Hi.
wnich one is the best option. Will be mounting to a tripod
Pretty similar it seems.
I just ordered the new skylark AAT IV, but I don't think you could go wrong with either.
The skylark has the advantage of a very neat little converter board that you can use if you have other OSD's you'd rather use. The MFD can work with other OSDs too, it's just not quite so tidy and simple. Skylark has a larger range of OSD solutions than MFD.
The MFD has the option for a second GPS on the tracker, and I have seen quite a neat little iPad application providing real time course plotting and location... Not sure if that's an official thing or home brew.
The new Skylark AAT IV has a pretty beefy looking dual servo setup for tilt and a bigger power supply. It's physically quite a bit bigger than the old one.
As you can see, it's a bit of a toss up!
I have also heard that the standard of soldering in the Skylark is much better than the MFD
I had one of the first MFD's, not a minutes problem with it, would buy another at the blink of an eye
Do they traci reliably through audio channel
Yep, but if your vtx has a microphone attached you'll have to solder it off
Simon can't you just use a different audio channel aka, the other open channel? I'm thinking Boscam here where the mic is attached...?
Dunno mate, I was always told to remove the mic regardless can cause issues
I always removed and never had problems tbh Rich
Pretty sure boscam only transmits a single audio channel, whereas immersion is stereo.
Think im going for ezantenna tracker and tiny telementary
If that`s the case then you will ave to do the same mod ( removing the mic ) if the vtx has an on-board microphone
My 2.4g boscam tx is stereo, on board Mic and ezOSD telem.
Its the 600mw imnersionrc vtx
Hi peeps I have just got the Skylark AAT IV and RVOSD RangeVideo OSD and autopilot and Boscam HD19 and Blackhawk Plus 5.8Ghz Nimrod Antenna Set now I've got to put it all together. One thing that I was a little bit disappointed about the actual packaging of the Skylark antennae tracker. :'(
(http://s10.postimg.org/guk84rxnp/DSCF7047_Small.jpg) (http://postimg.org/image/guk84rxnp/)
Mine has a couple of little marks on the case too but not as bad as that.
I'm surprised they don't just wrap the power module before popping it in the box, as it is it can smash against the exposed pan gears and get marked up like that.
Did you try emailing skylark?
I have been using the immersion stuff for about 5 years - been great. Tracker is a bit more DIY though. And doesn't do full continuous rotation (unless you have something special!) which really isn't an issue...
Yeah the full rotation is what put me off the IMRC tracker... I like to fly allll around to make best use of space.
It's not a big deal of course, just don't do circuits behind you.
Looking forwards to trying out my skylark though!
Yes, I informed Skylark but did not get Jack sh from them at the moment got frequency9 setting up the RangeVideo OSD and autopilot and the tracker. I would have bought the Skylark new OSD, but it's not out at the moment may be there send me one if i complained enough.
Quote from: Zeeflyboy on July 02, 2013, 01:28:02 PM
It's not a prob at all... Get a short blip and that's it. Doesn't
Stop me flying anywhere. Don't even think about it
IRC can rotate 360 degrees (or more depending on your servo + gearing), it just has to reverse once it hits the travel limit.
I thought it might be a limitation at first but I've never even noticed it unwinding its self when flying :)
