Members => Build Threads => Topic started by: drubug on October 08, 2010, 06:50:37 PM
Title: Piper Cub FPV platform
Post by: drubug on October 08, 2010, 06:50:37 PM
Have been playing with a WOT4 Foam-e for past couple of weeks as an FPV platform, now that i loaded all the gear inside and its just not going to cope with the weight, full power and barely climbs at all.
Plus the landing gear was not up to the job, it wasnt even a heavy landing!
(http://s3.postimage.org/6m3G9.jpg) (http://postimage.org/image/cw6svi6c/)
Ripped out the undercarriage and a big blob of foam with it. (Wheres the CA)
So rather than upgrade the motor and ESC, as i like flying the Wot4 im going to switch over to a new FPV platform.
I have a electric Piper Cub and I love flying it, so its time to switch over all the gear to that, it has MORE than enough power, i know... You cant prop hang a real cub.. I know ive flown one... anyway,
Thought I would post some pictures and let you know the kit i have inside it.
The Kit.
Also have
(Always record you can play it back and work out where your models hiding in a tree!!
[/list]
Here are a few pics of the platform
(http://s3.postimage.org/6mP3S.jpg) (http://postimage.org/image/cx2833k4/)
PiperCub
(http://s3.postimage.org/6nd0i.jpg) (http://postimage.org/image/cxirgkhw/)
Massive area for electronics
(http://s3.postimage.org/6nOqr.jpg) (http://postimage.org/image/cy7kirwk/)
CPD4 On top of the wing
(http://s3.postimage.org/6o7nA.jpg) (http://postimage.org/image/cykstjus/)
GPS unit mounted in the cockpit but this is pretty close to the vtx to ive moved it behind the wing.
Still to do.
Will tomorrow build a Pan/Tilt unit for the camera and mount this in the cockpit.
Maiden FPV flight tomorrow , weather permitting.
Title: Re: Piper Cub FPV platform
Post by: Coyote on October 08, 2010, 07:35:10 PM
Looking good, that looks a much more formidable bird to carry the extra weight. Good to see the WOT4 isn`t dead.
Good luck with the maiden tomorrow :)
Post by: mark1975 on October 08, 2010, 08:31:52 PM
looking good dru nice little setup there mate ..im getting eager now myself lol good luck with your maiden tomoz and we want a full report by 5.30pm lol
Post by: Sheldon Holy on October 08, 2010, 09:41:39 PM
Are you going to get rid of the plastic windows when you get the camera in? I guess the reflections could ruin everything, i've played with a keychain camera in a windowed cockpit and unless the material is completely clear it can be very hard to see.
So probably a good idea to get rid of the windows if you haven't done so already.
Sheldon
Post by: drubug on October 08, 2010, 09:45:26 PM
Thanks for the advice, yes I was going to trim back the top of the window and poke the pan and tilt out of the way.
Dont want to completely remove the screen as it directs a large proportion of the thrust from the prop so would have a marked effect on endurance.
Will post pics of what i do
Post by: Sheldon Holy on October 08, 2010, 10:04:09 PM
Ok. But try to get rid of as much as possible. Removing all the windows will have no effect on thrust at all. At any rate it's not like its some old warbird with such a huge radial cowl that onle half an inch of prop sticks out around the sides :o LOL
Every which way, you'll get the best results without windows, and very little aerodynamic properties are lost, and a picture will be so much better with a clear view. It'll also keep all the bits and pieces nice ans cold.
Sheldon
Post by: drubug on October 09, 2010, 01:09:25 AM
Again, ta, I was going to have the Pan Tilt unit fitted so its kinda poking out the top, reducing the amount i have to trim off the screen.
But yes i know what you saying, and ill def keep the camera clear of the screen  ;D
Will post some pics tomorrow
Post by: drubug on October 09, 2010, 02:36:19 PM
Too windy for the maiden today, although I did drive up and down the road FPV :)
Built a pan and tilt system for the camera this morning.
Using the camera bracket (modified)
and 2x Micro servos
(http://s4.postimage.org/34tsi.jpg) (http://postimage.org/image/68hbg7dw/)
Pan servo screws into the camera bracket,
The Tilt servo is fitted by fixing the arm to the bracket upright and the camera and the servo move with the arm staying screwed to the bracket, this way the camera can just be stuck to the servo body with tape. You also dont need to worry about hinges for the camera to fix to.
