  • Dot Guests: 184
  • Dot Users: 2
DSCF6005
Posted by: [email protected]
in: Stuff
its glued together...
Posted by: MarkLincs
in: Scout Bee
ASW-28 Build
Me 1
IMAG0786
Ground Station
IMAG0165
zeroG Raptor
Author Topic: Sbus testing  (Read 1311 times)
Dave
  • Let there be Flight....
    • F.P.heaVen
Sbus testing
« on: February 12, 2018, 11:34:36 AM »
Is there any way to test the Sbus output of a receiver without connecting it to a flight controller?
I have an X8R bound to a QX7 and fitted to a ViFly R220 M2. When I plug it into Betaflight I see no stick movement.
The quad is known working, Ive seen it fly. The TX is known working, Ive flown with it. The RX is brand new so SHOULD be ok but its the only thing I cant test as I don't have flight controller that's not fitted to a quad to test it with, hence my question above.
Ive tried all available Uarts and its definitely set to use an Sbus receiver.
Any ideas?
WWW.FPHEAVEN.CO.UK
Re: Sbus testing
« Reply #1 on: February 12, 2018, 08:41:10 PM »
Any ideas?
 First thing I would try, is to plug some servos into it and test to see if it really is bound like you think it is....especially if you are running LBT Firmware.
  • Nothing works !!
  • I'm not deaf just thinking
Re: Sbus testing
« Reply #2 on: February 13, 2018, 10:20:55 AM »
Cqn you do a screen shot of the Ports page and the Rx section of the Config page?
Dave
    • F.P.heaVen
Re: Sbus testing
« Reply #3 on: February 13, 2018, 03:36:20 PM »
Ive done that and buzzes the servos round quite happily :)
WWW.FPHEAVEN.CO.UK
Dave
    • F.P.heaVen
Re: Sbus testing
« Reply #4 on: February 13, 2018, 03:43:20 PM »
All set up as per Vifly instructions and confirmed with vifly themselves. Ive also sent them pics of the wiring....heard nothing from them since :(
I have tried the other uarts as suggested by Vifly support.
WWW.FPHEAVEN.CO.UK
Dave
    • F.P.heaVen
Re: Sbus testing
« Reply #5 on: February 13, 2018, 03:53:45 PM »
About thirty seconds after posting above, I got a reply from Vifly.
They are as flumoxed as I am (?)
WWW.FPHEAVEN.CO.UK
fpsazerbaijan
  • Officially Addicted.
    • My Youtube Channel
Re: Sbus testing
« Reply #6 on: February 14, 2018, 08:38:49 PM »
Might be completely wrong here but on my F4 board I had to solder the Sbus jumper pin to get it working with iNav
Re: Sbus testing
« Reply #7 on: February 18, 2018, 11:57:18 AM »
  On my Omnibus F4 board, which is a V1 type, BOTH jumpers are already on the board.
 Specifically, both PPM and SBUS jumpers are present....(unlike the FC in the above video)
 So, if you want to use SBUS, you need do nothing at all, but if you want to use PPM, you will have to prize off the SBUS jumper.
This I would suggest, is because most users are using SBUS systems, unlike the EZUHF RX which uses old fashioned PPM for example, but you can make either type work.
« Last Edit: February 18, 2018, 11:59:23 AM by English Turbines »
Dave
    • F.P.heaVen
Re: Sbus testing
« Reply #8 on: February 21, 2018, 11:34:20 AM »
Trouble is, its not a full size board. It looks like a custom one as it joins the rest of the electronics with a single ribbon cable.
I can only see one side of it as its stuck to the bottom plate but there don't appear to be jumpers on it.
WWW.FPHEAVEN.CO.UK
Re: Sbus testing
« Reply #9 on: February 21, 2018, 04:56:31 PM »
 If you are using a Frsky reciever, the SBUS is inverted, so I would check it can handle the inverted signal...?
I think I'm done... by Steve W
[Today at 12:28:11 PM]
I got to see what my own flying looks like! by luv2rip-fvp
[Today at 02:22:15 AM]
Manage to make it through the bars by luv2rip-fvp
[Today at 02:19:45 AM]
Frsky radio advice by English Turbines
[August 16, 2018, 11:49:00 AM]
drop it like its hot - betaflight Q by The flying cat
[August 16, 2018, 11:00:28 AM]
Better Bungee Required by Coyote
[August 15, 2018, 01:21:25 PM]
video editing software suggestions? by BigT
[August 15, 2018, 11:42:46 AM]
E.T.s Z84...iNAV 2.0 and Eachine DVR Testing by English Turbines
[August 14, 2018, 04:46:56 PM]
FLY ANGRY by Lamaule
[August 14, 2018, 11:16:16 AM]
Evening Rip with wings and hay-bales by urbanfpv
[August 13, 2018, 04:13:07 PM]
E-wings - a new UK based EPP wing manufacturer by iwan_canobi
[August 13, 2018, 11:19:35 AM]
Mini Talon FPV Flight by Drone 5
[August 12, 2018, 05:14:30 PM]
Hi folks by Coyote
[August 11, 2018, 10:04:37 PM]
School’s out... by elmattbo
[August 09, 2018, 09:22:39 PM]
What do you think about my build list? by ched
[August 09, 2018, 06:43:11 PM]
