FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 163
  • Dot Hidden: 0
  • Dot Users: 1
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
Landing Gear 3
Posted by: ROVguy
in: ROVguys Album
BODEGA
Posted by: COKE32
in: FPV SPAIN
Organised chaos
Posted by: ROVguy
in: ROVguys Album
aef
Posted by: [email protected]
in: Stuff
DSCF6005
in: Stuff
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Author Topic: DAL RC OSD cuts in and on DVR but not goggles  (Read 1941 times)
Sgt Bigglesworth
  • Flying officer
  • Offline Offline
« on: June 06, 2018, 05:05:06 PM »
This is a bit of a weird problem.
I'm using a DAL RC OSD and it's perfect in the goggles.
I use an Archos 700 to record the flight on my ground station.
The weird thing is that the OSD is constant and OK in the goggles but cuts in and out on my Archos. The video is fine in the Archos, just the OSD that is there one minute, a quick video glitch and it goes, another video glitch and it's back again. This problem is not evident in the goggles.
The Archos has an auto detect PAL/NTSC that can't be disarmed. Could it be that?
The Archos records video and OSD perfectly on my other plane which uses Eagle tree OSD - no problems with OSD cutting in and out on the Archos with that set up.
Logged
  • Global Moderator
  • Air Vice-Marshal
  • Offline Offline
  • Brought to you by Google
    • My YouTube page
Re: DAL RC OSD cuts in and on DVR but not goggles
« Reply #1 on: June 06, 2018, 05:31:50 PM »
I used to get this ages ago with the Pigeon OSD - if you look at this ancient video from about 4m20s you'll see the static knock the OSD from the recording (this was on a JapanFPV style DVR)
! No longer available
I did find it was a PAL/NTSC thing for the Pigeon, where a later version fixed it.  If you are unable to set PAL/NTSC, perhaps you could swap the camera for the opposite standard of what it currently is to see if that fixes it.
Sgt Bigglesworth
  • Flying officer
  • Offline Offline
« Reply #2 on: June 06, 2018, 08:42:32 PM »
Thanks CurryKitten,
Sounds like a similar problem, just weird that I can use the Archos on my other set up and the problem disappears.
I'll try another camera and see if that sorts it out.
Thanks again
Logged
Sgt Bigglesworth
  • Flying officer
  • Offline Offline
« Reply #3 on: June 09, 2018, 11:44:06 AM »
Tried a different camera - lo and behold - problem has gone. Good call currykitten!
Logged
* Recent Topics
Well, I registered by ched
220mph Proximity by FPVSteve
The Lego quadcopter by Coyote
[January 22, 2020, 08:46:19 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