(http://s4.postimage.org/35Pg9.jpg) (http://postimage.org/image/6a1jq06c/)
Fitted into the plane by the pan servo being installed with tape and a screw. I decided to fix into the corner of the plane cockpit, as this way you can look both left and right but looking right you can look straight down past the landing gear. (should be good for the flair)
And as advised I have put the camera outside so that the screen does not cause any problems with the vision. (thanks for the tip)
Few other bits done including the wing navigation coloured tape.
(http://s2.postimage.org/37opA.jpg) (http://postimage.org/image/6bva7rhg/)
This is actually the stuff they use on Ambulances and is VERY reflective so you can see red or green in almost any lighting conditions.
(http://s2.postimage.org/37FSA.jpg) (http://postimage.org/image/6c6uz6xw/)
Post by: mark1975 on October 09, 2010, 02:48:01 PM
she is looking sweet mate all ready for here maiden mm the weather yet again letting us down they even said it was going to be nice weekend mm got it wrong ..looking forward to your progress dru cheers matey
Post by: drubug on October 09, 2010, 02:56:13 PM
Its rubbish weather, but hey better to be on the ground wishing to be in the sky than in the sky wishing to be on the ground  ;D
To be fair the plane has flown many times just not with all the FPV stuff in, so its only the FPV maiden.
I love how this plane flies without the extra weight and the size and overpowered engine should cope well.
Just need to remember flaps for landing!
Post by: drubug on October 09, 2010, 04:12:20 PM
Pan and Tilt Demo (http://vimeo.com/15686137)
Video of the pan and tilt in action.
Post by: drubug on October 09, 2010, 04:14:29 PM
Seeing as the weather wouldn't play along, i went with the back up plan...
(http://s4.postimage.org/3vDzi.jpg) (http://postimage.org/image/73zu4a5g/)
Hot tub!
Post by: Coyote on October 09, 2010, 09:06:37 PM
Hi Dru, looking good mate, i would have recommended a different way of tilting the camera. The way i do it has a bit more strength, pivots on both camera bracket legs so wont shake as wind speed hitting the cam get high
Like this :
pan and tilt test (http://www.vimeo.com/13307118)
Shame you didnt get out, always tomorrow :)
Post by: drubug on October 10, 2010, 10:59:19 AM
Yes I thought about doing it that way but the way the camera i have was attached to the bracket i thought there was a risk of the screws coming out and the camera going bye byes. Ill give this a go and if it does shake will re fit it as you suggest :)
The camera is pretty much in the prop wash and at full power there wasnt any shake from the wind, so will see in flight.
Post by: mark1975 on October 10, 2010, 12:05:40 PM
blimey check that landing strip out ;;;; nice one dru he he
Post by: Coyote on October 10, 2010, 12:54:31 PM
Cool, like you say it might work just fine.
Just put a dab of threadlock on the camera bracket screws before fitting. After 5 mins the threadlocks gone off and the only way getting the scres back out is using a soldering iron on the screw head to melt the threadlock. If you try using a screwdriver it will wreck the screw before it lets go.
Title: First FPV Flight of the Cub
Post by: drubug on October 17, 2010, 02:03:03 PM
Come hell or high water, the cub was flying today.
Weather had been terrible for weeks but today it was sunny with just a gentle breeze.
Off we went, this was the first flight of the rebuilt Cub with the CPD4 active, and getting good 5/10 on the setup. (best i had before was 3)
FPV flight, might as well go for full take off and landing, (i dont do anything by halves)
First FPV flight with the Cub (http://vimeo.com/15917595)
Here is the very short flight and result.
The plane was horribly trimmed, nose up and left roll to battle.
You will see at about 1:18 I get pitch up and stall, you will see the CPD4 fighting to stop the wing drop, and stopped the plane entering a spin. It really does work well. I had it set slightly too nose down so it wouldnt fly level. But saved my bacon in the stall.
Landing was a little fast but as this was first time with no flap and all up weight of 2.8kgs!! better to be fast!
Post by: Coyote on October 17, 2010, 02:11:33 PM
Nice one Dru that was fast and furious flying, you dont hold back do you lol :)
Post by: electricmick on October 19, 2010, 01:00:30 AM
Well done for getting it back in one piece given the trim.
Post by: drubug on October 19, 2010, 07:34:26 PM
Quote from: Coyote on October 17, 2010, 02:11:33 PM
Pah. wheres the fun in that, live on the edge and have superglue on stand by.
Post by: Stewb on April 01, 2011, 10:27:52 PM
Evening,
Just joined and have a 40% Cub which will be fitted with tandem cameras (or that`s the idea).   Trouble is, I know less than a carrot about FPV so I might annoy you.
Can you help?
Cheers,
Stew.
