FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 188
  • Dot Hidden: 0
  • Dot Users: 0
* Site Sponsor
* Random Gallery Items
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
DSCF6004
Posted by: [email protected]
in: Stuff
The Donny Incident!
Posted by: ROVguy
in: ROVguys Album
easy2
Posted by: munkyboy
in: Pauls Stuff
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Author Topic: Storm OSD with Frsky L9R in Taranis  (Read 3198 times)
helimadness
  • Wing Commander
  • Offline Offline
« on: April 12, 2015, 07:35:59 AM »
Hi All
Going to get a Taranis and looking at receiver options. The L9R seems to get amazing range but the manual says the RX fail safe doesn't work with Taranis. So that would mean you couldn't get the RTH to work on loss of signal for the Storm. Is that correct? Is there a work around for this problem.
Logged
chris-s
  • Group Captain
  • Offline Offline
Re: Storm OSD with Frsky L9R in Taranis
« Reply #1 on: April 12, 2015, 09:38:34 AM »
Are you sure about that? The failsafe settings are something you set on the receiver and doesn't really have anything to do with tx side.
How does the storm recognise a failsafe situation?
I've got an l9r nib, will go test this with my lads Taranis now.
Chris
Logged
chris-s
  • Group Captain
  • Offline Offline
« Reply #2 on: April 12, 2015, 09:50:32 AM »
As expected, it seems to work fine. I put a servo on the throttle channel (any will do) set its failsafe position, moved the relevant tx stick, turned off the taranis and the servo moved to its failsafe position.
Chris
Logged
  • FPVHub Troll
  • Air Chief Marshal
  • Offline Offline
« Reply #3 on: April 12, 2015, 11:02:31 AM »
helimadness. the Storm OSD doesn't care what RX is plugged into it... it's effectively "dumb" and does what it's told.
If you set your failsafe to send a certain pulse width down a certain channel, then that's what will happen.
For Storm OSD, you program a switch on your tx to turn it into RTH mode. You simply set the failsafe on your tx to flick this switch to the RTH position.
Logged
  • Global Moderator
  • Air Vice-Marshal
  • Offline Offline
  • Brought to you by Google
    • My YouTube page
« Reply #4 on: April 12, 2015, 11:12:01 AM »
I've got an LR9 in my Bixler running the Storm and have a Tarnis and the failsafe works fine.  I seem to remember the manual being confusing about this.  I don't know (or remember) if you don't set it from the Tarnis like you can on the X series, or you have to press the button on the rx like the older rx's.  But it most definately works.
  • FPVHub Troll
  • Air Chief Marshal
  • Offline Offline
« Reply #5 on: April 12, 2015, 11:17:28 AM »
Yes, the frsky receivers I've had all need to have a button pressed on the receiver as part of the failsafe setting procedure.
with EzUHF it's dead easy, pop your tx in the state you want and hold down the failsafe button on the tx module.
Logged
helimadness
  • Wing Commander
  • Offline Offline
« Reply #6 on: April 12, 2015, 02:15:57 PM »
Hi All.
Thanks for the help. I have set the Failsafe up on the storm using my JRXG 7 and works fine. So understand the process.
Just the L9R manual is a little confusing. Had this highlighted in red.
"L9R Receiver is not support failsafe setting on Taranis X9D transmitter"
but apparently read else where that it is just bad wording and means you cant set fail safe from the transmitter it has to be set on the RX.
So looks like all good.
Right back to that shopping cart to click the checkout button :-)
Logged
* Recent Topics
My midlife crisis purchase and a quick rip! by luv2rip-fvp
[Yesterday at 11:38:22 PM]
Well, I registered by ched
220mph Proximity by FPVSteve
* Keywords
fpvhub  fpv hub
* Disclaimer
