FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 83
  • Dot Hidden: 0
  • Dot Users: 4
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
Receiver 2
Posted by: Coyote
in: Coyote`s Album
tricopter2
Posted by: n00b@FPV
in: Tricopter
Croyde beach
Posted by: Macsgrafs
in: Aerial photography
8dbipatch
Posted by: Coyote
in: Coyote`s Album
DSCN1152
Posted by: COKE32
in: FPV SPAIN
* Latest Gallery Items
IMAG0786
Posted by: Njoro
in: FPV Stuff
Ground Station
Posted by: Njoro
in: FPV Stuff
IMAG0165
Posted by: Njoro
in: FPV Stuff
IMAG0161
Posted by: Njoro
in: FPV Stuff
zeroG Raptor
Posted by: Njoro
in: FPV Stuff
Author Topic: Mobius. wide angle or normal for a miniquad  (Read 17906 times)
rob.thomson
  • Group Captain
  • Offline Offline
« on: August 01, 2014, 05:01:50 PM »
Title says it all...
Any suggestions?  I plan to use it as my flight cam.
Rob
Logged
ThunderstruK
  • Wing Commander
  • Offline Offline
Re: Mobius. wide angle or normal for a miniquad
« Reply #1 on: August 01, 2014, 05:19:49 PM »
I don't use it as my flight cam, but I have the standard lens for my video on my drq250. To me it gives a nice field of view.
Logged
Brod
  • Wing Commander
  • Offline Offline
« Reply #2 on: August 01, 2014, 05:42:09 PM »
wide angles best,when flying fast you can still see the ground and also able to see more to the left and right..
Logged
never ever give up...
Dave
  • Wing Commander
  • Offline Offline
  • Let there be Flight....
    • F.P.heaVen
« Reply #3 on: August 01, 2014, 06:51:29 PM »
I use a 'normal' one as my flight cam and I have never found myself wishing Id bought the 'wide' one.......Then again, Ive never flown using a 'wide' :+ :-\
Be aware there is a couple of milliseconds delay on them. I don't find it a problem but I know some people do.
Logged
WWW.FPHEAVEN.CO.UK
jamesb72
  • Wing Commander
  • Offline Offline
« Reply #4 on: August 01, 2014, 07:00:58 PM »
I much prefer the video from the standard lens over the wide, I don't use it for FPV view though.
I did a comparison video which shows the various settings with both lens.
FOV static comprison
Mobius quick FOV test Orig A lens vs Wide B lens in wide/narrow views
Micro quadcopter flight comparison
Mobius Orig A vs Wide B lens comparison in 30fps and 60fps on FPV250 Micro Quadcopter
I've actually ordered a standard lens/module to replace the wide one on my 2nd camera, as to me the wide lens is unusable, so if anyone wants a wide lens/module for cheap and can wait a few weeks drop me a PM. It looks like its fairly straightforward to swap the lens/module over:
See post 4 on this thread:
http://www.rcgroups.com/forums/showthread.php?t=1904559
« Last Edit: August 01, 2014, 07:02:30 PM by jamesb72 »
Logged
Ynot6
  • Quadbod
  • Wing Commander
  • Offline Offline
  • IN COMIIIIING !!!!!!!
« Reply #5 on: August 01, 2014, 07:56:56 PM »
very usefull. helps me with a decision about my HK 250.
Logged
OMG, IT FLIES!
  • Group Captain
  • Offline Offline
« Reply #6 on: August 15, 2014, 10:26:33 AM »
I prefer the wide angle myself
Logged
weavo56
  • Flight Lieutenant
  • Offline Offline
« Reply #7 on: August 30, 2014, 11:33:45 PM »
The only problem is the lag on the video feed from this camera as a flight cam .
It might give you a problem when at speed .
just a thought  .
Graham
Logged
Quads , 450,550,280's
mini Skyhunter
jamesb72
  • Wing Commander
  • Offline Offline
« Reply #8 on: September 02, 2014, 12:41:10 PM »
Just to update I swapped the lens/module over from the wide B lens to original A lens at the weekend on my second mobius, its really easy to swap over, two screws the top flips off and the camera is just wedged in, and the ribbon cable has a release bar and just slides out. You could swap back and forth pretty easily in a couple of minutes.
The A lens/module came already focused so no adjustment needed, just drop in and it worked.
My wide B lens module (lens and sensor) is NOW SOLD
« Last Edit: September 03, 2014, 08:24:55 AM by jamesb72 »
Logged
  • FPVHub Troll
  • Air Chief Marshal
  • Offline Offline
« Reply #9 on: September 02, 2014, 01:23:26 PM »
I've had both, and I've used both as the flight cam on my quadcopter.
I had the normal lens first, then when I lost the mobius when it was on a different aircraft, I took the opportunity to buy the wide angle one.
the normal one never felt like I was able to see enough around me when flying, the wide one is brilliant and the extra visibility has made me a more confident pilot.
Although I have personally tested the lag/latency on the mobius live AV out in the workshop... there IS some lag... but it's tiny.
I fly my quad fast and slow using the mobius live AV out and the lag has never been an issue for me.
In fact, the Live AV out is so good, that I plan on never buying another flight cam again, I will just build a little platform so I can move my mobius around from airframe to airframe. HD and flight cam from this camera is brilliant for such a good price.
Logged
  • Matured, not aged
  • Global Moderator
  • Group Captain
  • Offline Offline
« Reply #10 on: September 02, 2014, 03:53:06 PM »
James,
Just sent you a pm about the Mobius wide lens etc.
 :) PK
Logged
jamesb72
  • Wing Commander
  • Offline Offline
« Reply #11 on: September 03, 2014, 08:25:20 AM »
Thanks PK will get it posted today.
Logged
* Recent Topics
BlueFlyer's 15.4" LCD Flight Case Ground Station by English Turbines
[Today at 10:26:19 PM]
Omnibus F4 Autopilot...iNAV....Fixed Wing. by English Turbines
[Today at 10:01:28 PM]
E.T.s Martian 2 build....First proper quad. by English Turbines
[Today at 05:34:21 PM]
{ W I N D S O N G } by War Chest
[Today at 08:20:20 AM]
VIFLY by johnq816
[Today at 05:33:23 AM]
Ritewing Mini Drak. by mutley2
[Yesterday at 10:16:01 PM]
Where can I fly? by Tony O
[Yesterday at 01:49:40 PM]
Hi from Torbay by Tony O
[Yesterday at 11:33:06 AM]
ZTW Gecko 150A OPTO HV by rchobby
[Yesterday at 10:27:32 AM]
3D Printed Vesper Wing by iwan_canobi
[Yesterday at 09:59:14 AM]
AKK Technology Coupon Code Sharing by Dennislee
[Yesterday at 07:31:04 AM]
What arrived today? by Njoro
[January 21, 2018, 04:13:38 PM]
Have we been hacked? by wgt40w
[January 21, 2018, 03:24:36 PM]
Review of the Diatone GTR-90 Micro quad (Part 1) by ched
[January 20, 2018, 05:01:16 PM]
Fatshark faceplate clips by parky
[January 19, 2018, 06:27:54 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
