  • Dot Guests: 108
its glued together...
Posted by: MarkLincs
in: Scout Bee
The begining
ASW-28 Build
Folded Up
Braunton Burrows
Posted by: Macsgrafs
in: Aerial photography
Pages: [1] 2
Author Topic: FlyBot Flux build thread  (Read 1530 times)
  • Global Moderator
  • Air Vice-Marshal
  • Brought to you by Google
    • My YouTube page
« on: December 04, 2018, 09:19:41 PM »
I've just got hold of a Flux wing, so here's a build thread.  I've not done anything as I write this, but thought I'd grab some photos whilst I was checking out the box contents so I could record it somewhere while I go.
This is the Flux wing https://flybot.de/en/flux-fpv-freestyle-wing it's similar in the design concept to the MiniRaceWing that I flew before.  The big difference in these over regular wings is that the main fuse is made from 2 carbon plates with risers - almost exactly like a quad frame. But it goes a little further in how the wings are held on - they use these plates that will allow the wings to pop off in a crash making it quite difficult to actually damage.
I know this because I have thrown the MiniRaceWing into the ground about 20 times.  For me, it was somewhat of a pain to launch - it needs a proper throw, not my usual hold-onto-one-wing-and-toss-it malarky.  The Flux is supposed to be easier to handle and launch - we'll see !
So I've just taken the kits out of the box and so laid out the contents to get some snaps - here are the wings and winglets, with apologies for the picture.  I can either get not enough light onto this, or the wings reflect all the light and look odd
The next picture is of everything else in the box (except for the decal sheet as I forgot that - but y'know, decals - you've seen them before) here we have the elevons the frame parts, motor mount, push rods etc etc
As to what I'm going to put in there, to save time and money I'm probably going to raid the MiniRaceWing and steal it's power setup (T-Motor F80  2500kv, 60A Skywalker ESC and a Graupner 5.5x5.5 speed prop), and maybe the camera/VTX - not sure yet.  What I don't have right now is any decent metal geared servos, so I've got a few on order from Banggood.
There's quite a nice PDF manual available here https://flybot.de/media/pdf/15/08/a7/FLUX_Manual_EN.pdf if you want to see what I'm going to do next.  For starters I'll glue in the wing spars ready and put the frame part togather just so I can have a look at it.
Re: FlyBot Flux build thread
« Reply #1 on: December 04, 2018, 10:35:50 PM »
Interesting concept as is the MiniRaceWing which I can't remember seeing many video's from it though, did you not get the time on it or did it fall short of expectations ? How do you think this one will surpass it ?
  • Global Moderator
  • Air Vice-Marshal
    • My YouTube page
« Reply #2 on: December 05, 2018, 12:06:02 AM »
I Did a bunch of flights on it at a meet where very disappointingly, my HD camera recording 4 seconds instead of the 40 minutes of flying, so I didn't post up much, and aside from that I'd got caught up in lots of other stuff.  The plan was always to go back and get the hang of throwing it, but I do have lots of stuff that I always have on the to-do list and I don't get very far down that list mostly because of new things appearing.
I've just glued the spars in and put the central fuse part together, so ther'es a few differences that can be seen.  The wing in the new Flux is slightly thicker - so perhaps that will generate a bit more list and make it easier to launch.  The fuse it structured really very differently indeed... hold on, I'm going to take a few pics
What you can see in that picture is the MRW Fuse top, and the FLux fuse below.  The MRW is very low profile and opens out at the camera section.  It's motor mount was adjustable so you could adjust how far the carbon tube went into get your CG where you wanted it.
So the Flux loses that flexibility, but what we get instead is more space inside the fuse section, and a simple motor mount at the rear.  There are a lot more pre-drilled holes that let you mount full sized/micro cameras, regular flight controller stacks, or micro ones.  Basically there is more space - which is good for me as I am not the cleanest builder !
Here's a picture of the carbon spars glued in.  It's the two that protrude out that break away in a crash. (you can see the bits they connect into just underneath the main fuse part.
...and finally here's a pic comparing the wing profiles of the Flux (bottom) and the MRW (top) You can see how the Flux's wing is more substantial.  They both have the same mountings though, so I would fly either models with either wings !
  • Global Moderator
  • Air Vice-Marshal
    • My YouTube page
« Reply #3 on: December 05, 2018, 10:31:01 AM »
Since the glue was dry, I quickly attached the wings and put the winglets on so I could have a quick comparison to the MRW.  I like the curve of the Flux :)
I decided to order a new ESC for the Flux, as the MRW already has a bunch of wiring coming off and I do want to keep flying that one.  I shall probably still borrow the motor from it, but I've got a spare flight controller, VTX & camera so the rest is sorted.  What do you guys think about me trying an R9MM in there?
