FPV HUB
Advanced search
News:
* Site Sponsor
* Random Gallery Items
Sky surfer close up
Posted by: ROVguy
in: ROVguys Album
All equipment in
Posted by: Coyote
in: Coyote`s Album
ce s
Posted by: jakegazzard
in: CE OSD
DSCF6008
Posted by: n00b@FPV
in: Stuff
easy2
Posted by: munkyboy
in: Pauls Stuff
* Latest Gallery Items
IMAG0786
Posted by: Njoro
in: FPV Stuff
Ground Station
Posted by: Njoro
in: FPV Stuff
IMAG0165
Posted by: Njoro
in: FPV Stuff
IMAG0161
Posted by: Njoro
in: FPV Stuff
zeroG Raptor
Posted by: Njoro
in: FPV Stuff
Author Topic: Converting 27MHz Co-axial to 2.4GHz  (Read 4724 times)
keukpa
  • Guest
« on: December 16, 2012, 06:30:13 AM »
OK,
So my sister was kind enough to buy me a LARGE co-axial Helicopter for Christmas (Sky King 42"), so pretty hefty.
The current control system is a custom 27MHz board that drives two DC motors, one for each set of the coaxial blades.
What I want to do is convert this system to 2.4 GHz and make it FPV. I want 2.4GHz as I'll get some better range and more channels.
I've found one solution that I think might work, but this will only give me limited channels, I'll show that in a second. But the problem I'm forseeing is that the throttle channel on the coaxial controls both the motors at the same time, and yawing left or right, changes the speed of one of these motors to allow the rotation....
So I can just put in a standard 2.4GHz RX and Some ESCs as this isn't going to work, so my question is, does anyone know how this modification can be made? Are there any off-the-shelf 2.4GHz mods for coaxial helicopters?
Here is the helicopter:
http://www.ebay.co.uk/itm/160882758182?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D160882758182%26_rdc%3D1
Here is the heli control board:
http://www.ebay.co.uk/itm/SKY-KING-8501-01-PCB-Receiving-Board-Motherboard-27MHz-/120697579760?pt=UK_ToysGames_RadioControlled_JN&hash=item1c1a22e8f0&_uhb=1
Here is what I'm thinking of using to make 2.4GHz, however, I'm not sure if this will have the current supply for this size heli:
http://www.ebay.co.uk/itm/ESKY-2-4GHZ-4-IN-1-RECEIVER-LAMA-V3-V4-HUNTER-KOB-CO-AXIAL-000878-RX-EK2-0708-/150663340144?pt=UK_ToysGames_RadioControlled_JN&hash=item23143c2070&_uhb=1
Any help would be much appreciated!
Keukpa
Logged
  • Air Vice-Marshal
  • Offline Offline
Re: Converting 27MHz Co-axial to 2.4GHz
« Reply #1 on: December 16, 2012, 12:39:11 PM »
The 27MHz board appears to be both rx and  controllers, but the Esky appears to be just the rx so is not a direct replacement. You would have to find a matching controller board for the motors. How much time do you have and experience with electronics?
Logged
keukpa
  • Guest
« Reply #2 on: December 16, 2012, 12:45:19 PM »
Hi electrotor,
The 4-in-1 also powers to motors (I have on of these on my small V3-Lama) - better view and info here:
http://www.heliguy.com/Electric-RC-Helicopters/ESKY-KOB/EK2-0708-2.4GHz-4-in-1-Controller/
As for electronics experience, a degree in Electronic Engineering, and about 20 years experience (playing :) ). Oh and loads of time.
I was mainly wondering if there was a COTS I could use for direct replacement, if not I'm sure I can stick something together. Just prefer the easy option :)
Cheers,
Keukpa
Logged
mike
  • Flight Lieutenant
  • Offline Offline
« Reply #3 on: December 16, 2012, 12:56:14 PM »
i might be wrong but... i think the kk board can controll a coax too   (2M 2S singlerotor??)
+2 cheap escs and it should work :P
keukpa
  • Guest
« Reply #4 on: December 16, 2012, 01:03:25 PM »
Hi Mike,
Hmmm now there is an idea!! Any links to reference this?
I'll have to read up!
Cheers,
Keukpa
Logged
  • Admin
  • Offline Offline
    • My New Blog
« Reply #5 on: December 16, 2012, 01:10:06 PM »
i might be wrong but... i think the kk board can control a coax too   (2M 2S singlerotor??)
That`s a very good point, the KK the black and blue boards can run dualcopter mode which is a coaxial heli. That`s by far the easiest way
Logged
My Blog
My Youtube
My Vimeo
keukpa
  • Guest
« Reply #6 on: December 16, 2012, 01:21:37 PM »
Awesome!
