FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 77
  • Dot Hidden: 0
  • Dot Users: 1
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
kyosho concept
Posted by: mattydred
in: my other rc helis
anttenna
Posted by: MarkLincs
in: Scout Bee
Hexa and gimbal 2
Posted by: ROVguy
in: ROVguys Album
* Latest Gallery Items
IMAG0786
Posted by: Njoro
in: FPV Stuff
Ground Station
Posted by: Njoro
in: FPV Stuff
IMAG0165
Posted by: Njoro
in: FPV Stuff
IMAG0161
Posted by: Njoro
in: FPV Stuff
zeroG Raptor
Posted by: Njoro
in: FPV Stuff
Author Topic: Hot Melt Glue gun - light, Medium or Heavy?  (Read 2875 times)
  • Air Commodore
  • Offline Offline
« on: April 27, 2012, 08:33:43 PM »
I have a pathetic, small hot melt glue gun. It heats and dispenses so slowly I cannot get a smooth continuous bead to - say fix a servo in.
This link http://www.kitepackaging.co.uk/scp/Glue_Guns_and_Sticks/Glue_Guns.html shows different types.
Which type would you recommend for general fixing around 'foamies' ??
i.e. what size of stick / gun is best?  8, 12, 16, 18mm ???
« Last Edit: April 27, 2012, 08:36:33 PM by wgt40w »
Logged
Steve W
  • "The Gaffer"
  • Offline Offline
  • ^ not actual size
    • DroneFinder
Re: Hot Melt Glue gun - light, Medium or Heavy?
« Reply #1 on: April 27, 2012, 09:26:15 PM »
I use a 12mm gun I got from Wilkinsons for a fiver ... you have to leave it 10 mins to heat up properly before the glue gets hot enough to stay melted for more than 5 seconds though.
Logged
6lennn
  • Guest
« Reply #2 on: April 27, 2012, 10:33:35 PM »
f me, theyre expensive
I just use the one I picked up in b&q
its a stanley one similar to this
its great, high setting is too hot for foam
low setting is spot on
can pump out a lot of glue in one go if you need it, stay hot enough to have a quick adjustment if needed
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #3 on: April 27, 2012, 10:48:26 PM »
At those prices you have money to burn, or melt in this case.  ;D
Mine is a cordless one from Lidl and probably cost less than a tenner. It does just fine and has no variable setting. EPP or Elapor are OK but it's too hot for Depron, so I use UHU Por on that.
BTW you don't need a bead round a servo. Either a blob on each servo mounting lug, or a blob on the side you are mounting against a surface.
Logged
6lennn
  • Guest
« Reply #4 on: April 27, 2012, 10:55:16 PM »
oh, to add
i dont go for a smooth bead when glueing, just lick your finger and run it along the glue while its still hot for a smooth finish
you will burn your finger if you dont use enough spit!
Logged
  • Air Commodore
  • Offline Offline
« Reply #5 on: April 27, 2012, 11:18:17 PM »
Thanks lads - and no I do not "have money to burn" - not even as a pun.
The link I chose at the beginning of this Thread was chosen as it showed a range of guns from light to heavy - NOT because of its' prices.
Right, so 12mm wins the competition - now I'll start looking for one at the right price, preferably with adjustable heat setting ????
Logged
* Recent Topics
What arrived today? by BigT
[Today at 10:03:06 AM]
Drone Debate in Parliament - includes Shakespeare quotes! Yep! by electrotor
[June 18, 2018, 02:58:20 PM]
Martian 2.....& Molly the Dog. by English Turbines
[June 17, 2018, 12:41:43 AM]
A break in our weather by drambuidhe
[June 16, 2018, 03:28:04 AM]
Z-84 Annotated Cruise Around My Field by Steve W
[June 16, 2018, 12:15:09 AM]
FXT Technology....Viper Goggles Test + Tiny Seven by English Turbines
[June 15, 2018, 07:12:26 PM]
Better Bungee Required by Drone 5
[June 15, 2018, 11:58:17 AM]
Popped my fixed wing Cherry by Coyote
[June 15, 2018, 09:08:33 AM]
3D Printed Wing by Coyote
[June 15, 2018, 09:03:56 AM]
Arrma Senton 6S BLX FPV by Coyote
[June 15, 2018, 08:56:59 AM]
A good laugh by Steve W
[June 14, 2018, 06:27:36 PM]
E.T.s Mini Talon...Upgrade to iNAV by Vickiexr
[June 14, 2018, 12:55:21 PM]
Steve's Wing Wing Z-84 Build with T1000FC by English Turbines
[June 13, 2018, 10:57:35 PM]
Torvol Drone Adventure Backpack - useful for Phantom owners and similar by FlyingRock
[June 13, 2018, 05:21:24 PM]
first build. need help with parts list. by Steve W
[June 13, 2018, 03:24:01 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