FlyingRock
  • Squadron Leader
« Reply #4 on: December 05, 2018, 11:42:54 AM »
Great comparison shots CK, thanks for posting!
« Reply #5 on: December 05, 2018, 08:29:03 PM »
Remarkably similar in wing design.
HerkyBird
  • Squadron Leader
« Reply #6 on: December 05, 2018, 10:20:12 PM »
Are the carbon spars the same distance apart between the 2 models by any chance Wayne? I'm wondering as it would be great to be able to get a set of flux wings to go with my MiniRaceWing fuz!
  • Global Moderator
  • Air Vice-Marshal
    • My YouTube page
« Reply #7 on: December 05, 2018, 11:05:42 PM »
They are indeed - the wings would be totally swappable
HerkyBird
  • Squadron Leader
« Reply #8 on: December 06, 2018, 12:48:05 AM »
Great news thanks Wayne, I'll have to see if I can get hold of a set of spare wings then...
Schalonsus
  • Flight Lieutenant
« Reply #9 on: December 10, 2018, 02:17:33 AM »
If you have problems starting, try half throttle. That's enough to get it going and it won't torque. Also try to throw level, not upwards.
I fly a Flux too, its a bit calmer to fly as the MiniRaceWing and i like the bigger electronics bay, much easier installation.
Loopdreams
« Reply #10 on: December 10, 2018, 08:36:57 AM »
If I had a pound for every FPVer moaning about some plane or other being difficult to launch and then you see them throwing them up at 45 degrees into an immediate stall then I'd probably have six or seven pounds by now!
    • DroneFinder
« Reply #11 on: December 10, 2018, 09:44:59 AM »
"throwing" is very questionable half the time too ... Mr Burns would be proud.
  • Global Moderator
  • Air Vice-Marshal
    • My YouTube page
« Reply #12 on: December 12, 2018, 08:07:04 PM »
It's definitely my throw - if I get someone else to do a two-handed over the head toss then it's up without a problem.  I got so used to a single wing toss on a lighter wing that would just go.
But anyhow, hopefully I'll do better.  I've just stuck up a quite video to go through what's in the box and some comparison pics as well
Sorry...
    • DroneFinder
« Reply #13 on: December 13, 2018, 12:11:33 AM »
Funnily enough I can't do side launches even with the z84, I tend to chuck it overarm then throttle on as there's very little clearance between fingers + prop
  • Global Moderator
  • Air Vice-Marshal
    • My YouTube page
« Reply #14 on: February 07, 2019, 12:59:22 AM »
Right then, crappy weather lately has moved the build forwards - although I'm sure I took some more pictures, but appear to have lost them somehow... oops
Actually, this might be the picture I thought I'd lost.  So what I did first it use clear tape over the elevons to protect the raw balsa (I think the one on the left is uncovered and the right is.. maybe)  The control surface was then taped into place on the wing and the control horns glued into place.
The push rods that were included in the kit were too long by quite a margin and had to be cut down to the specified length.  I presume these are just off the shelf components and that's how they come.
Once at the right length the ball joints were added with a guestimate of how long they should be, but with one side threaded it means the adjustments are pretty easy
Started on the servos next, and as per usual the screws to hold the ball joints are way bigger than the normal holes, so I used a scalpel blade to open up the hole wide enough.
The pre-cut servo holes were just a little short for the TowerPro servos I was using, so I needed the scalpel again to remove a little bit of foam
I centered the servo's, sorted out the pushrod lengths, and glued in place
Lastly, more tape was added, over the leading edge, the servo wires and a few other places as per the manual before adding the decals.  Wings finished !
Pages: [1] 2
E.T.s Martian 2 Hack up with Betaflight and GPS by Coyote
[June 14, 2019, 11:48:06 PM]
Low by Coyote
[June 14, 2019, 11:40:58 PM]
Canyon by Lamaule
[June 14, 2019, 09:16:44 PM]
Some more flow! by luv2rip-fvp
[June 14, 2019, 04:14:28 AM]
Flying FPV and the compulsory Observer rules. by ched
[June 13, 2019, 12:36:51 PM]
E.T.s Stingy X5 Quad...Learning Air Mode. by ched
[June 11, 2019, 05:10:59 PM]
A close call! by luv2rip-fvp
[June 10, 2019, 02:11:07 AM]
Bando Blat by urbanfpv
[June 09, 2019, 08:49:33 PM]
Amazon Drone Deliveries by ched
[June 07, 2019, 05:17:40 PM]
New UK Drones Law punishes British Model Flying Community by The flying cat
[June 07, 2019, 11:03:06 AM]
