Multicopter => Flight Controllers => Topic started by: JezUK1 on April 30, 2013, 11:13:21 PM
Title: Naza return to home.
Post by: JezUK1 on April 30, 2013, 11:13:21 PM
I was wondering for the DJI return to home Is there a function that you can tell it to gain altitude before returning home and Landing? Or can you only make it turn around and come straight back?
Also is the fail safe the same thing? Plus is I were to lose radio control signal would it realise that and come home?
Title: Re: Naza return to home.
Post by: g.collins on April 30, 2013, 11:25:04 PM
It automatically climes up, before it returns to launch.
:) G
Post by: Dizzy on April 30, 2013, 11:31:51 PM
[/quote]  It will return to home and land  if u lost your radio control link only if you have set your reciever failsafes correctly ie rth switch on and throttle to more than 25percent  :D
dizzy
Post by: CurryKitten on April 30, 2013, 11:38:52 PM
I believe Naza will climb to 20m before returning to you....unless it's already more than 20m up in which case it just stays at that altitude.
Like Dizzy says - you need to make sure your rx supports a failsafe function, so you can tell you rx to activate RTH if it looses the RC link.
Here's a video of me pooping myself whilst testing my RTH function -
Naza RTH testing (http://www.youtube.com/watch?v=RidRzuqnmfs#ws)
Post by: g.collins on April 30, 2013, 11:58:25 PM
Scary stuff bud, the first time I did my fail safe, it was dark, I didn't realize it went up first, I felt a bit faint I can tell you.
:) G
Post by: Teamftp on May 01, 2013, 12:20:35 AM
It is super impressive to watch and works great!!
Post by: 3DJIM on May 01, 2013, 01:16:23 AM
It is sweet, took mine out 600m under the goggles and popped the RTH!
Jim
www.youtube.com/watch?v=kjdd0XtXLno (http://www.youtube.com/watch?v=kjdd0XtXLno#ws)
Post by: JezUK1 on May 01, 2013, 12:35:33 PM
Wow fantastic! Is there a way you can program it so it does something before it comes home for instance get it to gain a certain amount of altitude or can you only use the default settings?
Post by: CurryKitten on May 01, 2013, 12:44:34 PM
Not with the Naza, as I said it'll rise to 20m before coming home, or if > 20m already just come home at that distance. It's also giving you the chance to reestablish an RC link, there's a pause before each of the phases - so on initial control loss, it'll sit there.. wait, then go up.. wait, then come back, wait and finally land.  I believe the WooKong has the return altitude programmable... but it's lots and lots more money.
Post by: JezUK1 on May 01, 2013, 01:34:56 PM
Aw we will not be going down more £££ just yet lol. Thanks.
So with planes and return to home how does that work or don't you use the NAZ unit for that?
Post by: CurryKitten on May 01, 2013, 02:48:46 PM
Naza is a specific multi-rotor flight controller, *most* RTH systems in planes work by taking elevator and aileron control (sometimes throttle) in order to steer the plane back to the original co-ordinates.  Once there, they circle around some way above you.
As far as I know only the APM (ardupilot) can land a plane... although it's not something many have the guts to try, but also works on multis/planes and cars
Post by: JezUK1 on May 01, 2013, 09:16:08 PM
Aww I see that makes sense. Can't say I would like it to auto land a plane lol.
Silly question how can you get ur quad to come home if you lose radio control signal? Would be very handy to have that.
Post by: Oatcake on May 01, 2013, 10:10:37 PM
You set up a switch on your tx to switch naza into failsafe mode. You then set up your rx failsafe so that it defaults to switching the switch on. You do need a rx with full failsafe though - some just allow you to adjust the throttle channel only.
Simples.
Post by: Skipper Billy on May 01, 2013, 11:10:13 PM
You also need to 'smart' bind your tx and rx to make it work.
Post by: JezUK1 on May 01, 2013, 11:36:41 PM
What is smart bind?
Post by: CurryKitten on May 01, 2013, 11:54:14 PM
I've no idea what smart bind is either - what's smart bind ?
