FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 146
  • Dot Hidden: 0
  • Dot Users: 1
  • Dot Users Online:
* Site Sponsor
* Random Gallery Items
Side View
Posted by: Coyote
in: Coyote`s Album
The begining
Posted by: Coyote
in: Coyote`s Album
tri 4
Posted by: [email protected]
in: Tricopter
revenge is sweet
Posted by: mattydred
in: f27c stryker
3dbi omni
Posted by: Coyote
in: Coyote`s Album
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Author Topic: Effect of using adapters and bending the co-ax cable  (Read 2856 times)
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
« on: February 08, 2019, 03:19:54 PM »
As Painless360 and Menace RC continue the lab testing series this is of particular interest to me.
Most surprising was the huge losses RG316 gave, made me rethink a few things in my builds, changes will be made !
Logged
urbanfpv
  • Flight Lieutenant
  • Offline Offline
Re: Effect of using adapters and bending the co-ax cable
« Reply #1 on: February 08, 2019, 04:12:29 PM »
Just watched this.  I'd recently changed to using 90 degree adapters on my goggles as well!  I've now ordered some 45 degree ones to replace them.  :laugh:
However,  I think the use of angled adapters is generally better - especially if you know you dip your head while flying.  If you're using a helical antenna, the gain with having the antenna pointed horizontal to upwards must be far greater than having it pointing or drooping towards the ground and offsets the loss due to the adapter to some extent.
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
« Reply #2 on: February 08, 2019, 04:45:58 PM »
Its made me think about a few things, and yes the Helical was one of the first that sprung to mind.
My 2.4 and 5.8GHz helicals are both sporting 90 degree adaptors coming off them, which is having that much of an ill effect I think now I will change both to get all the dB back again. The antenna tracker will be harder to sort than the helicals straight onto goggles, swapping the 90 out for a bit of RG402 is very practical to do really.
Logged
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
« Reply #3 on: February 08, 2019, 05:04:46 PM »
OK so curiosity got the better of me and I went and checked just how I had my trackers antennas setup like  :
1.2GHz CP Patch :
90 degree connector to RG316 to 90 degree connector
Now this is 1.2GHz so I can't really use the losses mentioned in the video and the 1.2 frequency is well below the intended 2.4GHz use for RG316 so would I actually be incurring any / as much losses I'm unsure.
2.4GHz Helical :
Again 90 to 316 to 90
But again, it should be ok using 316 in this case as its within the spec of 316, but I'm still wondering the effects the 2 90 degree connector will be having on it.
In both cases though, a simple swap out for a length of RG402 isn't quite as easy and practical as it would first appear with the antennas SMA being where they are in the first place.
So now I'm thinking, are the losses on the lower frequencies that large to warrant going to all the effort, or in fact on the lower frequencies are they small enough to be negligible.
Logged
* Recent Topics
Well, I registered by ched
220mph Proximity by FPVSteve
The Lego quadcopter by Coyote
[January 22, 2020, 08:46:19 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
