FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 83
  • Dot Hidden: 0
  • Dot Users: 0
* Site Sponsor
* Random Gallery Items
DVR
Posted by: Coyote
in: Coyote`s Album
Sky surfer close up
Posted by: ROVguy
in: ROVguys Album
QUEDADA FPV 040
Posted by: COKE32
in: FPV SPAIN
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Author Topic: RVOSD in a Skywalker 1900 anyone?  (Read 6013 times)
g4wft
  • Flying officer
  • Offline Offline
« on: August 27, 2014, 09:03:52 AM »
Hi,
I've just finished building a Skywalker 1900.  I'm getting the plane trimmed out at the moment without the RVOSD and FPV gear (but with suitable dummy weight added to simulate the extra items).  It flies OK, but I find the ailerons fairly ineffective.  Mixing in some rudder with ailerons helps a lot.  I have the CoG right on the servo wires at the moment.
When I install the RVOSD though and it takes control there clearly won't be any mixing going on, as that's a function of the RC Tx.  The same goes for any autopilot I guess.  So, how have you found the Skywalker under A/P control - any problems with aileron authority?  Do I need to look at getting aileron differential?  I'm using a single channel for ailerons, so it's going to have to be mechanical differential if I go that route.  Or do I need to be moving the CoG a little further back?
Interested to hear your opinions.
Cheers,
Tim.
Logged
  • Nothing works !!
  • Air Commodore
  • Offline Offline
  • I'm not deaf just thinking
« Reply #1 on: August 27, 2014, 09:52:12 AM »
My 1900 is the same, handles like a canal barge in a crosswind. In my experience differential won't help. It's down to the dihedral and aileron size and the under camber on the wing. As I have always flown large scale warbirds and autogyro I always use rudder, not relying on any mixing to do so. With my MFD AP there is an option to have the ap mix in rudder in auto flight modes but I have not found that necessary. I do find the 1900 very hard to do a steep climb on full power. It just wants to fall off to either side. Again it's the wing.
In auto flight I have tuned  the turns to be  very gentle and the stabilisation high to cope with the small aileron.
My solution would be to increase the dihedral or increase the size of the aileron or open up the flaps cut out and put in secondary ailerons ( 2 more servos). I notice that BEVRC do a replacement wing with a different section and bigger ailerons.
Logged
  • Air Commodore
  • Offline Offline
Re: RVOSD in a Skywalker 1900 anyone?
« Reply #2 on: August 27, 2014, 12:49:27 PM »
Never had a problems with aileron control with my Skywalker 1900. More than enough for typical flying, I never felt like I needed more. Full lock it's more than agile enough. To get nice turns you need to use rudder.
I use single channel with a Y-Lead through my RVOSD. Works just fine, no need to mess around with aileron differential.
If you are finding your ailerons ineffective have you tried increasing the throws?
Logged
g4wft
  • Flying officer
  • Offline Offline
« Reply #3 on: August 27, 2014, 01:57:34 PM »
Thanks very much for the replies chaps.  The ailerons are setup with 120% travel on the servos at present, but I could move the linkage to a closer hole on the aileron horn.
What do you reckon on the CoG being on the servo wires?  Could it go a bit further back do you reckon?
Thanks,
Tim.
Logged
  • Air Commodore
  • Offline Offline
« Reply #4 on: August 27, 2014, 02:11:43 PM »
Yeah I've moved mine down to get a decent amount of travel on the aileron.
Never really experimented with CG on my SW. It's always forward of the servo wires, even massively loaded up I just fly nose heavy, it has more than enough elevator to keep that in check and I never noticed it flying worse because of it.
Logged
g4wft
  • Flying officer
  • Offline Offline
« Reply #5 on: August 27, 2014, 02:51:43 PM »
Fair comment - thanks Dogz.  I too prefer to fly a bit nose-heavy if anything, simply because I've had bitter experience of a CoG that's too far back - it ain't pleasant!
I'll shift the pushrod a bit inwards on the control horn and as soon as I can give it another try.
Thanks,
Tim.
Logged
* Recent Topics
Golden Wings by urbanfpv
[June 06, 2021, 05:55:19 PM]
Newbie from Lincoln here by Coyote
[June 06, 2021, 07:57:49 AM]
Hi from the midlands by Coyote
[June 06, 2021, 07:57:26 AM]
New FPV UK Article 16 Operational Authorisation (issue 2) & FPV UK Handbook v1.1 by big a
[May 30, 2021, 09:58:49 AM]
some tree trimming by luv2rip-fvp
[May 27, 2021, 04:09:49 AM]
a quick pack this past weekend by luv2rip-fvp
[May 19, 2021, 02:33:19 AM]
Didn't make it over the branch by luv2rip-fvp
[May 05, 2021, 01:23:46 AM]
Help required. Standalone FPV camera by FPVSteve
[April 22, 2021, 10:18:07 PM]
Wassssup from Kent by Drone 5
[April 20, 2021, 10:48:16 PM]
I forgot I had these props by luv2rip-fvp
[April 19, 2021, 03:02:31 AM]
* Keywords
fpvhub  fpv hub
* Disclaimer
