Video Equipment => FPV Antennas => Topic started by: weavo56 on March 22, 2014, 03:42:06 PM
Title: Wire lengths for skew planers at 5.8Ghz ?
Post by: weavo56 on March 22, 2014, 03:42:06 PM
Does it make a difference if you make a skew for 5800  and use  say 5705  as your ch freq on another Tx ?
Or should you make them for a set ch freq ?
Graham
Title: Re: Wire lengths for skew planers at 5.8Ghz ?
Post by: Coyote on March 22, 2014, 06:23:24 PM
The Skew`s have a very wide band of usage so that`s absolutely fine doing that
Post by: weavo56 on March 22, 2014, 09:12:01 PM
Thats great , thanks mate will make some to 5800  .
Graham
Post by: bignose13 on March 22, 2014, 09:32:46 PM
Graham
If your using the skew you had off me then it'll go from 5700 all the way to 5900,
Post by: weavo56 on March 22, 2014, 11:48:44 PM
Hi ,  yes got that on the Go Discover .
I have a mix of vtx's    32  & 8 ch   Tx  so when I looked at the ch's being used  I thought there might be a problem.
Will have a go at doing them at 5800  and see .
Cheers  graham
