  • Dot Guests: 173
  • Dot Users: 3
airwolf hummingbird
Posted by: mattydred
in: my other rc helis
DLG (Propper FLying)
Posted by: mp66
in: Some of my models
X8 Stickered up
Ubec and FPV Equipment
MkII Back
Posted by: wgt40w
in: Ground Station Mk II
IMAG0786
Ground Station
IMAG0165
zeroG Raptor
Pages: 1 ... 8 9 [10] 11 12
Author Topic: Omnibus F4 Autopilot...iNAV....Fixed Wing.  (Read 19742 times)
  • Nothing works !!
  • I'm not deaf just thinking
« Reply #135 on: February 10, 2018, 09:42:38 AM »
He died in a motorcycle accident. His family decided to leave his videos on you tube as a memorial.
Re: Omnibus F4 Autopilot...iNAV....Fixed Wing.
« Reply #136 on: February 10, 2018, 02:57:16 PM »
  Oh, no...Thats so tragic....So young....He seemed like a nice Guy..:(
« Last Edit: February 17, 2018, 11:23:43 AM by Coyote »
Schalonsus
  • Flight Lieutenant
« Reply #137 on: February 14, 2018, 10:05:03 AM »
For all that like the iNav boards but prefere the Ardupilot code....
https://www.rcgroups.com/forums/showthread.php?2784349-Ardupilot-on-OpenPilot-Revolution
  • Nothing works !!
« Reply #138 on: February 16, 2018, 08:26:47 PM »
Really nice result today. Zeroed tx trims and flew st 60% throttle in pass through/servo autotune, landed disarmed. Then flew in horizon and autotune mode, landed and saved to eprom,(sticks down and out). Major change in handling, s800 quite nice to fly now. Further test of rth, loiter and alt  hold, showed up several more tuning issues to do, nothing major, increase circle diameter, decrease climb angle, decrease rth throttle a bit and rth height.  I really donít like the stodgy feeling of horizon mode on this wing. Big stick movement needed to initiate a turn then it bangs in, slightest relax on the stick and it whips back to level. Itís like having -30 expo on a Futaba tx. More tuning work needed.
For pilots following this thread in the future to come: Discovered that alt hold on its own doesnít manage the throttle, with horizon and alt hold together throttle is managed but closing the throttle will turn motor off!!!  Disconnecting the M8N compass has resulted in a much quicker 3D lock.
« Reply #139 on: February 17, 2018, 01:42:40 PM »
 Hi Mate,
              Oh, good...sounds like you are getting there..You need to type in that line of code to prevent the board disarming sounds like...If gliding, motor off for more than five seconds?
  Good, you disconnected the Compass....at last.....20 Sats....You dont need it!!!
  Surprised Horizon still feels soggy on ailerons..?..Rate curve inside iNAV maybe..?
  • Nothing works !!
« Reply #140 on: February 17, 2018, 04:05:53 PM »
I am going through the wiki cli codes to see if I have missed something.
« Reply #141 on: February 17, 2018, 05:38:18 PM »
 Hi Big T,
                Make sure you have this line of code in the CLI.
 If you intend to glide for more than 10 seconds, in iNav 1.6 & 1.7 it's suggested that you also set this value, so that the model doesn't "failsafe" by itself when using zero throttle during a glide:
set failsafe_throttle_low_delay = 0
  This line is kind of important...I can't even imagine why its not in as a default line of code, but heyho..?
  • Nothing works !!
« Reply #142 on: February 17, 2018, 08:00:41 PM »
Yes cheers for that, it was and is in the cli. Are you using ezuhf? If so is it possible to get ppm out of the ezuhf?  Got the chance of a cheap module for the Taranis and I already have a 8 channel rx that I use in one of the Tonka FPV trucks.
« Reply #143 on: February 17, 2018, 08:27:50 PM »
 Hi Mate,
               Yes, Im using the EZ in my Falcon now...Yes, you can programme the recievers to give a PPM stream only, but not SBUS. Remember, you will need to remove the SBUS jumper from the FC to get it to work (scalpel is what I use)
 You can kind of get a decent RSSI too by selecting "Link Quality" and assigning to a specific channel. This should give a full strength signal of around 78% at close range even on Lo TX output power. It will not increase if you go to Hi power.
  It works pretty well, and I only need to use Lo power with a Dipole on my RX and the SR771 on my TX.
 Regarding your "soggy" Aileron response in Horizon, try setting Air Mode to permanently ON. in iNAV..?
  • Nothing works !!
« Reply #144 on: February 17, 2018, 08:58:28 PM »
Airmode is/was on. I think itís in the cli somewhere. Anyhoo onward and upward. If this weather holds I am digging out one of my 30% CAPS for some quality LOS flying. If this weather breaks then who knows.
« Reply #145 on: February 18, 2018, 11:48:52 AM »
Hi Big T,
 Maybe you should consider switching Air Mode off then, its a Multi Rotor Mode....? I never use it.
  I was looking at my PIDs on the Falcon last night, I only have a value of 2 for Roll and Pitch...On my P gains.
So, in manual Mode, I have about 10mm up and 8mm down...but in Horizon Mode, if I bank the plane to 45 deg I only see about 3 to 4mm of Elevon deflection. This is enough to stabilise when flying around in Horizon, but I can override it easily if I want to.
