Video Equipment => FPV Antennas => Topic started by: Ynot6 on May 26, 2014, 08:47:41 PM
Title: lh polarized?
Post by: Ynot6 on May 26, 2014, 08:47:41 PM
i know most people use the odd numbered channels to avoid cross talk, has any one considered using left hand polarization to use the even numbered channels? i would certainly be up for using them myself.
Title: Re: lh polarized?
Post by: mike on May 26, 2014, 10:31:39 PM
i´m using LHs for over a year now... still havent met someone who´s using the same "direction"^^
Post by: Coyote on May 26, 2014, 10:36:38 PM
I use LH antennas exclusively now because I fly with two RH pilots, makes things much easier
Post by: mp66 on May 26, 2014, 10:38:47 PM
Does the rh / ls stop any interference or just make it less?
I fly with a rh like my only other buddy, maybe we need to talk..
Post by: Coyote on May 26, 2014, 10:53:22 PM
When your on LHCP and someone is flying with RHCP there is first the channel separation, then on top of that the mismatch in polarization also gives you -30dB rejection as well. So you get absolutely no signal from the other flyer. If you were both on the same channel you still get the -30dB but if your both close you will pick up each others transmissions.
Post by: mp66 on May 26, 2014, 11:10:13 PM
Thanks,
A pretty simple way of getting less problems..
Post by: Coyote on May 26, 2014, 11:38:39 PM
Yup, stacking the odds in your favour is always good :)
Post by: Ynot6 on May 27, 2014, 06:10:29 PM
seems i'm miles behind (as usual).  :facepalm: but good to know the idea already works  :D
