FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 78
  • Dot Hidden: 0
  • Dot Users: 2
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
Toxic ship
Posted by: Macsgrafs
in: Aerial photography
QUEDADA FPV 006
Posted by: COKE32
in: FPV SPAIN
Receiver 2
Posted by: Coyote
in: Coyote`s Album
Sky surfer close up
Posted by: ROVguy
in: ROVguys Album
still glued together
Posted by: MarkLincs
in: Scout Bee
* Latest Gallery Items
IMAG0786
Posted by: Njoro
in: FPV Stuff
Ground Station
Posted by: Njoro
in: FPV Stuff
IMAG0165
Posted by: Njoro
in: FPV Stuff
IMAG0161
Posted by: Njoro
in: FPV Stuff
zeroG Raptor
Posted by: Njoro
in: FPV Stuff
Pages: 1 2 [3]
Author Topic: I'm New - DJI F450, TBS Discovery or QAV 540  (Read 11977 times)
  • Air Vice-Marshal
  • Offline Offline
  • November Video Of The Month Winner
« Reply #30 on: September 11, 2013, 08:43:43 PM »
my advice is unless you are very patient or just love tinkering you should go with plug and play or you might get put off :)
Logged
bs85
  • Flying officer
  • Offline Offline
Re: I'm New - DJI F450, TBS Discovery or QAV 540
« Reply #31 on: September 11, 2013, 09:07:09 PM »
This is my build spec, not saying its perfect but it does work:
Spidex and BL gimbal Euro 254 say about 211
Naza M V2 bundle http://quadcopters.co.uk/dji-naza-m-v2-flight-controller-inc-gps-721-p.asp 312
4 x  http://quadcopters.co.uk/torxpower-2216-pro-short-shaft-brushless-motor-800kv-125-p.asp 116
4 x http://www.unmannedtechshop.co.uk/multi-rotor/multirotor-motors-and-esc/22a-multi-rotor-esc-simonk-rapidesc.html 56
2 x http://www.electricwingman.com/power/propellers/apc/slow-fly/10x4.7.aspx 5
2 x http://www.electricwingman.com/product.aspx?product=1184 8
To power this I use a 4S 3-5000 MAh battery.
I also fitted a simple OSD and power supply but if you get the above Naza I would add the new mini iOSD from DJI http://quadcopters.co.uk/dji-iosd-mini-909-p.asp for 50
All up 758. Told you it was not cheap, have you got a GoPro3? If not another 280 plus a lead from Randall http://www.fpvhub.com/index.php/topic,15103.msg127088.html#msg127088
Scared even more now?
The setup of the Naza is easy, plenty of advise on here, it works out the box. The Spidex is easy to build and the BLG works out the box. You will get support on this forum, no matter what you choose.
Mick
PS don't let her indoors see this summary......one box at a time.....
Mick
This is nearly the same spec as mine. The differences are.
Torxpower 2216 900kv motors http://quadcopters.co.uk/torxpower-2216-pro-short-shaft-brushless-motor-900kv-v2-330-p.asp
Hobbyking blueseries esc 30a http://hobbyking.com/hobbyking/store/__13429__HobbyKing_30A_BlueSeries_Brushless_Speed_Controller.html
RCTimer props
ImmersionRC 5.8Ghz Audio/Video Transmitter  http://hobbyking.com/hobbyking/store/__17507__ImmersionRC_5_8Ghz_Audio_Video_Transmitter_FatShark_compatible_600mw_.html
Securitycamera2000 fpv camera
Hobbyking 3-Channel FPV Video Switcher http://hobbyking.com/hobbyking/store/__29651__Hobbyking_3_Channel_FPV_Video_Switcher.html
You could get a Naza M Lite instead of a Naza M V2 and save 172
I did have it flying with an Adrucopter APM2.5 for a while but it takes a bit more to time configure.
Logged
Witterings
  • Squadron Leader
  • Offline Offline
« Reply #32 on: September 11, 2013, 11:42:26 PM »
Very last question .... why won't the HD3 Gimbal work with the Discovery body ????
I'm interested to hear the answer BUT that said I think I'm going to go with the F450.
Reasons
It's my 1st build and I'd like something with lots of knowledge / support available.
No one's knocked it and said it's a rubbish product ...... maybe there's slightly better layouts but they come at a cost which at the moment would pay for a new TX / other bits / FPV.
