Radio Equipment => 2.4Ghz 35Mhz => Topic started by: weavo56 on February 27, 2014, 03:59:14 AM
Title: New antenna for Tx ?
Post by: weavo56 on February 27, 2014, 03:59:14 AM
I have a 9XR   Turnigy  Tx would this antenna work better than the one that came with it ?
(http://s23.postimg.org/7ewowi7vb/Tx_antenna.jpg) (http://postimg.org/image/7ewowi7vb/)
Thanks  Graham
Title: Re: New antenna for Tx ?
Post by: chris-s on February 27, 2014, 09:19:26 AM
I'm pretty sure the antenna on the 9xr is built in, so without a bit of modding that won't just 'bolt on' if that's what you meant. But sure, if you mod it that would work, at least in principle depending on the nature of the actual antenna.
Chris
Post by: rob.thomson on February 27, 2014, 09:21:39 AM
The 9xr has an internal antenna,  but it only works with modules built to use it.
So depends on what module you use.    Most have their own antenna.
Post by: weavo56 on February 28, 2014, 08:49:06 PM
Sorry guys , forgot all about that I have a Fr SKY  DJT Telemetry   ACCST module in the back I thought it could replace the antenna on the module .
I have swapped them just to test if it works but not at any distance .
Graham
