  • Dot Guests: 147
  • Dot Users: 2
IMAG0166
Receiver No.1
FPV Y VENTURE 12 2009 016
Posted by: COKE32
in: FPV SPAIN
easy4
Posted by: munkyboy
in: Pauls Stuff
Author Topic: Help No video through my FC  (Read 406 times)
Quad__
  • Pilot Officer
« on: June 30, 2020, 10:17:48 PM »
Hello everyone,
I cannot seem to get my FPV video to pass through my FC. I get a picture when itís connected directly transmitter to camera (no FC) but when I connect the video wire to video in and out on my FC, I get a black screen on my goggles and no OSD.
Is there any settings I change change on BF (Iíve checked, and my OSD is on) it is my FC need replacing.
Re: Help No video through my FC
« Reply #1 on: July 07, 2020, 06:40:09 AM »
I think we need a lot more details to really make any suggestions, like what make is the FC ? have you any wiring pictures ? What grounds are you using in the video path ect
Quad__
  • Pilot Officer
« Reply #2 on: July 10, 2020, 11:42:51 AM »
Iím using a MAMBA F405 mini FC, runcam micro swift and runcam tx200u, the quads a diatone R349.
Hereís a picture of my wiring, but for my camera the red is video and the yellows voltage.
And what do you mean by which grounds am I using?
  • Global Moderator
  • Air Marshal
  • Brought to you by Google
    • My YouTube page
« Reply #3 on: July 11, 2020, 12:20:36 PM »
All the board layouts for the f405 I can find have 12 pins on the side you are connecting your camera and VTX, but this board has 14.  Do you have a link to the schematics ?
Quad__
  • Pilot Officer
« Reply #4 on: July 12, 2020, 07:09:20 PM »
Yes this is the schematics
  • Global Moderator
  • Air Marshal
    • My YouTube page
« Reply #5 on: July 13, 2020, 11:43:18 AM »
The wiring looks ok (I can't see where the VTX is connected - but assuming you've connected that up correctly)
Usually, a blank screen would suggest that the VTX is putting out a signal, but is transmitting nothing... i.e it's not getting an image from the camera.  Any chance you'd connected that signal to 5v at some point? (which may well murder it)  I would really try and stick red to power if I were you - else it can get a bit confusing.
It's easy to pin down the problem with the aid of a spare camera and/or VTX but I'm guessing these aren't to hand.  In which case you could see if the camera is working by powering it whilst connecting the GND/Video out to a composite video connector and sticking that into a compatible monitor/TV
  • Online Online
    • DroneFinder
« Reply #6 on: July 13, 2020, 01:12:34 PM »
is the lens cap off? :)
Quad__
  • Pilot Officer
« Reply #7 on: July 14, 2020, 06:43:15 AM »
Yes the VTX is connected properly since I didnít mess with it, and itís still as it came.
Do you mean connect the camera to an external 5v and GND? Because Iíve done that, I connected both the cameras and VTX to an external GND and power (not on this FC) so only had my video cable running through the FC. It produced an image but no OSD.
Also the tried the this camera and VTX on another FC, and an image and OSD were produced.
Additionally I do have a spare camera and VTX, if you want to try something else.
And yes, my lens cap is off :)
  • Global Moderator
  • Air Marshal
    • My YouTube page
« Reply #8 on: July 14, 2020, 11:52:10 AM »
So you connected GND/V of the VTX and camera to an external source, but left the video.  So camera going to VI and VO to VTX?  If that's the case (ignoring the OSD of lack of) it sounds like the camera isn't getting power on your actual FC.  Have you checked the voltage if you check the FV GND/5V connections for the camera ?
Quad__
  • Pilot Officer
« Reply #9 on: July 15, 2020, 02:47:00 AM »
Yeah it seems my camera and/or VTX Isnít getting power on my FC, eventhough Iíve checked it with a multimeter and Iím getting 5v, on my 5v pads on my FC.
What could be the cause of this?
  • Online Online
« Reply #10 on: July 15, 2020, 08:27:12 PM »
Double check you are also getting 0V on the pads you are using!!! As if you only have 5v and no 0v it wont work! i.e. put the multimeter between lipo 0v (as close to lipo as possible) and test 5v then put multimeter on 5v and test to 0v.
Quad__
  • Pilot Officer
« Reply #11 on: July 16, 2020, 08:23:08 PM »
Iím not to sure I get what you mean, Iíve checked and Iím getting 5v on all the 5v pads on my board even if Iím not using them.
  • Online Online
« Reply #12 on: July 16, 2020, 10:40:55 PM »
To check a voltage with a multimeter you have 2 probes. To test the 5V you put the black (0v) probe to a gnd pad then the red tests the 5v pads to see what voltage is between the two test points.
But you also need to test the 0V pads. So you put the red lead on a 5v pad then the black one on each gnd/0V pad. They should all show a reading of 5v between the probes on the multimeter.
A multimeter in voltage mode tests the difference in voltage between the probes. Ultimately test the 0V (to black probe) and the 5V (to red probe) on the ones that actually feed your camera then the vtx ones.
Hope that helps?
A little tour... by luv2rip-fvp
[Today at 01:50:15 PM]
UPDATE: Gatwick drone arrest couple - Dec 2018 by Coyote
[Yesterday at 02:59:41 PM]
Brave New World by Tim Chambers
[July 31, 2020, 02:56:19 PM]
Practicing Acro by FPVSteve
[July 30, 2020, 05:11:47 PM]
[July 29, 2020, 10:10:00 PM]
One motor doesnít spin, despite throttle position by FPVSteve
[July 29, 2020, 05:00:17 PM]
Mixing it up a bit by luv2rip-fvp
[July 27, 2020, 03:34:58 PM]
Wales Unlocked! by urbanfpv
[July 21, 2020, 06:13:51 PM]
NOOBs first quad... asking for a friend (2020) by Doppelganger
[July 19, 2020, 02:15:05 PM]
Great spot part 3 of 3 by luv2rip-fvp
[July 17, 2020, 09:04:18 PM]
