Members => Build Threads => Topic started by: Miles on July 23, 2011, 11:42:22 PM
Title: FoxJet Build Log
Post by: Miles on July 23, 2011, 11:42:22 PM
At the moment, just pics, will annotate later
BW
(http://s1.postimage.org/eo21ublw/image002.png) (http://postimage.org/image/eo21ublw/)
GMinty fox from SWM, 14.99 with 2 servos, £20 inc postage, but they only spent £2 on the stamp???
(http://s1.postimage.org/eo3pdo3o/image003.png) (http://postimage.org/image/eo3pdo3o/)
So, includes the green Wing, Elevator and Canopy
(http://s1.postimage.org/eo5cx0lg/image004.png) (http://postimage.org/image/eo5cx0lg/)
Built
(http://s1.postimage.org/eo70gd38/image005.png) (http://postimage.org/image/eo70gd38/)
Weighs in at 51G, more that Gordons orange one?
(http://s1.postimage.org/eolwahj8/image016.png) (http://postimage.org/image/eolwahj8/)
Mark COG on wing
(http://s1.postimage.org/eo8nzpl0/image007.png) (http://postimage.org/image/eo8nzpl0/)
Remove Canopy with something blunt
(http://s1.postimage.org/eobz2ekk/image009.png) (http://postimage.org/image/eobz2ekk/)
Canopy off
(http://s1.postimage.org/eofa53k4/image011.png) (http://postimage.org/image/eofa53k4/)
There's a 9G bearing
(http://s1.postimage.org/eogxog1w/image012.png) (http://postimage.org/image/eogxog1w/)
Remove it, I levered it out with a flat head screw driver
(http://s1.postimage.org/eoil7sjo/image013.png) (http://postimage.org/image/eoil7sjo/)
9G...
(http://s1.postimage.org/eok8r51g/image014.png) (http://postimage.org/image/eok8r51g/)
Brng it down to 42G
(http://s1.postimage.org/eonjtu10/image017.png) (http://postimage.org/image/eonjtu10/)
Now Cut out the tab that holds on the canopy, I used a Scalpel and sandpaper, but you can melt it out with a soldering iron.
(http://s1.postimage.org/eop7d6is/image018.png) (http://postimage.org/image/eop7d6is/)
The motor :) this produces 250G~300G of thrust with a 4X5 Prop on a 2 cell batt, shoud go quite quickly.
(http://s1.postimage.org/eosifvic/image019.png) (http://postimage.org/image/eosifvic/)
Weighs in at 16G, 1G more than they say, shouldn't be an issue though...
(http://s1.postimage.org/eou5z804/image020.png) (http://postimage.org/image/eou5z804/)
Annoyingly, it is a front mounted motor so I originally designed a piece of ABS plastic to mount it on, however it comes with this Triangle Mount, which is stronger than my mount :)
(http://s1.postimage.org/eovtikhw/image022.png) (http://postimage.org/image/eovtikhw/)
That adds 1G
(http://s1.postimage.org/eoxh1wzo/image025.png) (http://postimage.org/image/eoxh1wzo/)
I was thinking I could mount it with some 2' Carbon Tubes with screws in them...
(http://s1.postimage.org/eoz4l9hg/image028.png) (http://postimage.org/image/eoz4l9hg/)
... like that, they are stuck in with Araldite :)
(http://s1.postimage.org/ep0s4lz8/image029.png) (http://postimage.org/image/ep0s4lz8/)
My amazing spacer method, it actually worked quite well
(http://s1.postimage.org/ep2fnyh0/image030.png) (http://postimage.org/image/ep2fnyh0/)
Adding the third leg
(http://s1.postimage.org/ep5qqngk/image031.png) (http://postimage.org/image/ep5qqngk/)
Fitted with an easystar prop
(http://s1.postimage.org/ep7e9zyc/image032.png) (http://postimage.org/image/ep7e9zyc/)
It has one of those Prop saver rubber band thingys
(http://s1.postimage.org/ep91tcg4/image034.png) (http://postimage.org/image/ep91tcg4/)
Bck to the plane, I had marked out areas to cut for the servo and ESC... I cut around the edge with a Scalpel, then puled out small pieces of foam with a pair of wire snipper's. That is the Aileron Servo
(http://s1.postimage.org/epapcoxw/image035.png) (http://postimage.org/image/epapcoxw/)
I then drilled out the holes for the Motor, they don't look straight but they are...
(http://s1.postimage.org/epfnyqf8/image039.png) (http://postimage.org/image/epfnyqf8/)
I coated the inside of the hole with araldite and stuck it in, I tried to make it as parallel to the plane as possible...
To be cont'd
BW
Title: Re: Another Fox
Post by: Coyote on July 24, 2011, 10:26:56 AM
Looks good so far bud, another Fox, these are really popular this month :)
Post by: Miles on July 24, 2011, 10:42:25 AM
Quote from: Coyote on July 24, 2011, 10:26:56 AM
Yeah lol, I needed a plane that is small enough to take with me to croatia, I am building it to flat pack :)
BW
