Simple as above really.
The Tx simply will NOT bind with either of the two RX's I have. One was not bound to the TX so I thought I might as well bind them both at the same time and job sorted. One on the quad and one on the plane.
Yesterday it was working fine?!?!?!
Now I did make the mistake of first off trying to bind them when the TX and RX were pretty close, within 5-100cm away from each other. I have heard this can make it go into some sort of uber failsafe!?!?!
I have had a read on various other forums and tried various things to try and sort. Tried to update but the crap updater won't even work (software issue I think not hardware)!!! DAMN YOU VILE THING!!!
So if anyone has had / heard of this I would be very grateful for any answers....... short of burn it!!
as you said huntridge the distance may be your issue.
i have this with my spektrum gear try moving your tx further away from your rx and binding.
Liam
