gives me a headache just looking at it (?)
(http://s16.postimg.org/wji9yhrsh/carlsquad.jpg) (http://postimg.org/image/wji9yhrsh/)
(http://s14.postimg.org/ttkfhvzgt/carlsquad1.jpg) (http://postimg.org/image/ttkfhvzgt/)
(http://s4.postimg.org/9ja5pa30p/carlsquad2.jpg) (http://postimg.org/image/9ja5pa30p/)
this is the text from the ebay listing from whom my mate bought it off
THIS IS FOR A QUADCOPTER 400 MM BETWEEN FRONT MOTOR SHAFTS, DESIGNED TO TAKE A GO PRO CAMERA AND COMES WITH THE FOLLOWING INSTALLED...
CRIUS AIO PRO BOARD WITH BLUETOOTH MODULE TO CONNECT DIRECT TO MISSION PLANNER MEGAPIRATE SOFTWARE IS INSTALLED ON BOARD
4 IN 1 20 AMP ESCS
HP2212 1000 KV MOTORS WITH 8 INCH PROPS
CN-06 GPS UNIT
HIGH AMP BEC POWER SUPPLY
GENUINE SPEKTRUM AR 8000 RECEIVER
4 FLIGHT PACKS YOU CAN USE 2X IN PARRELEL FOR 12 TO 14 MINUTE FLIGHTS OR ALONE FOR 6 TO 7 MINUTE FLIGHTS
IT HAS A CAMERA GIMBLE ANTI VIBRATION MOUNTED, BUT HAS NOT BEEN CONNECTED TO BOARD YET, COMES WITH SERVOS BUT THEY NEED INSTALLING TO RUN GIMBLE.
IF YOU USE 2 BATTERIES IN PARRALEL AND A GO PRO CAMERA THE BALANCE C OF G IS PERFECT,I HAVE LEAD WEIGHT IN FRONT TO SIMULATE THE WEIGHT OF THE GO PRO TO SET UP THE BALANCE AND C OF G CORRECTLY.
THIS IS A TOUGH QUAD FRAME AND FLIES VERY WELL .
THE GPS WAYPOINT FLYING IS DONE VIA MISSION PLANNER THAT IS A FREE DOWNLOAD FROM THE WEB AND USED GOOGLE EARTH AND IS A SIMPLE CLICK AND GO METHOD.YOU CAN ALTITUDE HOLD,GPS HOLD,WAYPOINT FLY MISSIONS,RETURN TO LAUNCH FUNCTION, AUTO LAND FUNCTION ETC.
I CAN SUPPLY FULL SETTINGS FOR A SPEKTRUM DX8 TRANSMITTER VIA SD CARD FILE. I ADVISE A DX8 TO GET FULL USE OF ALL FUNCTIONS.
THANKS FOR LOOKING FEEL FREE TO ASK ANY QUESTIONS OR CALL 07914******
THE QUAD IN THE BACKGROUND ISNT INCLUDED IN SALE THANKS
The quad in the background isn't for sale? Sounds like dodgy ebay advert to me.
Ok mate... this has the multiwii AIO pro installed...and in the photo I see the board....your best bet is to come over to mine on sunday morning if you can and we'll get her flying...
Keukpa :)
Quote from: Andy66 on May 09, 2013, 04:59:56 PM
Were there any other pics which had a quadcopter in the background?
heres the ebay listing
http://www.ebay.co.uk/itm/QUADCOPTER-MULTIROTOR-BIND-AND-FLY-/200918994324?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D200918994324%26_rdc%3D1&nma=true&si=OBl96W%252FWGx%252FZLipY6vRyJVWR5sQ%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 (http://www.ebay.co.uk/itm/QUADCOPTER-MULTIROTOR-BIND-AND-FLY-/200918994324?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D200918994324%26_rdc%3D1&nma=true&si=OBl96W%252FWGx%252FZLipY6vRyJVWR5sQ%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557)
Quote from: keukpa on May 09, 2013, 05:20:27 PM
Keukpa :)
here you go john,
connors opening it up so you can see and taking off the camera mount/gimble cuz its shite
(http://s13.postimg.org/ucgdn1ojn/connor_fix.jpg) (http://postimg.org/image/ucgdn1ojn/)
(http://s24.postimg.org/mpvn4klf5/insidequad.jpg) (http://postimg.org/image/mpvn4klf5/)
(http://s23.postimg.org/jte4ks2uf/ar8000.jpg) (http://postimg.org/image/jte4ks2uf/)
(http://s22.postimg.org/5q70r1xst/bluetooth.jpg) (http://postimg.org/image/5q70r1xst/)
(http://s7.postimg.org/idxqot0vr/ubec.jpg) (http://postimg.org/image/idxqot0vr/)
yumyum
(http://s1.postimg.org/bkf19pomj/3feet.jpg) (http://postimg.org/image/bkf19pomj/)
Oooooo donuts...I want a quad made out of donuts....
Keukpa
dont know what the guy was thinking when he wired the motors up
(http://s7.postimg.org/dqzhsedh3/shite.jpg) (http://postimg.org/image/dqzhsedh3/)
shite
(http://s23.postimg.org/ulwx25ug7/good.jpg) (http://postimg.org/image/ulwx25ug7/)
shortened, bit of heat shrink and a few cable ties and they are much better
looking forward to meeting you on sunday john and sorting the flight controller and getting it in the air.
i just found this little yellow thing in the box the quad came in - havnt a clue what it is or where it goes.
sorted the motor wires out and pulled the spektrum rx and satelite out from inside the frame and mounted them outside where they will get a better signal similar to how i done it on skyops1.
if its not raining or blowing a gale when i get to yours we go flying first before sort this quad out cuz the weather might change and might not get a chance to fly.
its got to be propper bad weather to stop me flying skyops1 because it handles it great - good fpv flying but not too good for filming
the ubec isnt connected to anything on the 5v out either???
(http://s10.postimg.org/iuu9zklcl/quadsetup.jpg) (http://postimg.org/image/iuu9zklcl/)
(http://s9.postimg.org/6pyccb0mj/skyops1rx.jpg) (http://postimg.org/image/6pyccb0mj/)
Looks like its all there mate.. we'll get this sorted sunday. I'll PM you tomorrow with details...
Keukpa
