FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 91
  • Dot Hidden: 0
  • Dot Users: 1
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
Folded Up
Posted by: Coyote
in: Coyote`s Album
Hexa and gimbal 2
Posted by: ROVguy
in: ROVguys Album
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Author Topic: RVOSD questions  (Read 5727 times)
markvanhaze
  • Wing Commander
  • Offline Offline
  • Sir Crash-A-Lot-Airlines
    • Always Windy
RVOSD questions
« on: June 02, 2013, 11:36:02 AM »
So I have started a Z2 build with RVOSD. I have 2 major issues:
1. If there is no video signal coming from the flightcam, the OSD stays dark. So if for any reason the flightcam dies during flight, bye bye plane or quickly flip to RTL?
2. Is there a quick way to invoke RTL, ie. a flip of a switch? From what I can see I have to get into the OSD menu, and select RTL myself OR switch off my transmitter and using the failsafe RVOSD should go into RTL mode.
Logged
  • Air Commodore
  • Offline Offline
Re: RVOSD questions
« Reply #1 on: June 02, 2013, 12:38:13 PM »
1. I am fairly sure my RVOSD output picture without a camera when I was setting it up I distinctly remember seeing it before I had plugged in my camera. Think about it, what if your flight cam gives up? With RVOSD you can fly blind.... it would be v. bad design if the OSD stopped when the camera did. I wonder if there is something up with your wiring causing that?
2. Yes. Configure RVOSD FS throttle detect in the normal way. Then configure a switch on your TX with a mix to bump the throttle into the failsafe position you previously set. Then you just set RVOSD failsafe to RTH.
That you you can save the 3 position switch for other modes like fly by wire.
Logged
markvanhaze
  • Wing Commander
  • Offline Offline
    • Always Windy
Re: RVOSD questions
« Reply #2 on: June 02, 2013, 12:53:59 PM »
I can reproduce it everytime - the RVOSD does not show up when there is no signal from the camera. Once the camera delivers a signal, its immediately on.
Thanks though for the RTL/Throttle solution, that makes sense.
Logged
  • Air Commodore
  • Offline Offline
Re: RVOSD questions
« Reply #3 on: June 02, 2013, 01:34:24 PM »
Ok I'll get back to you when I get a chance to plug mine in and confirm.
Logged
markvanhaze
  • Wing Commander
  • Offline Offline
    • Always Windy
Re: RVOSD questions
« Reply #4 on: June 02, 2013, 02:17:35 PM »
Cheers mate.
Logged
  • Air Vice-Marshal
  • Offline Offline
  • November Video Of The Month Winner
Re: RVOSD questions
« Reply #5 on: June 05, 2013, 10:09:20 AM »
A few of them (OSD's) don't generate their own sync-signal so need the video from camera..
I know the Cyclops and the FY-Hornet generate their own sync signal and will give you the over-lay without a video feed :)
Logged
markvanhaze
  • Wing Commander
  • Offline Offline
    • Always Windy
Re: RVOSD questions
« Reply #6 on: June 07, 2013, 02:48:42 PM »
Its confirmed, no video, no OSD. Checked back with RVOSD.
Logged
  • Air Vice-Marshal
  • Offline Offline
Re: RVOSD questions
« Reply #7 on: June 07, 2013, 04:40:30 PM »
That's a bit crap  :o
Logged
  • Group Captain
  • Offline Offline
RVOSD questions
« Reply #8 on: June 07, 2013, 06:35:20 PM »
It's pretty common... The majority don't generate their own sync.
Logged
  • Air Vice-Marshal
  • Offline Offline
Re: RVOSD questions
« Reply #9 on: June 07, 2013, 07:06:53 PM »
Be interesting to know which ones do, as its very useful for redundancy.. i.e. if your camera dies you can still use the home arrow.
I know G-OSD/CL-OSD doesn't have its own sync signal.
The old Cyclops & FY21/31 do :)
Logged
markvanhaze
  • Wing Commander
  • Offline Offline
    • Always Windy
Re: RVOSD questions
« Reply #10 on: June 07, 2013, 07:14:40 PM »
FY Hornet OSD works without cam. I also think thats pretty crap of RVOSD. Classic example where it comes in handy if you have OSD without the cam was someone posted a video of his wing colliding mid air with another and the flightcam died so he flew home on instruments until LOS.
Logged
Baner
  • Squadron Leader
  • Offline Offline
Re: RVOSD questions
« Reply #11 on: June 23, 2013, 02:02:01 PM »
So you are saying that as soon as I loses the video the plane crashes, it doesn't turn on the return to launch it just crashes. If so, would somebody like to buy my RVOSD
Logged
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
Re: RVOSD questions
« Reply #12 on: June 23, 2013, 02:11:24 PM »
If you loose your picture select rth or turn your transmitter off to activate rth :)
Logged
markvanhaze
  • Wing Commander
  • Offline Offline
    • Always Windy
Re: RVOSD questions
« Reply #13 on: June 23, 2013, 02:31:51 PM »
Nope thats not what im saying. The RVOSD will work just as before but you will not see anything on the screen and have to rely on the RTL IF you switched it on / activated it by turning the transmitter off.
Logged
* Recent Topics
Golden Wings by urbanfpv
[June 06, 2021, 05:55:19 PM]
Newbie from Lincoln here by Coyote
[June 06, 2021, 07:57:49 AM]
Hi from the midlands by Coyote
[June 06, 2021, 07:57:26 AM]
New FPV UK Article 16 Operational Authorisation (issue 2) & FPV UK Handbook v1.1 by big a
[May 30, 2021, 09:58:49 AM]
some tree trimming by luv2rip-fvp
[May 27, 2021, 04:09:49 AM]
a quick pack this past weekend by luv2rip-fvp
[May 19, 2021, 02:33:19 AM]
Didn't make it over the branch by luv2rip-fvp
[May 05, 2021, 01:23:46 AM]
Help required. Standalone FPV camera by FPVSteve
[April 22, 2021, 10:18:07 PM]
Wassssup from Kent by Drone 5
[April 20, 2021, 10:48:16 PM]
I forgot I had these props by luv2rip-fvp
[April 19, 2021, 03:02:31 AM]
* Keywords
fpvhub  fpv hub
* Disclaimer
