anyone set their funjet up with the fy21ap ap117, cant seem to get the ailerons and elevator to work on both wings when i am in ABM , they only work on one ,
Hi,
Don't know if it's any help but page 18 of the PDF instructions says something about Delta wing aileron elevator control that a jumper has to be installed at position 10/CD
lol , yep that did it !!! 12 hours of scratching my head , 10 seconds sticking a jumper in!!! must learn to read manual correctly in future. cheers pal
I am about to fit one to a ritewing, but the instructions show the jumper in 2 different positions. The first drawing has the jumper virticle in row 10 across D + C, the second has it horizontal on the bottom accross 9 + 8. Anyone know which is correct?????
Thanks Ian
based on the two posts above yours I say 10 C+D it seems to have worked like that for Aarons elevons.
I am in the process now of purchasing the autopilot and soon will have it installed in my funjet, if it all works out, I shall be using it in a twinstar or skywalker, cant decide!!!
Hi Giys.
I have 2 fy21ap ap117 setups, on my new one I have mounted the FY21AP without its box, it was easier to fit it in a small cavity, where it doesn't touch anything in the plane which will intrigues vibrations. + it was lighter
will I'm on the subject, it is recommended that a separate battery is used on this setup for the OSD and camera, but on the plane that I'm fitting this one on its only small, so I won't to see if I could use the same flight battery, I was wondering is it beter to get power before it gos through the volt sensor or as it comes out.
thanks.
:) G
