  • Dot Guests: 164
Imagen023
Posted by: COKE32
in: FPV SPAIN
Receiver 2
Me 1
Braunton Burrows
Posted by: Macsgrafs
in: Aerial photography
easy3
Posted by: munkyboy
in: Pauls Stuff
Author Topic: Modifying Frsky R9 antennas  (Read 1396 times)
« on: October 30, 2018, 06:37:19 PM »
Hi guys
Out the box the Frsky R9MM antennas and most the other receiver antennas are really poor. There are lots of arguments over the antennas lengths but really fractions of a mm or a mm or so aren't going to half your range the antenna being fractions out will only reduce the maximum potential range.
So with that said what's all the problems with them then ?
Well the main problem is the way the user is installing them, totally incorrectly on the likes of a mini quad rendering the antenna pretty useless against the carbon. Others are putting them alongside signal blocking lipos etc.
The other main issue with them is the position they are in when they are installed, the antennas are Dipoles so should be installed at 90 degrees to the feed point and inline with each other. They do not come like that though so this is where a lot of issues are coming about.
If you have a 3D printer handy, or at least someone with one that has 6 mins to spare here is the easiest way of fixing them :) This technique can also be used with other frequency antennas and not just limited to 868MHz
First what do we need ?
  • Snips
  • RC antenna tube
  • Heat shrink Tubing
  • Soldering Iron
  • Printed Immortal T copy
Cut the antenna tubes to length so they cover both elements and a portion of the feed wire.
Then desolder the black wire to enable you to push the antenna tube over the whole antenna to the rear.
Solder the black wire back on again as close to the split point as possible.
Put the other two tubes over the elements and cover the inner ends in UHU Por and leave to go tacky.
Then apply UHU Por to the printed T parts and again leave to go tacky.
Once tacky lay the tubes inside and bring together the two T parts, the Por will now hold the antenna together. Cut the heat shrink to the required length and slip over the antenna tubes, heat and they will hold the antenna together while the glue dries and trim the antenna off nicely.
I uncoupled the UFL connector on mine and slipped a piece over the feen end to neaten that bit up as well.
Done !
Your antenna is now in its must optimal configuration and is easier to install ( Properly positioned :) )
Re: Modifying Frsky R9 antennas
« Reply #1 on: October 30, 2018, 06:56:31 PM »
Nice job Ian...
                       Does Trappy know you have stolen his "Immortal Tee" antenna..?
                        AKA a Dipole....lol.
  That 868mhz Moxon for the TX should be epic with this.
« Reply #2 on: December 29, 2018, 03:15:31 PM »
It's a simple enough principle, make the loose wires as straight as possible to get the best out of them :)
The lengths should be 77mm I had forgot to put in the post also.
« Reply #3 on: December 29, 2018, 07:50:08 PM »
  The interesting thing is, on that recent UAV Futures Video, he was using tubular sleeved Dipoles on his diversity receiver.
  A 90 degree push connector and this arrangement has to be a good idea from an install point of view on a Fixed Wing, not so clever on a Mini Quad for sure.
  So, how important is the 90 degree feed wire in the case of the "Tee Antenna"...?
« Reply #4 on: December 29, 2018, 07:59:35 PM »
In an ideal world it wants to be 90 degrees at the feed point, if it runs along side the element it will of course be blocking some of the signal so its not ideal at all.
The best approach for quads is a Sleeved Dipole which is great for mounting but does not incur any of the losses from the coax being in the way as instead it is inside the sleeve.
« Reply #5 on: December 29, 2018, 08:11:39 PM »
 Ah, yes of course the sleeve surrounds the feed cable...never thought of it like that, I thought it was just the active part which did the receiving..
  Be interesting to make one and try it, just need some 2mm brass tubing i think...?
« Reply #6 on: December 29, 2018, 08:19:47 PM »
You can buy them from TBS already made, and very well made they are too. You do though get them in SMA format only so on a receiver you would need a U.F.L to SMA adaptor so it could mount to the frame.
I have placed an order for a few a few days back.
From there though they are everything but cheap :)
Sleeved straight Dipole $19.95 + Shipping
Or with an angled SMA ( least preferred )
90 degree Sleeved Dipole $19.95 + Shipping
How I miss good old Bignose13 with his antenna prices :(
« Reply #7 on: December 29, 2018, 08:25:37 PM »
  Yeah, I was thinking for the receiver though, those are Transmitter Dipoles...?
  In the video, he clearly has sleeved Dipoles on his receiver..
  Ah, found them, the RX pair also have 90 deg SMA connectors on them....
« Last Edit: December 29, 2018, 08:28:41 PM by English Turbines »
« Reply #8 on: December 29, 2018, 08:31:04 PM »
There is no operational difference between transmitter antennas and receiver, same thing, they can be used on either end. However the transmitters are SMA and Receivers not so you need the SMA to IPEX patch cable to use them.
My midlife crisis purchase and a quick rip! by luv2rip-fvp
[Yesterday at 11:38:22 PM]
Well, I registered by ched
[February 20, 2020, 08:51:38 PM]
Took Mark's S900 out for a test! by luv2rip-fvp
[February 17, 2020, 03:22:39 PM]
I'm (attempting) to make a free FPV quad sim by ched
[February 14, 2020, 11:11:38 PM]
PPM/PWM to SBUS converter? by ched
[February 08, 2020, 09:54:15 PM]
220mph Proximity by FPVSteve
[February 07, 2020, 12:51:32 PM]
Matek f405 wing and frsky l9r rssi setup by Brandon1
[February 04, 2020, 11:30:10 PM]
FrSky and ACCST 2.0 - DANGER by ORCA
[February 03, 2020, 08:50:44 PM]
My 1st rip of 2020! by luv2rip-fvp
[February 02, 2020, 07:12:36 PM]
recommend me a quad to learn on by badger
[February 01, 2020, 11:27:05 PM]
