  • Dot Guests: 97
Sky Surfer Maiden 2
Sky Surfer Maiden 4
Battery layout
Posted by: MarkLincs
in: Scout Bee
Hexa complete 2
Pages: 1 2 3 [4] 5
Author Topic: 220mph Proximity  (Read 4418 times)
omegooliebird
  • Flying officer
Re: 220mph Proximity
« Reply #45 on: March 06, 2020, 12:27:35 PM »
Whilst trying unsuccessfully to go to sleep last night, I formulated a very simple no servo load solution that will also be easy to print in the right orientation. I will put bearings in the sear, and possibly a roller on the end of the servo horn to really reduce any friction. It will be easy to load, and will also add a touch of tension as it is engaged into position. The position/geometry is just conceptual, will do it on Fusion later and get everything right and make a prototype. Will probably mount the elastic slightly down one arm of the hex, so it pulls the strap well out of the way. Also will have a rod that goes through the body and the sear, that will be retracted by another servo, as a safety pin...Sorry about the drawing, my art didn't ever really progress after I left primary school :-)
  • Squadron Leader
« Reply #46 on: March 06, 2020, 09:03:19 PM »
Makes sense to me. It should be nice and easy to test on the ground.
« Reply #47 on: March 12, 2020, 12:19:22 PM »
This is going to be an epic maiden :)
omegooliebird
  • Flying officer
« Reply #48 on: March 15, 2020, 11:13:17 PM »
Flew the extended arm monster hex today after totally rebuilding/rewiring it. Took every connector I could of it and re-soldered every joint just to be sure...you never know what is lurking underneath the heat-shrink..!!! It has buckets of power and is super stable, I didn't touch the gains on the Wookong, it flew perfect as it was. Crazy noise, I've actually not seen a multirotor this size fly before. Sounds intimidating!
Printed part of the release mech, but ran out of ABS filament, so waiting on more now. It is all getting pretty close... Looking forward to doing the first test drop with a Funjet.
I also realised that it will allow me to try some insane props on the electric Fusion, as the very over-square props are risky on the vert launches. So may be able to push the electric record further without spending a fortune on motors/esc's... Win-win!
I guess one plus side of this Snake-flu that is getting on top of us, is that self isolation does give one a chance to attend to some of those builds that are buried in the shed and we never had the time to get to... Maybe it will reinvigorate the build fever that used to be such a big part of the FPV community at the start.
omegooliebird
  • Flying officer
« Reply #49 on: March 18, 2020, 08:26:42 PM »
Had my record beaten today!!! First time anyone has posted a faster video for 7 years! It is a good day!!! This makes the jet project even more exciting, and puts the pressure on! He is getting a lot of hassle for it being in a steep dive at the time of the highest number, but I am happy that it is a higher number than mine got to. I am pretty sure mine is about 60kmh faster on the flat, but that is not the point, he got a higher number with plenty of sats locked:
  • Squadron Leader
« Reply #50 on: March 18, 2020, 09:50:20 PM »
Maybe there should be 2 records, 1 unlimited, the second staying within legal height limits  :D
Looking forward to your flights.
    • DroneFinder
« Reply #51 on: March 18, 2020, 11:27:16 PM »
Jeez, just a shade under 275mph is insane for a foam jet.
Interesting that he got it when the battery had been used as well so wasn't running full voltage...
Good luck Rupes!
« Last Edit: March 18, 2020, 11:29:17 PM by FPVSteve »
omegooliebird
  • Flying officer
« Reply #52 on: March 19, 2020, 01:23:24 AM »
The Omegooliebird is working hard...Things are coming along, printer has been running solid for 3 days.. Quite a bit more to do, but it's on it's feet with the bird in position..
omegooliebird
  • Flying officer
« Reply #53 on: March 19, 2020, 01:24:05 AM »
omegooliebird
  • Flying officer
« Reply #54 on: March 19, 2020, 01:24:29 AM »
  • Squadron Leader
« Reply #55 on: March 19, 2020, 02:27:33 AM »
Looks amazing.
Are you going to need a hex pilot as well as yourself to fly the jet?
omegooliebird
  • Flying officer
« Reply #56 on: March 19, 2020, 03:53:08 PM »
..the girlfriend... what can go wrong... 'just hold the left stick up until I say press the button'...DO NOT press the button otherwise.'
  • Squadron Leader
« Reply #57 on: March 19, 2020, 04:46:47 PM »
Can't you lift off the hex, get to position then hand over the tx to your girlfriend to just press the button?
Maybe there is some sort of buddy box you could setup?
Interesting, I like your project, more solutions to be found  :D
Keep up the great work while we all avoid the virus  :)
    • DroneFinder
« Reply #58 on: March 19, 2020, 11:52:53 PM »
Will the hex autoland because I imagine you'll be quite busy :D
omegooliebird
  • Flying officer
« Reply #59 on: March 20, 2020, 01:33:46 AM »
I could take the hex up leave it in position hold, put the plane goggles on and hit the release button all myself...but, there is always a chance the hex could have a failure, and if it is falling I would want to abort and drop the plane to try and get it away before it all comes crashing down... So best if I have the plane goggles on the whole way through... Actually thinking about it, I could just pilot the hex from the plane FPV system all the way up to release... that would work! I could just pull the RTH on the hex once I settled down with the plane.. It is going to be proper exciting no matter what though :-)
« Last Edit: March 20, 2020, 01:35:41 AM by omegooliebird »
Pages: 1 2 3 [4] 5
Is everyone okay? by FPVSteve
[Yesterday at 11:45:31 PM]
What's Your "I'm stuck at home" Project? by ched
[April 08, 2020, 11:54:23 PM]
Soldering help!! by ched
[April 08, 2020, 04:32:01 PM]
220mph Proximity by ched
[April 07, 2020, 10:33:51 PM]
I'm (attempting) to make a free FPV quad sim by Coyote
[April 03, 2020, 11:04:39 AM]
Brecon Beckons Part 2 by Coyote
[April 03, 2020, 10:53:06 AM]
Hi from Bracknell - Berks by evildronepilot
[April 01, 2020, 04:21:22 PM]
Advice Wanted on Getting into Telemetry by wgt40w
[March 31, 2020, 03:23:06 PM]
Killing some time inside! by luv2rip-fvp
[March 29, 2020, 04:32:59 AM]
FY-31AP v1.20 upgrade (Important firmware update) by Edkopter
[March 28, 2020, 08:48:05 PM]