Example of what you do with a FrSky rx which is what I use to set fail safe, is on my radio I switch my manual RTH switch on and set throttle to 50%, then I press a button on the rx.  If the rx looses the signal from the radio it then sends this signal to the Naza controller - which obliges by coming home
Post by: Randall on May 02, 2013, 09:25:27 AM
The rth works great on the Naza i have it on a switch and also if i turn my tx off it kicks in (so loss of signal would activate it) i have turned the tx off and it does work fine however you do need to set this up first using the software on the pc is easiest.
One thing is i find the 20m climb a bit hit and miss it does not always climb to 20m i have set the rth off when and 2-3 feet and it only went up 8-10m and would not have cleared a big tree for instance. So dont rely on it but id at a decent hight it will work a treat. I have used mine once in a real emergency and it was great to see it come home all on its own.
Post by: Skipper Billy on May 02, 2013, 10:40:23 AM
Smart bind is a little different to the normal bind and allows you to have an almost infinite variety of failsafe options on 2.4 systems.
Put the bind plug into the receiver and power on as normal but now remove the bind plug.
When you power on the tranny into bind mode- whatever position the switches and sticks are in will be the remembered failsafe position.
Post by: CurryKitten on May 02, 2013, 11:25:55 AM
Quote from: Skipper Billy on May 02, 2013, 10:40:23 AM
Is that the equivalent of pressing the button on the FrSky rx (having moved the sticks/switches into the desired postions) in order to set the failsafe position then ?
Post by: Skipper Billy on May 02, 2013, 12:56:57 PM
Not familiar with FrSky gear but it sounds the same. It works with Spektrum and JR etc.
Post by: Heliotrope on May 09, 2013, 03:45:37 PM
Quote from: CurryKitten on May 01, 2013, 12:44:34 PM
I know it sounds pedantic but the devil is in the detail as they say. Is the RTH altitude based on the altitude at take off point or the point at where the RTH is invoked? It may not matter much in Norfolk but it does here in Wales!
Post by: Skipper Billy on May 09, 2013, 03:58:11 PM
If you invoke RTH at less than 60 feet higher than where where you took off from it will climb to 60 feet then fly home and descend.
If you are higher than 60 feet from where you took off from when you invoke it it will fly home at that altitude.
Post by: tdmodels on May 09, 2013, 04:02:01 PM
Quote from: Heliotrope on May 09, 2013, 03:45:37 PM
The NAZA is not aware of your terrain.  So it will climb to 20 meters above ground level from where you connected the battery.
Post by: Heliotrope on May 09, 2013, 04:54:23 PM
Many thanks guys - that's clear now.
Post by: JezUK1 on May 09, 2013, 10:22:33 PM
Here is a question. I thought I had my quad set to come home and land.
I flip the oh shit which to call it home and pull back on the stick. I have to keep the stick down or it will not come home. Problems is it won't land and it over shoots home and carries on unless I let the stick go to get control.
Your thoughts please....
Post by: FPVSimon on May 09, 2013, 10:35:14 PM
It sounds like you hit the IOC switch rather than the RTH.
Post by: JezUK1 on May 09, 2013, 11:21:53 PM
Silly question what does that stand for?
Post by: CurryKitten on May 10, 2013, 12:18:54 AM
IOC = Intelligent Orientation Control
It basically means in this mode, pulling back means come back to you - irrespective of which way it's facing... not used it.
Here's the thing, when you engage RTH, you don't need to pull back on the stick... in fact doing that will do nothing, unless you take it out of RTH.
Load up the Naza assistant and check what flight mode it goes into when you flick this switch... because it certainly doesn't sound like RTH is engaged
Post by: JezUK1 on May 10, 2013, 09:17:53 AM
Strange I'm sure I had it set correctly. I'll have another look and report back.
Post by: plingboot on May 10, 2013, 09:30:51 AM
I might be wrong, but I didn't think the naza could be set up with an rth switch like the WKM.
On my naza(s), I've set up a switch which forces the flight mode into the failsafe zone, via a mix, and also uses a throttle cut function with an offset to fix the throttle at a bit below 50%.
in the assistant tx monitor it works as planned, but not had the balls to try it for real yet. Maybe this weekend.
Post by: Skipper Billy on May 10, 2013, 12:57:25 PM
The NazaM CAN be set to RTH at the flick of a switch.
RTL, Autoland and Full Power testing - DJI Hexacopter with NazaFC & GPS (http://www.youtube.com/watch?v=ZtsWlhZwS3U#ws)
