General Category => Manufacturers Section => Topic started by: micarus on May 01, 2014, 04:01:41 PM
Title: Warning for anyone buying a Sky Mule from H/K.
Post by: micarus on May 01, 2014, 04:01:41 PM
Got my SkyMule on Monday and got all the r/c gear in for the maiden which was yesterday, the plane is a cracker and took off nicely, a bit of a trim then a few gentle circuits and a gentle landing , fine so far! opened up the throttle and all hell breaks loose , the port motor and pod broke loose and before I got it shut down the prop tore across ripped open the side of the fus'  charged over the top of the wing and broke the starboard prop. a nice aircraft messed up because some lazy stupid sod didn't put enough glue on the thing.   AAAAARG!!!.
Nw trying to send photos the H/K to try and get some sense out of them .
So if you buy one of these planes just make sure and epoxy or hot glue the motor cowlings on before you run it .
    This is in my opinion a good plane as long as you check the  glue joints
        Cheers  MIKE.
Title: Re: Warning for anyone buying a Sky Mule from H/K.
Post by: krikey on May 01, 2014, 04:59:57 PM
Oh No!
Chinese QC strikes again!
Post by: ClippedWing on May 01, 2014, 05:23:24 PM
Ouch mate that sucks!
I hate it when an airframe is ruined!
Post by: BlueFlyer on May 01, 2014, 05:45:18 PM
oooh, gutted!!
one of the main reasons I tend to only ever buy these models in kit form.
feel for you mate.
Post by: bignose13 on May 01, 2014, 05:59:47 PM
And me Chris, just not worth trusting the old chinky workmanship
Post by: Charliewalker on May 01, 2014, 06:42:04 PM
it's cos they're so small, they cant see the top of the bench!
seriously though, sorry to hear that.
Post by: mp66 on May 01, 2014, 06:44:53 PM
It is always worse when the damage is not your own dumb fault...
Post by: FPVSteve on May 01, 2014, 07:00:18 PM
Ouch sorry to hear - am I the only one that thinks having the motor mounts glued on on a puller is a bad idea?
Post by: Gundummy on May 01, 2014, 07:50:38 PM
.... note to oneself... add even more glue to the gluey mess that makes up a glued motor cowling......
Post by: micarus on May 02, 2014, 01:49:07 PM
Thanks for the "Condolences " fellas , I think I may just fix it up and not go through the hasle with H/K.
I won't have it for ages otherwise.
                   Cheers  MIKE. ;D
Post by: Chris in Kabul on May 02, 2014, 05:31:40 PM
QuoteOuch sorry to hear - am I the only one that thinks having the motor mounts glued on on a puller is a bad idea?
I don't think I've ever seen another way to fix a motor on the front whether IC or electric. Former F1 is usually glued to the fuselage before bolting in a motor and mount.
Post by: FPVSteve on May 02, 2014, 08:19:28 PM
Shouldn't it sort of hook around the rear of a firewall or something so that it becomes a physical connection rather then just adhesive.
Post by: Gundummy on May 02, 2014, 08:32:44 PM
QuoteShouldn't it sort of hook around the rear of a firewall or something so that it becomes a physical connection rather then just adhesive.
My motors "bolt" to the motor mounts which is then embedded into the foam via slots - i'm 99.9% sure that mine arn't going anywhere!!! really suprised these came away?
GD
Post by: micarus on May 05, 2014, 10:08:19 AM
There was no fault in the design guys , just a lack of glue :+ otherwise it's a cracking plane ;D
     I have sorted mine out now and hope to fly it this week , then when I'm happy with the trim I will fit my F.P.V gear on it.
B.T.W it's amazing what you can cover up with stickers :laugh: :laugh:
            Cheers  MIKE. :)
Post by: benitoculito on November 19, 2014, 09:56:29 PM
Was great to find this little thread, have been hovering over the buy it button for the Skymule. Looks  like a great plane, much room inside, what battery/flight times do you get ?
