  • Dot Guests: 194
  • Dot Users: 1
Scout Bee
Posted by: MarkLincs
in: Scout Bee
py-x4
Posted by: JOMA72
in: quadcopters
Venturi almost done
Mystery motor connector!
Posted by: jon
in: Misc uploads
Author Topic: badger's Twinstar build  (Read 772 times)
badger
  • Pilot Officer
« on: September 02, 2019, 01:47:56 PM »
so I thought I'd do a build thread as I'm definitely going to need a bit of help with the FC stuff, so here goes:
MPX Twinstar
2x Turnigy D2830-11 1000kV motors
2x Turnigy Plush-32 30A speed controllers
4x Corona 929MG 12g Metal Gear servos
2x Graupner electric 8x5 props CW/CCW
4S 3Ah batteries
Matek F411-wing FC
Beitian BN-880 GPS
FrSky SBUS-capable XR-series Rx
Eachine TX526 VTx
Aomway cloverleaf antenna
mini-size camera TBD
Mobius
plus various other stuff I haven't thought of yet
it's not intended to be anything clever, just something to cruise around with, be a testbed for my first FC build, so 2.4GHz radio, 5.8GHz video, all nice & simple (& legal ;) ).
I've plugged the FC into my computer & calibrated it with the iNav Configurator & it all looks okay.  the micro USB port does look horribly fragile though & I'll probably squidge a bit of epoxy around it the strengthen it - there do seem to be lots of comments on YouTube about people having broken theirs off.  I would ideally like to leave a UART free with MSP enabled, but I don't think there are enough on the FC to be able to do this.
so, wiring, nice & simple again, as per the helpful Matek diagram:
SBUS -> SBUS  (built-in inverter on UART1-Rx)
GPS   -> UART2
SmartPort -> ST1 - this is just for RSSI, right?
this uses all the UARTs & doesn't leave one unused in case I damage the USB, correct?
I've still got a few bits on order - not least the Twinstar - so there will be pictures to follow.  & probably lots more stupid questions  :o
« Last Edit: September 02, 2019, 01:50:16 PM by badger »
Shikra
  • "The brains behind Bignose"
  • Group Captain
  • Still flying up my own arse.
Re: badger's Twinstar build
« Reply #1 on: September 03, 2019, 03:10:43 PM »
My first FPV plane was twinstar. Absolutely loved it. Been thinking about doing one again so just bought it.
iNav on F405 wing
Frsky R9M and f-port
Sunnysky 2212-1100 with APC 8*5 to start
badger
  • Pilot Officer
« Reply #2 on: September 03, 2019, 05:38:20 PM »
iNav on F405 wing
nice.  :)
mine turned up this morning.  it seems pretty nice, but from a time BC (before carbon), so there's rather less space inside than I was expecting on account of the thickness of the foam.  I think I might get an RX4R/RX6R for it rather than trying to shoehorn in one of my X6R/X8Rs.
badger
  • Pilot Officer
« Reply #3 on: September 03, 2019, 05:44:14 PM »
I just realized that I'd mixed up SBUS & SmartPort here - RSSI is on SBUS ch16.
I'm not sure why I would want SmartPort connected to the FC & whether it's for sending SmartPort sensor data to the FC or sending FC sensor data to the Rx. :confused:
Shikra
  • Group Captain
« Reply #4 on: September 04, 2019, 03:55:08 PM »
One of the reasons I went to the Frsky R9M. With FrSky Fport only need one wire to get all the telemetry and control. that said, I have never used telemetry for FPV before. Never found the need.
I suggest planning your layout and ry fitting everything before gluing together. Its hard to resist assembling, but it helps a lot to figure out what goes where.
I ended up using same GPS as you and have put it in a 3d case just behind wing. My rx will also go in there. Really happy out it turned out.
For the FX, I hollowed out part of the fuselage so the FC can sit in there and I have full movement of the battery back as far as it needs to go.
Next have to figure out a design for the camera / cockpit area.
For motors I designed some new mounts to suit the Sunnysky 2212. Probably suit yours too. I'm uploading the files to thingiverse if you need some.
badger
  • Pilot Officer
« Reply #5 on: September 04, 2019, 06:05:05 PM »
I did some googling on SmartPort & understand how it works with a FC a bit better now.  I'm going to fly the TwinStar LOS sometimes, so telemetry is a must for me.  I will investigate FPort for a future model!
I'm definitely going to do a dry run before gluing the fuselage halves together, there's rather more than I'm used to to fit in & I want to make sure it's going to balance somewhat sensibly beforehand.  I'm still waiting on my motors & ESCs before I can do too much.
I was reading Coyote's TS build thread here:
https://www.fpvhub.com/index.php/topic,21201.0.html
which seems to show that the included motor mount might be usable.  I wish I could 3D print stuff, but I don't have a printer.  :(
« Reply #6 on: September 04, 2019, 09:26:14 PM »
Nice choice of bird, I would do another one myself they fly so well.
Sure the standard mounts work fine, as do the 3D printed ones.
It is a little tight for space so a lot f trial and error and creativity is required for the dry run stage before committing to glue :)
badger
  • Pilot Officer
« Reply #7 on: September 16, 2019, 01:10:53 PM »
I soldered up the F411-wing board & was quite pleased with the job I did - & got GPS, SBUS & SmartPort all working nicely.  & then it just died on me :(  now it won't boot & one of the components on the bottom of the board gets finger-burningly hot, which I don't think it did before.
I don't suppose BangGood are going to believe it was a faulty board once you start soldering, so I guess I'm going to have to get another one & try again.  :(
« Reply #8 on: September 16, 2019, 03:45:16 PM »
That's a shame, not very confidence building either. I wonder what's caused it  :'(
badger
  • Pilot Officer
« Reply #9 on: September 16, 2019, 03:58:45 PM »
well, I say "just died", but I did try plugging in a servo & it went crazy.  when I checked I was getting Vbatt (3S) on the servo 5V pins - all the other 5V pins were 5V & the VTx Vbatt pin was Vbatt, so I'm fairly confident that it wasn't anything dodgy on my part.  I rather doubt I'd persuade BangGood of that, although I might give it a go.  :(
I've ordered another F411 & I have an F405 already, so next time I'm going to configure it via USB & just solder on a battery plug, then go over all the pin holes with a multimeter before doing any more soldering.
on the upside, my soldering has improved a lot & I can now make servo leads.  ;)
Well, I registered by ched
[February 20, 2020, 08:51:38 PM]
Took Mark's S900 out for a test! by luv2rip-fvp
[February 17, 2020, 03:22:39 PM]
I'm (attempting) to make a free FPV quad sim by ched
[February 14, 2020, 11:11:38 PM]
PPM/PWM to SBUS converter? by ched
[February 08, 2020, 09:54:15 PM]
220mph Proximity by FPVSteve
[February 07, 2020, 12:51:32 PM]
Matek f405 wing and frsky l9r rssi setup by Brandon1
[February 04, 2020, 11:30:10 PM]
FrSky and ACCST 2.0 - DANGER by ORCA
[February 03, 2020, 08:50:44 PM]
My 1st rip of 2020! by luv2rip-fvp
[February 02, 2020, 07:12:36 PM]
recommend me a quad to learn on by badger
[February 01, 2020, 11:27:05 PM]
The Lego quadcopter by Coyote
[January 22, 2020, 08:46:19 PM]
