  • Dot Guests: 33
  • Dot Users: 2
tri 4
Posted by: n00b@FPV
in: Tricopter
The begining
Landing Gear 3
Ply mounts
3dbi omni
IMAG0786
Ground Station
IMAG0165
zeroG Raptor
Pages: 1 2 3 [4]
Author Topic: BlueFlyer's F3 Shadow FPV Racer  (Read 1734 times)
JeromeF
  • Cadet
Re: BlueFlyer's F3 Shadow FPV Racer
« Reply #45 on: May 01, 2017, 08:27:00 PM »
I'm thinking of going for a similar configuration to the TBS Caipirhana and having the Rx and VTx mounted on the wings.. Might be a bit ambitious but I am sure I'll find a way to crap it all in and I've got a nice rig for cutting holes and cavities into foam :D
  • Air Chief Marshal
  • Head in the clouds
« Reply #46 on: May 01, 2017, 09:32:26 PM »
It's definitely possible, I reckon I could easily build one with a full AP if I were to do it again. But the type of plane it is doesn't really lend itself to having an AP/Stabiliser on board.
X-UAV Mini Talon
FlyingWings F3 Shadow
FlyingWings Hornet
GEPRC TX5 - Chimp Quad
JeromeF
  • Cadet
« Reply #47 on: May 02, 2017, 09:37:17 PM »
It's more for the OSD, Home Position and potentially RTH if I needed to recover: works out an awful lot cheaper than me buying the GPS for a TBS Core Pro. The cost of a FC, GPS, Current Sensor is around 50 and the TBS GPS 75 aha.
I reckon it'll be in manual mode most the time :) Also if it all goes well I'll put the same kit into a bigger wing for 'range testing' aha
AdamG
  • Group Captain
« Reply #48 on: May 03, 2017, 08:09:38 PM »
I put an AP in my Falcon as insurance too. I never user stabilised or anything like that, I fly manual all the time... but I like having RTH for the odd occasion where I push it a bit too far and lose video signal. Oh and occasionally I use loiter for a break  :)
Dillwhacker
« Reply #49 on: May 18, 2017, 10:53:56 PM »
Hey Blue.
I noticed you soldered the motor wires directly to the ESC without bullets.
Did you shorten the motor wires? If so, how did you re-tin the remaining wire?
I just did mine and had a devil of a job re-tinning the enamelled motor wires - what's the trick?
Taaa
benitoculito
  • Flight Lieutenant
« Reply #50 on: May 18, 2017, 11:39:55 PM »
Dillwhacker
« Reply #51 on: May 18, 2017, 11:47:53 PM »
Cheers Benito.
I tried that and it seemed to sort of work, but not as easily as in that video.
After I tried that, I used a gas soldering iron set to silly hot, and the combination of the two did the trick, but it was a struggle.
Thanks bud.
  • Air Chief Marshal
« Reply #52 on: May 19, 2017, 12:23:33 AM »
Are you using the same motor? I didn't have any issues tinning my motor wires after cutting off the bullets
X-UAV Mini Talon
FlyingWings Hornet
Dillwhacker
« Reply #53 on: May 19, 2017, 12:30:05 AM »
Yes. The same one from the HK ME163.
I cut them down very short and was left with about 8 strands in each of the 3 phases, with very tough enamel covering that was a real begger to remove. Cut down well below the original tinning.
Managed eventually, but was not fun !
  • Air Chief Marshal
« Reply #54 on: May 19, 2017, 12:37:21 AM »
I've seen somewhere that you can apparently use asprin to treat the enamel wire to make it easier to tin.
X-UAV Mini Talon
FlyingWings Hornet
  • Air Chief Marshal
« Reply #55 on: May 19, 2017, 12:40:59 AM »
From here: https://electronics.stackexchange.com/questions/53028/how-to-remove-enamel-from-wire
Quote
Get a pill of aspirine. Put your enameled wire on its surface and press it down with a soldering iron's tip heated by operational temperature. Aspirin melts, boils, gets in contact with enamel and desintegrates its coating on wire's copper. So you can strip it with the same soldering iron's tinned tip pretty easily in a couple of seconds (up to 10 sec in fact). Then let it cool down for a several seconds and remove the brittle (like a colophony) melted aspirine's rests away from naked and tinned enameled wire's tip... Do not breath in the aspirine smoke.
X-UAV Mini Talon
FlyingWings Hornet
Dillwhacker
« Reply #56 on: May 19, 2017, 12:48:16 AM »
Cheers Blue, the Aspirin thing sort-of worked.
But I wasn't sure all of the strands were tinned nicely, so I attacked it with a REALLY hot gas iron, and that removed the remains of the varnish and gave me a nice shiny joint.
Happy days now.
Pages: 1 2 3 [4]
X-UAV Mini Talon by SnoozeDoggyDog
[Today at 05:35:42 PM]
Awesome Flytower AIO ESC/FC/VTX thingy review by CurryKitten
[Today at 04:59:11 PM]
Review of the Eachine Aurora 100 Brushless microquad by beesleyboy
[Today at 03:58:43 PM]
Hello from Aylesbury by Jakalas
[Today at 03:46:06 PM]
Flying to the Lighthouse island by beesleyboy
[Yesterday at 09:29:50 PM]
Runcam2 doing other stuff by Coyote
[Yesterday at 07:16:07 PM]
InsideFPV drone racing. by Roundozo
[Yesterday at 05:51:36 PM]
Hello by Coyote
[Yesterday at 03:25:15 PM]
New Flying Site by beesleyboy
[Yesterday at 11:49:24 AM]
MFD AAT 90 degrees off when tracking by SnoozeDoggyDog
[Yesterday at 12:15:15 AM]
Champions League drone attack by Steve W
[May 26, 2017, 11:34:42 PM]
E.T.s SKYFUN with Aeromax OSD & GPS.....Maiden Flight. by English Turbines
[May 26, 2017, 09:59:24 PM]
Where can I get one of these? by Gundummy
[May 26, 2017, 09:28:44 PM]
Phantom 4 ... What's the max wind You fly in??? by ORCA
[May 26, 2017, 05:16:27 PM]
Ritewing Mini Drak. by iwan_canobi
[May 26, 2017, 04:13:56 PM]
