Diversity controller for under £5
Started by MatZeRO, March 20, 2014, 03:12:47 PM
MatZeRO
Did anyone see the video from Bruce on Youtube where he makes a diversity controller for $1.29?  A $1.29 FPV diversity controller (theory & design)
Had some spare time today so we had a little play and made one, works perfectly!  We added some headers to make it look nicer and we are going to shrink wrap it.
Bit messy on the bottom :P
stevec
cool, did you use the extra resistor and capacitors as Part 3?
cheers
Steve
gtv
Looks good, where did you get the RSSI from?
MatZeRO
Cleaned it up a bit, looks neat now.
Yes I did all the bits he mentions in part 3.
RSSI is from the pin on the RX, had to solder to it.
mrwilljackson
Looks fab, I'm waiting on a second vrx to build one of these myself - pleased it works!
Thats cool! The switch is great. Similar circuit with an arduino could also be used for switching between 2 cameras on board!
A version that looks at the video output would be cooler cos then you could use any vrx. Though would need to figure out an algorithm to figure what is a clean video signal and what isnt.
Brilliant job though Bruce!
TBC15
Could you give us a parts list please and where did you get your parts from? Any thoughts on mounting 2 of the cheap 5V RX modules on the same board?
stevec
I ordered the bits to make a couple of these today.
Not sure I like the dead bug technique but I'll use some variboard I have knocking about and mount the stuff through the holes...
If I can find a half decent cheap case I may make a couple to sell on.
This hobby is great for getting your geek on :-)
/Steve
MatZeRO
@SteveC did you make one in the end?
stevec
Not yet. I have all the bits but we went away for easter..
Sent from my GT-I9505 using Tapatalk
stevec
apparently they do, but it works backwards so you need to hook the video feeds up backwards so it switches to the other rx on a high signal.
/Steve
stevec
I'm using these...
http://www.firstpersonview.co.uk/receivers/airwave-7ch-receiver
Bought 2 just need to make the controller now.
/steve
stevec
Not sure but I don't transmit audio I cut the wires off the plugs.
I am just going to do the mods he does in his videos.
Here is what I did tonight.  Testing my new solder station ;-)
And one for scale...
Next to solder the capacitors and modify the recievers to feed rssi out.
I went with varo board as I didn't fancy trying to hold 4 to 5 wires together and solder them all at once.
If the thing works I'll tidy it up and get it mounted in a case.
Steve
MatZeRO
We found the dead bug method a pain in the behind. We had a go at creating our own circuit, works ok, got it in my ground station now.
MrGyro