Are these the HobbyKing ones?......hang on let me find a link....
These:
http://www.hobbyking.com/hobbyking/store/__21977__HobbyKing_Multi_Rotor_Control_Board_V3_0_Atmega328_PA_.html
Actually, thinking about it, would any KK board, or even MultiWii board do it?
Cheers,
Keukpa
Logged
  • Admin
  • Offline Offline
    • My New Blog
« Reply #7 on: December 16, 2012, 01:59:49 PM »
The multiwii does support dualcopter yes
I`m not sure on that board you linked too, but this board does for sure
http://www.ebay.co.uk/itm/KK-Multicopter-Flight-Control-Board-V5-5-Tricopter-Quadcopter-Hexacopter-/230882665173?pt=UK_ToysGames_RadioControlled_JN&hash=item35c1ade2d5
Logged
My Blog
My Youtube
My Vimeo
  • Matured, not aged
  • Global Moderator
  • Group Captain
  • Offline Offline
« Reply #8 on: December 16, 2012, 02:26:36 PM »
The OpenPilot CC board (and CC3D) looks like it will do coaxial
http://forums.openpilot.org/topic/10645-coaxial-helicopter/page__hl__%20coaxial
PK
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #9 on: December 16, 2012, 02:43:15 PM »
Time available and experience give you a distinct advantage. The Esky link in your first post only partially came up on my phone so it appeared to be only an rx. As I recall the Lama is quite a bit smaller than the coax you have been given so it is likely that the current raings of the escs will not be sufficient.
KK solution seems promising but more complex than necessary.
Logged
keukpa
  • Guest
« Reply #10 on: December 16, 2012, 02:50:22 PM »
yeah, this was my thought, I think it isn't sufficient to deliver the required current for the larger heli.
But I think a KK or MultiWii that do co-axial is certainly the quickest and easiest solution, and pretty cheap too :)
So, I'll investigate that first...unless anyone knows of a dedicated system?
Cheers,
Keukpa
Logged
charosenz
  • Guest
« Reply #11 on: June 05, 2013, 07:37:18 AM »
I am sure if the authors will read this but I would sure like to know if the conversion worked out.   If so could you share the results here on the thread?
Logged
  • Air Vice-Marshal
  • Offline Offline
  • November Video Of The Month Winner
« Reply #12 on: June 07, 2013, 04:49:06 PM »
By the looks of things you need three brushed speed controllers (2 medium, 1 weeny), a gyro and some interesting mixing on your radio :D
Logged
charosenz
  • Guest
« Reply #13 on: June 08, 2013, 04:42:11 PM »
I thought about the mixing issue, and not sure how that would be set up.  I am sure someone has done this......
 I also like the idea of using a multirotor mixing board like the KK style controller.  I know that Hobby King advertises one for about $20.00.  It has a 3 axis piezo gyro on the board which is great.  I know it has a 3 rotor profile on the list of set up.   I am just not sure if you used this board, if it would take the place of the 3 brushed, ESC, do you?
I was also hoping to hear back from some of the folks who posted on this to see if they made any progress on this.
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #14 on: June 14, 2013, 06:43:03 PM »
The gyro will need to control the speed difference between the two main blades but you'd have to create a mix for the throttle as it will be controlling two speed controllers.
Logged
* Recent Topics
A reasonably priced antenna analyser that covers 433MHz up to 2.4 GHz by Capt_Science
[Today at 01:19:23 AM]
Google Hangouts by Steve W
[Today at 01:10:43 AM]
New Wing- Reptile S800 - anyone got one? by Jake Bullit
[Yesterday at 11:53:04 PM]
Pitot Mount by BlueFlyer
[Yesterday at 10:18:58 PM]
Hi from an old git in MK by Coyote
[Yesterday at 09:52:06 PM]
Micro Minim OSD on PDB by Coyote
[Yesterday at 08:43:17 PM]
If you pre-ordered a Lily DRONE will you will get your money back? by Gundummy
[Yesterday at 08:34:41 PM]
Hi, new here! Vector on bixler, gain and pids? Help! by Steve W
[Yesterday at 08:28:33 PM]
Hi all just joined ! by Gundummy
[Yesterday at 06:46:31 PM]
Connecting to Cleanflight by Gundummy
[Yesterday at 06:43:03 PM]
Coming soon - the sky hook by Gundummy
[Yesterday at 06:35:59 PM]
Eflite Opterra by Gundummy
[Yesterday at 06:33:05 PM]
3D Printed Planes by Coyote
[Yesterday at 05:44:14 PM]
What arrived today? by CurryKitten
[Yesterday at 02:42:25 PM]
Mini Talon - Clouds by Coyote
[January 17, 2017, 05:40:00 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
