Multicopter => Flight Controllers => Topic started by: Dean on July 10, 2013, 03:53:33 PM
Title: Aurora 9 naza problem fail safe
Post by: Dean on July 10, 2013, 03:53:33 PM
Not sure if someone can help.
I have aurora 9 and naza m
Trying to set the failsafe.
I have the 3 switch and 2 switch
Gps/ alt/ man
When I have it on alt and turn on the failsafe switch
It goes to fail safe. When its in gps and I flick the switch it goes to failsafe.
When its on man and I flick the switch it goes to the right into a half blank box.
I have naza assistant 3.12 version.
How can I fix this. ?
Sorry if I don't make sense hard to explain.
Title: Re: Aurora 9 naza problem fail safe
Post by: DaveyLC on July 10, 2013, 04:59:47 PM
I assume your fail safe is setup as a mix?
How do you set the fail safe state on the Aurora? Maybe you could trim out your 3 way switch so one position is in the fail safe area.. Set the fail safe state and then re-trim so that position becomes the correct mode again.
