hi my e-sky ek2-0704 is't working in my elevator channel but works in my aileron channel. All it does when plugged into elevator (ch2) is flash and never stop. what am i doing wrong? :'(
is the trim on your aileron channel in the middle? i would think it is and it isnt on the elevator which is why i thinks its not arming.
i will quickly try
nope still isn't working
Not initialising normally means the models not steady when its turned on, trims arnt neutral or a dud gyro
all trims are neutral and the gyro works fine when plugged into aileron and elevator works fine when not plugged into the gyro.
Are your alieron and elevator servos different brands ?
yes but i didn't realise that would make a difference.
It shouldn`t normally, but you say it works on one but not another so i figured the only varible could be servo brand. Same rx, same gyro, different servo.
I`d swap the servo, or try the gyro plugged into evlator, but a different servo plugged into the gyro`s output
thanks i have swapped them and they are now working
Cool, nice 1 :)
