Members => Build Threads => Topic started by: marcin on February 17, 2014, 12:56:33 AM
Title: back to Y6
Post by: marcin on February 17, 2014, 12:56:33 AM
ready for maiden - hexa was not good for AV ..that setup works a lot better.
(http://img691.imageshack.us/img691/6070/sw8m.jpg) (http://img691.imageshack.us/i/sw8m.jpg/)
(http://img69.imageshack.us/img69/9100/7gdc.jpg) (http://img69.imageshack.us/i/7gdc.jpg/)
Title: Re: back to Y6
Post by: marcin on February 17, 2014, 12:13:15 PM
Maiden is done.
Must admit ,that thing can't even compare to hexa !!!  :sparta:
Post by: Coyote on February 17, 2014, 06:28:16 PM
Looks interesting bud, does it fold down at all for transportation ?
Post by: marcin on February 17, 2014, 08:40:09 PM
no Ian ,keep it simple ,don't like to complicate and no problem with transport ,also easy to carry with that handle on top  :)
asap I got real 3k carbon sheets I will make one full carbon  :)
Post by: FPVSteve on February 17, 2014, 08:40:38 PM
How many toddlers can that thing carry away to devour in a cave then??
Post by: marcin on February 17, 2014, 08:41:57 PM
2
Post by: Dizzy on February 18, 2014, 06:12:02 PM
its a Raptor LOL
looks mean bet she sounds mean too, Marcin ;)
Post by: marcin on February 19, 2014, 01:02:23 AM
she looks a lot better after clean up wiring mess  :)
Now I'm about to replace whole legs for gimbal with 20mm tubes to make them evem more stiff  ;D
will add pictures soon.
Post by: marcin on February 21, 2014, 03:16:18 PM
As I think my legs might catch some vibes during fast flying forward etc:.
I design and made whole gimbal pod for Y6 ,with 8108 mounting plate ,also gimbal mounting tube with possibility to slide forward /backward to adjust proper YAW CoG.
,design is a lot hevier then previous "600gr what's on pictures - legs" but it's made form aluminium tube and 3mm G10 - so can't expect something light and stiff like this build.
well will test that POD soon.
Actually I like it more these thick legs ,they look solid to me - tested I use that POD as my stool  ;D I'm 93kg so it's OK.
If my COG in Y6 goes to low ,middle plates got designed holes to fit batterys on top also then CoG will go UP a lot.
All is ready for testing ,she fly once for now and I really like it !!!
(http://img404.imageshack.us/img404/2733/o52f.jpg) (http://img404.imageshack.us/i/o52f.jpg/)
(http://img36.imageshack.us/img36/9322/woaz.jpg) (http://img36.imageshack.us/i/woaz.jpg/)
Post by: marcin on March 01, 2014, 11:31:37 PM
Pimp my Y6  ;D
(http://img20.imageshack.us/img20/8605/p46l.jpg) (http://img20.imageshack.us/i/p46l.jpg/)
Post by: Coyote on March 02, 2014, 01:12:22 AM
Cool :)
Post by: marcin on March 04, 2014, 12:17:54 AM
drop some weight from legs before I fit them.
(http://img843.imageshack.us/img843/4818/zu37.jpg) (http://img843.imageshack.us/i/zu37.jpg/)
Post by: hase2 on March 06, 2014, 02:28:42 PM
looks good - how much weight did you save by using carbon?
Post by: marcin on March 06, 2014, 07:30:31 PM
legs only drop 160gr - tubes You can see on picture Hase  ;)
still got 3 arms to mount - I weight them and alloy ,these is another 160gr difference ,so all together using only carbon I got 320gr -for now.
After that I will swap these 12mm alloy tubes used in gimbal for carbon "IN DELIVERY" - so more to drop :)
Then - motor mount ,will cut them from 2mm 3k Carbon instead of 3mm G10. - no clue how much this will safe ,but alwasy something.
Thinking about making whole Y6 middle plates in carbon ,but price for sheet in that sizes is  :-X
for now setting this thing  ;D ,more stiff setup ,better dampening system,perfect balance on  all 3 axis,no slope at all +setup button mounted in tubes to change setting in gimbal boards.
(http://img23.imageshack.us/img23/2268/i3c2.jpg) (http://img23.imageshack.us/i/i3c2.jpg/)
(http://img834.imageshack.us/img834/4499/jt6h.jpg) (http://img834.imageshack.us/i/jt6h.jpg/)
