Other Equipment => Antenna Trackers => Topic started by: jwmachon on July 04, 2013, 06:43:04 PM
Title: Powering ez antenna tracker
Post by: jwmachon on July 04, 2013, 06:43:04 PM
Hi what's the best battery to power the eztracker I know I need a ubec looking at 2 or 3a lipo
It's a 360 degree 6v servo 50kg.
Would like to know suggested mah for a good day flying
Title: Re: Powering ez antenna tracker
Post by: skyscraper on July 04, 2013, 08:57:49 PM
Quote from: jwmachon on July 04, 2013, 06:43:04 PM
Out of interest, how do you get a servo weighing 50 kg to the flying field?
:laugh:
Post by: Coyote on July 04, 2013, 09:26:51 PM
2S or 3S doesnt matter, your still giving it a regulated 5v supply, so which ever you have handy is fine. The larger the lipo ( mah not voltage ) the longer you get from it so choose whats best for your normal flying.
I used 3S 5000mah for mine, simply because I ran a monitor, DVR and Receiver off 12v so the lipo was already part of my system
Post by: DaveyLC on July 04, 2013, 10:57:50 PM
I'd suggest powering it via the servo port as the power track on the pcb is microscopic and prone to fail.
