Members => Build Threads => Topic started by: pk-surfing on October 27, 2014, 09:43:54 PM
Title: PK's Z3
Post by: pk-surfing on October 27, 2014, 09:43:54 PM
PK's Ritewing Z3
I was fortunate to get one of the first of the Z3's thanks to the hard work put in by Dogzilla but then work took over so the build went on hold for a few weeks.
It's finished now and ready for it's maiden flight if the weather is ok this coming weekend
Motor is Turnigy Aerodrive SK3 - 3542-1250kv
10x6 APC prop
Servos Hitec HS5485
Vector flight controller with air speed indicator
IRC 2.4 vtx
Turnigy Plush 60a esc at the moment but getting swapped for a YEP 80a esc
the plane was sprayed with PlastiDip white ruberised paint then the clear lam added, the spray paint gave a nice coating on the foam and the lam stuck to it very well.
I had been concerned that it wouldn't balance out with two 4S 3300 lipos up front (I have a few of these for my Z2) but once I had ther motor mounted as far back as I could and the prop on it all balanced spot on, however most likely will fly it using my 4S 5000 hard pack lipos.
I'm also going to turn the motor round and bring it in board on the mount as this will give better support and minimise the chance of motor vibration (prop is balance)
piccy of the underside (daughters writing on the tool box... from when she was 7 !)
(http://s30.postimg.org/w1zhwfa9p/Z3_underside.jpg) (http://postimg.org/image/w1zhwfa9p/)
couple of bead headed pins at the C of G point, easy to feel
(http://s30.postimg.org/cvqw6zj5p/Z3_pins_for_Cof_G.jpg) (http://postimg.org/image/cvqw6zj5p/)
Elevon horns and carbon fibre rods
(http://s27.postimg.org/3nu0onmy7/Z3_elevon_horns.jpg) (http://postimg.org/image/3nu0onmy7/)
ball joint connector at the servo's (Hitec HS5485)
(http://s22.postimg.org/tyz80e0al/Z3_servo_ball_link.jpg) (http://postimg.org/image/tyz80e0al/)
Vtx in 3D printed holder
(http://s24.postimg.org/qpgnzl6ch/Z3_Vtx_in_holder.jpg) (http://postimg.org/image/qpgnzl6ch/)
Vtx held in with strong grip velcor I had from somewhere
(http://s21.postimg.org/h43ok2k83/Z3_printed_holder.jpg) (http://postimg.org/image/h43ok2k83/)
Short USB lead for easy connection to the Vector flight controller
(http://s28.postimg.org/q0rz27vx5/Z3_usb.jpg) (http://postimg.org/image/q0rz27vx5/)
Vector flight controller and current sensor etc
(http://s8.postimg.org/dt3y8k5nl/Z3_Vector.jpg) (http://postimg.org/image/dt3y8k5nl/)
Receiver, air  speed sensor and the GPS/Magnetometer
(http://s8.postimg.org/64bpakujl/Z3_rec_air_speed_GPS.jpg) (http://postimg.org/image/64bpakujl/)
Hardpack 4S 5000 lipo fits and balances the C of G just nice (use these on my DJ 550)
(http://s27.postimg.org/asz9dru27/Z3_5000_4_S.jpg) (http://postimg.org/image/asz9dru27/)
2no 4S 3300's fit but they have to be kept right back to get the C of G
(http://s24.postimg.org/loigppdnl/Z3_2no_3300_4_S.jpg) (http://postimg.org/image/loigppdnl/)
and a piccy with all the hatches open
(http://s11.postimg.org/wsxbgllqn/Z3_hatches_open.jpg) (http://postimg.org/image/wsxbgllqn/)
Title: Re: PK's Z3
Post by: Coyote on October 27, 2014, 09:47:29 PM
That's very smart Paul, love the paint job :)
Title: Re: PK's Z3
Post by: bignose13 on October 27, 2014, 09:49:04 PM
Looks the mutz nutz mate
Title: Re: PK's Z3
Post by: Dizzy on October 27, 2014, 10:18:40 PM
Lovely job love that paintwork a work of art in itself  :D
Title: Re: PK's Z3
Post by: Ratty on October 27, 2014, 10:35:30 PM
Looks great PK.
Pretty much the exact same set up as I am using. Let us know how the maiden goes and what flight times you get ect please.
Title: Re: PK's Z3
Post by: Billy_boy_2010 on October 27, 2014, 10:48:49 PM
Wow fantastic.
Out of interest- why have you chosen 1 x 5000 over two 3300s?
Title: Re: PK's Z3
Post by: Badlands on October 27, 2014, 10:48:58 PM
Very well thought out build Paul.
Where did u get your carbon fibre pushrods from?
