General Category => General Discussion => Topic started by: marcin.gala on July 10, 2011, 06:35:22 PM
Title: DL kick failsafe.
Post by: marcin.gala on July 10, 2011, 06:35:22 PM
Made couple flights today ,everything was fine till last flight.
Was quite high and away from base was OK ,then i came back and starts flying around base...about 10/100 metres away and a up to 100m altitude..notice my DL
starts kicking failsafe...everytime I use full throttle.
I land immediately and check all connections ,everything was fine ,so check on ground..and notice failsafe kicks onyl when doind full throttle...
Failsafe kick for less then 1second...plenty times.
ANY IDEAS WHAT CAN BE WRONG...FLY WITH THIS SETUP MANY TIMES...EVEN FLY AND BACK "SAME FLIGHT" WAS QUITE LONG AND HIGH....XXXXm and XXXXm BEFORE THIS HAPPEND.
CHECK RSSI --DURING THESE KICKS AND SEEMS IS OK SHOWS 100% ALL THE TIME.
Title: Re: DL kick failsafe.
Post by: Coyote on July 10, 2011, 09:20:23 PM
Sounds like your rx power ( bec ) is dropping out due to insufficiant volts causing rx to switch off
Post by: g.collins on July 11, 2011, 02:49:51 PM
I tried one of these when I was getting brownouts on my helly, it didn't work, I looked on some of the forms and they said that you would need a bank of them to get enuf power.
regards G
