Radio Equipment => 2.4Ghz 35Mhz => Topic started by: Hubie123 on January 14, 2014, 08:53:51 PM
Title: Taranis assigning 3 way switches for rth storm osd
Post by: Hubie123 on January 14, 2014, 08:53:51 PM
Still here Taranis headache
Struggling through it, I have now got my storm osd wired up but struggleing to set up me 3 way switch's 2 way switch for modes
Title: Re: Taranis assigning 3 way switches for rth storm osd
Post by: Hubie123 on January 14, 2014, 09:08:21 PM
help needed
Post by: Matt101 on January 14, 2014, 09:36:56 PM
FrSky Taranis Review: APM Ardupilot Switches, Channel Setup, RTL or panic button! (http://www.youtube.com/watch?v=S-LSZQk1Ya8#ws)
Any good?
Post by: Hubie123 on January 14, 2014, 09:45:03 PM
I have watched this video already but stumbles me at the end as he goes on to his computer and finishes it off on his computer
Post by: Hubie123 on January 14, 2014, 09:49:22 PM
what I want that video to say is setting up the frsky taranis with the storm osd  assigning switches for modes and display
and while there on the subject setting up flaps on 1 channel  3 way switch leading on to crow.
is that too much to ask LOL
Post by: rob.thomson on January 14, 2014, 10:05:57 PM
It is very easy to setup.
Add a mix to the channel.
Set the source for the mix to then switch in question.
Done!
Note.  Do not set the 'switch field'
Post by: Jake Bullit on January 14, 2014, 11:15:03 PM
I'm in the same boat. Could you spell it out a bit clearer Rob, I'm a real dunce on the Tranny 😣
Post by: Coyote on January 14, 2014, 11:24:10 PM
On your mixer page :
Go to the channel you want your switch to be on
Hold down enter to create a mix.
In the mix screen go to source and change value to match the switch you want to use.
You don`t need to adjust anything else in the mix.
Come out of the mix
Go to the next page which is for end points, sub trims and reversing channels.
Go to the channel you set the switch mix on.
Adjust the end points and if needed sub trim value so your switch activates the modes you want.
For a 2 way switch you don`t adjust the sub trim value, just the two endpoints if you nee to at all.
Your done :)
Post by: Jake Bullit on January 14, 2014, 11:55:57 PM
Thanks, that made more sense. I'll give it a go.
Post by: _tj_ on February 13, 2014, 12:25:02 AM
I have managed to set the Tornado with a 3 position switch for Manual, PA, & waypoint.
And then have a 2 position switch that overides it for RTH.
I have also set the flaps on the slider.
Just need to add a mix for the elevator to flaps.
Next on the list after a few hundred other tasks.