 I think the key to setting up is to test the models surface deflections in your hand whilst in Horizon Mode and to ensure you dont have too much surface deflection.
  Remember, when in GPS Modes like RTL and FS and ALT Hold...It will utilise preset bank angles, climb, dive....so the deflections are not relevant, but the angles are.
 If your motor turned off mid flight, you must have switched off / disarmed the board...?
  • Nothing works !!
« Reply #146 on: February 18, 2018, 02:48:37 PM »
No the motor didnít go ďoffĒ, it was that I was surprised that it responded to the throttle command in RTH when I closed the throttle to minimum.
Schalonsus
  • Flight Lieutenant
« Reply #147 on: February 18, 2018, 04:28:44 PM »
In RTH throttle is controlled manual, in Failsafe throttle is controlled by FC.
You should have Airmode always enabled, it is a mode for planes too. If zero throttle without air mode you have a lot less stabilisation...
  • Nothing works !!
« Reply #148 on: February 18, 2018, 07:09:32 PM »
Well I dont like to contradict as I am a noob with this but on mine the throttle is controlled by the FC in RTH. However I do have a bigger issue with RTH. Today I was fine tuning horizon and RTH behavior. I had some very alarming RTH semi fails that dont give me any confidence at the moment.
 What happens is that RTH was engaged about 150 meters out downwind at about 40 meters alt. The model starts to slowly turn and gets on a home heading, the throttle  is increased to the set percentage and the model starts to climb to 70 meters. Then the model sort of falls off the heading and starts to fly away down wind. The first few times I took over and flew it back, then I decided to let it go and see what happened. Which was when it was almost too far away for me to orient it, it started a very slow right turn to get back on home heading. It was alarming as I thought I had a flyaway in not very good light.
Second issue is that the  loiter circle around home does not put home in the center and pos hold is the same. Not centerd.
Third issue is that I have now got full control of roll in Horizon but if I try to loop the FC takes over at the top of the loop and rolls me out.
« Reply #149 on: February 18, 2018, 08:28:23 PM »
 Hi mate,
               Yes, my experience with RTH is that iNAV works the throttle when needed.
 I think inside iNAV, there is a minimum distance from Home you can engage RTH...You engaged RTH at only 100 mtrs out...that's too close....and that loitering in a figure of eight kind of way..? has happened to me as well....I think the Loiter radius is simply too small myself, what have you set it to?...It looks like 50 mtrs to me watching that clip....too small.
 Sounds like you were doing all this stuff LOS..?...How can you tell exactly what's going on LOS?
 In RTH, you need enough power to match the climb out angle you have chosen, and also the bank angle has an effect too. The fact it struggles to turn means you have set it incorrectly or there is insufficient Elevon movement to make it happen.?
 Its set the opposite of my Falcon, the RTH is, if anything quite agressive, immediate 45 deg bank angle with a 20 deg climb and a bucket full of throttle. As I said, I have quite a bit of movement in manual set on mine, in fact it's a bit of a handful in pass mode TBH.
 As soon as Horizon is engaged, it becomes a different beast, flies level and is tamed around mid stick due to the RC rate curve you can set in iNAV. Engage a GPS Mode and there is enough throw to make it respond very fast, the opposite of what you describe. I think you dont have enough throws on this plane now..?
 Suddenly, you have full control in Horizon Mode...?...hmm...why is that then?.....
 If you want to do Acro...engage Acro Mode, or Pass Mode.... not Horizon?
  I think it's behaving normally, but the control throws are not enough when a GPS Mode is engaged. This is where the rate curve in iNAV comes into play. Do not put any curves or rates in your TX. It's all a matter of how you set it up, like all FCs TBH.
 Turn off your Foxeer Cameras OSD.
« Last Edit: February 18, 2018, 08:41:24 PM by English Turbines »
Optical receiver / optical transmitter and optical transceiver by Annaa
[Today at 05:57:17 AM]
video editing software suggestions? by badger
[Today at 12:13:22 AM]
drop it like its hot - betaflight Q by discus.fly
[Yesterday at 08:46:51 PM]
E.T.s Z84...iNAV 2.0 and Eachine DVR Testing by English Turbines
[Yesterday at 04:46:56 PM]
FLY ANGRY by Lamaule
[Yesterday at 11:16:16 AM]
Evening Rip with wings and hay-bales by urbanfpv
[August 13, 2018, 04:13:07 PM]
E-wings - a new UK based EPP wing manufacturer by iwan_canobi
[August 13, 2018, 11:19:35 AM]
[August 12, 2018, 06:49:02 PM]
Mini Talon FPV Flight by Drone 5
[August 12, 2018, 05:14:30 PM]
I think I'm done... by Billy_boy_2010
[August 12, 2018, 09:38:16 AM]
Please tell us what is a modular power supply? Emergency help by Coyote
[August 11, 2018, 10:08:18 PM]
Hi folks by Coyote
[August 11, 2018, 10:04:37 PM]
Schoolís out... by elmattbo
[August 09, 2018, 09:22:39 PM]
What do you think about my build list? by ched
[August 09, 2018, 06:43:11 PM]
Saying hello by curlypaul
[August 07, 2018, 02:33:30 PM]