If it works for me and becomes a more serious hobby / something to earn a bit of pocket money (I'm under no illusions you can make a lot of money out of this and have another business) I'd probably upgrade anyway and in which case I'd maybe make the 450 into my ...... fly it hard and have fun platform with everything else stripped off of it, maybe tale the Naza with GPS out (which could go in the upgrade) and just put in a simpler controller and fly it in manual mode.
A big thank you to everyone for their input really has been appreciated!!!
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #33 on: September 12, 2013, 09:07:27 AM »
The zenmuse gimbal needs to be mounted on the base and the disco isn't designed to have legs / gear and They Would sort of defeat the point of the disco anyway :)
Logged
Witterings
  • Squadron Leader
  • Offline Offline
« Reply #34 on: September 12, 2013, 09:50:59 AM »
The F450 comes with a set of legs and as the arms for the disco are the same couldn't you use the legs on the disco and mount it underneath.
I get what you're saying about the looks and it'd be better without legs but just from a praticallity point of view it'd give you a larger platform that's easier to work on / place your FPV gear ????????
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #35 on: September 12, 2013, 10:06:00 AM »
I think you're misunderstanding :)
The F450 and Disco are very different once assembled... Yes the disco uses the same F450 arms and electronics but the 'main body plates' are completely different.. The legs fix to the plates on the F450 so they wont attach to the disco.
The F450 is a traditional quad copter (you would normally attach a landing gear and gimbal to the base) where as the Disco is a 'dead-cat' layout which is designed to be low profile, the front arms are wide to allow for the camera on the nose and the tail long to allow for larger batteries to counter-balance the camera (to keep the CG)...
So by mounting the camera on the bottom and adding landing gear you completely fudge the CG and go against the whole purpose of a 'dead-cat' configuration.
And the F450 doesn't come with legs, they are an optional extra if you want to fit the DJI Zenmuse gimbal :)
This is what you need:
http://www.buildyourowndrone.co.uk/DJI-Naza-M-V2-GPS-H3-2D-Brushless-Gimbal-F450-p/dji-naza-m-v2-gps-h3-2d-f450.htm
« Last Edit: September 12, 2013, 10:10:06 AM by DaveyLC »
Logged
Witterings
  • Squadron Leader
  • Offline Offline
« Reply #36 on: September 12, 2013, 06:53:13 PM »
DaveyLC, I get where you're coming from with your last reply just really needed to get it straight in my head that I was doing the right thing and had looked at all the options!!!!!
I've ordered the DJI F450 bundle today, worst case scenario if I do want to upgrade to the disco pro in the future I've got most of the bits which without a bundled deal the Naza 2 would be 312 alone and I'm sure I could sell the 2nd hand  HD3 Gimbal for 150 approx so to me for now it seemed like a bit of a no brainer to be able to try without too much of an outlay initially.
Once again thanks to all for your input has been much appreciated!!!!
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #37 on: September 12, 2013, 06:54:35 PM »
If you want 150 for the gimbal you've sold it to me already  :laugh:
Logged
Pages: 1 2 [3]
* Recent Topics
What arrived today? by BigT
[Today at 10:03:06 AM]
Drone Debate in Parliament - includes Shakespeare quotes! Yep! by electrotor
[June 18, 2018, 02:58:20 PM]
Martian 2.....& Molly the Dog. by English Turbines
[June 17, 2018, 12:41:43 AM]
A break in our weather by drambuidhe
[June 16, 2018, 03:28:04 AM]
Z-84 Annotated Cruise Around My Field by Steve W
[June 16, 2018, 12:15:09 AM]
FXT Technology....Viper Goggles Test + Tiny Seven by English Turbines
[June 15, 2018, 07:12:26 PM]
Better Bungee Required by Drone 5
[June 15, 2018, 11:58:17 AM]
Popped my fixed wing Cherry by Coyote
[June 15, 2018, 09:08:33 AM]
3D Printed Wing by Coyote
[June 15, 2018, 09:03:56 AM]
Arrma Senton 6S BLX FPV by Coyote
[June 15, 2018, 08:56:59 AM]
A good laugh by Steve W
[June 14, 2018, 06:27:36 PM]
E.T.s Mini Talon...Upgrade to iNAV by Vickiexr
[June 14, 2018, 12:55:21 PM]
Steve's Wing Wing Z-84 Build with T1000FC by English Turbines
[June 13, 2018, 10:57:35 PM]
Torvol Drone Adventure Backpack - useful for Phantom owners and similar by FlyingRock
[June 13, 2018, 05:21:24 PM]
first build. need help with parts list. by Steve W
[June 13, 2018, 03:24:01 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
