  • Dot Guests: 169
  • Dot Users: 1
rcstuff 020
Posted by: mattydred
in: edge540
More Sky Surfer pics
3dbi omni
QUEDADA FPV 006
Posted by: COKE32
in: FPV SPAIN
Scout Bee
Posted by: MarkLincs
in: Scout Bee
Author Topic: Took off a resister off my F3 Flight controller, does it matter?  (Read 391 times)
ali101
  • Flying officer
Hi guys,
I by accidentally took of a resister (not sure what there called tbh), does it make a difference, shall I replace my FC, the board functions fine (turns on without any smoke).
Whatís your guys opinions on this?
  • Online Online
Re: Took off a resister off my F3 Flight controller, does it matter?
« Reply #1 on: June 19, 2020, 03:10:13 PM »
It could be for a feature you are not using but who knows. With props off check everything you can in BF. i.e does the model of the quad move correctly when you move quad? Do motors spin correct directions? Do rx signals work, does osd work etc...... Just test everything as much as you can especially failsafe!!!!!!
Good Luck.
ali101
  • Flying officer
« Reply #2 on: June 21, 2020, 10:26:35 AM »
Thanks ched, the motors do
Spin correctly and the board moves according to a the BF GUI.
But Iím not getting my RX input on BF, so thatís probably what that transistor was for :)
  • Online Online
« Reply #3 on: June 21, 2020, 01:29:37 PM »
You might be able to move the rx to a different uart to get it working?
ali101
  • Flying officer
« Reply #4 on: June 21, 2020, 01:51:38 PM »
Iíve moved the RX to all 3 UART spaces on my FC, then changed it on the ports tab on BF, as well as playing around with the serial rx inversion. But no luck
  • Online Online
« Reply #5 on: June 21, 2020, 02:25:59 PM »
Sugar. I suppose you could try say an led strip on a uart to test it? Just something other than a rx. That way you could prove if uarts are working. Do you have smart audio connected from your vtx? Does that work?
ali101
  • Flying officer
« Reply #6 on: June 23, 2020, 03:01:01 PM »
Good idea ched, thanks. Do I connect the ĎLEDí wire on the LED to my UART on my FC? RX3 right?
  • Online Online
« Reply #7 on: June 23, 2020, 05:40:08 PM »
I think led wire to the tx pad. As fc is transmitting signal to the led to tell it what to do.
It would be rx pad if led was providing info to fc.
ali101
  • Flying officer
« Reply #8 on: June 23, 2020, 07:02:30 PM »
Okay done that, Iíve turned on port 6, since itís on TX6, but when I go to the LED section on BF, it doesnít save.
What am I doing wrong?
  • Online Online
« Reply #9 on: June 23, 2020, 09:00:49 PM »
You have to remap resources. i.e. currently tx6 is acting as a uart but you want to test it by assigning it as an LED STRIP output.
This page will give you info that should help.
ali101
  • Flying officer
« Reply #10 on: June 24, 2020, 12:59:26 AM »
Thanks ched, but I canít see the page, did you add a link?
  • Online Online
ali101
  • Flying officer
« Reply #12 on: June 30, 2020, 11:41:17 PM »
Okay so what Iím getting from Oscar liangs post is that, I swap the port for LED STRIP and TX6.
So would it be Ďresource TX6 (then LED STRIP PORT)í? I donít need to add a Ďsetí do I?
A little tour... by luv2rip-fvp
[Today at 01:50:15 PM]
UPDATE: Gatwick drone arrest couple - Dec 2018 by Coyote
[Yesterday at 02:59:41 PM]
Brave New World by Tim Chambers
[July 31, 2020, 02:56:19 PM]
Practicing Acro by FPVSteve
[July 30, 2020, 05:11:47 PM]
[July 29, 2020, 10:10:00 PM]
One motor doesnít spin, despite throttle position by FPVSteve
[July 29, 2020, 05:00:17 PM]
Mixing it up a bit by luv2rip-fvp
[July 27, 2020, 03:34:58 PM]
Wales Unlocked! by urbanfpv
[July 21, 2020, 06:13:51 PM]
NOOBs first quad... asking for a friend (2020) by Doppelganger
[July 19, 2020, 02:15:05 PM]
Great spot part 3 of 3 by luv2rip-fvp
[July 17, 2020, 09:04:18 PM]
