Untitled (http://www.youtube.com/watch?v=35ZoCglUeJw#ws)
Thanks Nigel
dizzy
Does it look good, or did it look good ( the props comment ) ?? :)
My fifth test flight then crash GPS and alti modes are fine ! (http://www.youtube.com/watch?v=AK19Y5fgmCg#ws)
Any idea's would be great as i really dont know why at the moment this happened :+
Your crash is very similar to mine when I somehow managed to flick into manual mode. See video at 2.53ish
The quad felt odd during pre-flight (LOS), little did I know that I had a loose prop and during the FPV flight I started fighting the controls. Just as I was landing I went into manual mode? And I was only able to recover because the OSD showed "MAN", then the prop came off and the quad did a complete roll landing on its leg and breaking a skid.
http://youtu.be/Sy-7M3DzsVA (http://youtu.be/Sy-7M3DzsVA)
Very much the same thanks for that Njoro, i feel a little happier now hase and coyote said the same thing too :)
SO finally found it ;D I do like a proper reason for a failure like this and by pure chance i have found it :D I changed out the two motors and esc,s on the side that dropped just to be safe :)
I have flown her several times since in just the hover to check all is well and touch wood she seems ok, but when playing around with one of the motors i removed i found that with sustained pressure on the shaft it will suddenly let go and spin in the motor casing turns out the motor shaft is scored around the diameter of the shaft so badly it will not come out :+
Time to look at different motors i think
well that was a good find Diz :D