Title: Re: PK's Z3
Post by: pk-surfing on October 27, 2014, 11:34:50 PM
Quote from: Badlands on October 27, 2014, 10:48:58 PM
Found them on Ebay, this seller does 2mm and 3mm CF so I got a set of each to try and decided on the 2mm.
http://www.ebay.co.uk/itm/2mm-Push-Rods-Carbon-Fibre-4-Clevises-Couplers-/160819275275?pt=UK_ToysGames_RadioControlled_JN&hash=item257193660b (http://www.ebay.co.uk/itm/2mm-Push-Rods-Carbon-Fibre-4-Clevises-Couplers-/160819275275?pt=UK_ToysGames_RadioControlled_JN&hash=item257193660b)
item number 160819275275 if that link doesn't work
Very stiff and it means I have the 3mm ones to use on a Z2 kit still in the box (spare for when I smash up my first one  :) )
PK  :)
Title: Re: PK's Z3
Post by: pk-surfing on October 27, 2014, 11:40:31 PM
Quote from: Billy_boy_2010 on October 27, 2014, 10:48:49 PM
Wow fantastic.
Hi Billy,
Not decided for definite just yet but the single 5000 means I don't need to use a 'Y' connector and it's a bit lighter than the two 3300's so will probably use that for the maiden at least to keep it light for the first launch.
Benefit of the two 3300's is they fit nice and snug in the space so no sideways movement, and give me that bit extra capacity.
I still need to decide how to strap the lipos in and stop them moving forwards, I usually superglue a velcro strap across the battery bay as well as velcro on the lipos anf floor, job for tomorrow night.
PK  :)
Title: Re: PK's Z3
Post by: iPeel on October 28, 2014, 08:17:44 AM
Quote from: pk-surfing on October 27, 2014, 11:40:31 PM
You also get lower current draw per battery when you open up the taps, battery C ratings are a bit like depth ratings on watches. I find on a 9x6 mine draws just under 60a on full power.
Nice build BTW, that coating's going to look great when the sun's reflecting on it!
Title: Re: PK's Z3
Post by: mark1975 on October 28, 2014, 08:18:50 AM
Looking very nice Paul..
Title: Re: PK's Z3
Post by: pk-surfing on October 30, 2014, 10:45:37 PM
A couple more piccy's,
I've added some more bling on the wing, blue reflective film on the top side
(http://s18.postimg.org/922rlxwb9/Z3_bling_on_the_wing.jpg) (http://postimg.org/image/922rlxwb9/)
And I've hot glued the camera menu button board up front in the front bay, theres a piece of aluminium angle with foam buffer epoxied to the underside of the ply battery plate and to the bottom of the bay to act as a stop when I'm putting the lipo in.
(http://s18.postimg.org/bidrr9t5h/Z3_cam_menu_board.jpg) (http://postimg.org/image/bidrr9t5h/)
Just need to calibrate the Vector compass and a bit of decent weather and its going to get thrown skywards  :)
PK  :)
Title: Re: PK's Z3
Post by: Ratty on October 30, 2014, 10:50:37 PM
Good luck with the maiden.  :D
Title: Re: PK's Z3
Post by: Billy_boy_2010 on October 30, 2014, 10:55:55 PM
Looks fantastic.
Out of interest- why haven't you chosen a greater distance between the Rx and video Tx.
Too tricky with the removable wings?
Close range plane only?
Title: Re: PK's Z3
Post by: mr_s81 on October 30, 2014, 11:02:55 PM
Loving the design on the top! Very nice plane, looks very purposeful!
Title: Re: PK's Z3
Post by: pk-surfing on October 31, 2014, 12:07:53 AM
Quote from: Billy_boy_2010 on October 30, 2014, 10:55:55 PM
Looks fantastic.
I had originally intended to put the Vtx far out on the outer wing but I've used my UHF gear for about 3 years now and (touch wood) it's never given any problems on planes and multis using 1.2, 2.4 and 5.8 vtx's so with this plane having detachable outer wing panels I decided to see how it goes.
The receiver is a UHF Scherrer on 433 and the Vtx is on the 2.4 band so this choice of frequency will play ok with each other as harmonics (from the 2.4 vtx) only go up the frequency scale as multiples not dividing down.
There is a chance of the 2.4 vtx simply overloading the preamp section of the 433 receiver however I'm using the latest Scherrer receiver and it is recognised as having a very well designed input stage, bench testing of this receiver with the vtx right next to it didn't cause any glitching with servos connected.
The separation between the receiver and the vtx antenna is 250mm at the moment, the intention is to see how it performs as existing then if any problems I'll move the vtx onto the outer wing and use one of the Emcotec multi cable connectors I got for this build.
PK  :)
