Multicopter => Multi Copter => Topic started by: marcin on January 02, 2014, 01:50:54 AM
Title: Help me build small FPV Quad.
Post by: marcin on January 02, 2014, 01:50:54 AM
OK.
My another idea is to desing and build small "around 30cm long maximum" quadrocopter.
1. MUST BE CHEAPEST SETUP POSSIBLE "INCLUDING ALL WE NEED"
2. PROPELLERS MAXIMUM 6" 7"
3 LIPO TO POWER THAT THING WOULD BE 3s or 4s but 1000mAh = silly cheap ! and got 10 of them !
4. FPV ONLY ,camera+VTX ,NO OSD GOPRO ETC:.
help me choose power setup
motors
esc's
props
fc
fpv - i will go 1.2 Lawmate or 5.8 immersion
It's tiny and this build is for bushing my local park :)
don't worry about frame I will create something for that setup.
Special frame to go crazy :) and cheap :)
Title: Re: Help me build small FPV Quad.
Post by: marcin on January 02, 2014, 02:40:26 AM
OK I think to start with these motors
http://www.giantshark.co.uk/product/170677/xyh28-22-1400kv-8a-outrunnner (http://www.giantshark.co.uk/product/170677/xyh28-22-1400kv-8a-outrunnner)
then add
this esc's http://www.giantshark.co.uk/product/168493/hobbywing-flyfun-10amp-esc-speed-controller (http://www.giantshark.co.uk/product/168493/hobbywing-flyfun-10amp-esc-speed-controller)
or http://www.hobbyking.com/hobbyking/store/__28159__TURNIGY_Plush_12amp_2A_BEC_BESC_UK_Warehouse_.html (http://www.hobbyking.com/hobbyking/store/__28159__TURNIGY_Plush_12amp_2A_BEC_BESC_UK_Warehouse_.html)
I know motor need 12amp esc but you never use full power on quad.
NOW ...? what props for that setup ,will go with 3S 1000mAh Lipo.
Post by: hase2 on January 02, 2014, 12:05:37 PM
does it have to be just small or as small as possible?
does it have to be as cheap as possible?
does it have to be a quad?
got some ideas :)
Post by: marcin on January 08, 2014, 03:21:15 AM
I try to sell FY30A but I will use as my FC in quad  :D
here is video what that thing can do :.
https://vimeo.com/34143597 (https://vimeo.com/34143597)
and here we got firmware and manual  :D
http://www.feiyu-tech.com/product-en.php?id=13&mlist=3 (http://www.feiyu-tech.com/product-en.php?id=13&mlist=3)
all I need is my giantshark order to be here and frame  :laugh:
Post by: marcin on January 08, 2014, 04:18:40 AM
ok I decide to get :.
D2822/14 1450kv motors + 12Amp turnigy plush ESC's with 8x3.8 electric props -this setup will give me around 400gr thrust each motor at 7amps or 6amps.
so 1.6kg is maximum
now need frame for 8" props  ;D light and stiff then work out FY30A and some lightweight frsky receiver for that.
Post by: marcin on January 12, 2014, 03:43:35 PM
Have to shorten shafts.
Check props for balance.
Flash FY30A - setup.
Bind that tiny frsky receiver and make tiny wires for connections.
Oh and setup ESC's then solder all together.
Hope this one will give me some fun ,because big mammas I got give me headache and shaky legs for now  :laugh:
Frame + engines +FY + receiver + props/hubs + 2200mAh 3S Lipo all together weight 775gr.
Shaft to shaft is 42.5mm
Still no idea for legs - must be light as much as possible.
(http://img850.imageshack.us/img850/1218/dils.jpg) (http://img850.imageshack.us/i/dils.jpg/)
Post by: marcin on January 12, 2014, 10:40:43 PM
got legs  ;D
(http://img571.imageshack.us/img571/4919/z7fd.jpg) (http://img571.imageshack.us/i/z7fd.jpg/)
Post by: krikey on January 15, 2014, 08:54:41 AM
That looks sweet Marcin.
Post by: Hubsanman on January 15, 2014, 06:40:36 PM
Like the metal arms Marcin, much more durable than my plastic ones!  :)
