Next job , im going to use the velcro strips method to keep the wings together .
Whats the strongest glue to stick the velcro to the foam ?
Graham
UHU Por is the main contact glue for foam and it can be pretty strong if you let it cure before you start stressing it. A stronger option in my opinion would be gorilla glue but it's messy and if u got some cheap arse velcro it will go through the velcro backing but if you put just the teeniest bit and apply pressure while curing it's super strong and you will pull the foam away before the glue lets go.
Or good old 2 part epoxy works well
Thanks guys , I was hoping to use UHU but thought it was for foam only , got gorrilla too , could epoxy be too brittle ,but its not going to flex in that pos so might use epoxy , thanks .
Graham
Done the job today i used the UHU por and sticky backed velcro on the wings (furry part ) and will use the hooks thriugh the body .
So sticky and UHU should hold :D :D
G W
