Members => Build Threads => Topic started by: Coyote on May 08, 2012, 09:42:10 PM
Title: Coyote`s Skywalker 1900
Post by: Coyote on May 08, 2012, 09:42:10 PM
Hi guys, build number two is underway. I`ve not got far into it but I have made a start so here we go :)
Skywalker 1900
Motor : Overlander 980kv
Prop : 9x6
Esc : Turnigy Plush 40 Amp
Lipo : 1x/ 2x 5000 mah 4S
Osd : FY Hornet OSD
Autopilot : FY31AP
Fpv
Camera : Seawolf 690 tvl
Vtx : ImmersionRC 5.8ghz
Gopro : Yes
The 1900 Skywalker is in most parts apart from the wing length no difference to the V5 apart from the camera pod. So no need to show loads of pics or parts you have already seen hundreds of times over.
This build is going to be a lot different to my last few walker builds, a lot different, so lets begin our journey :)
Ill start at the first mod`s
First was the carbon tail rod, last time I left it how it was and ended up with a slightly off tail that wobbled, tape did help loads, but had to go down a stronger more rigid route this time. I ordered 0.5mm x 10mm carbon strip. I cut half way down the carbon rod and epoxied it in place making sure cables were inside the tube but clear
(http://s18.postimage.org/mvix9g7xh/IMAG0159_1.jpg) (http://postimage.org/image/mvix9g7xh/)
Next up was something I wanted to do ages ago, and I have on the X8. Make a ply base floor for securing the lipo properly and to give the FY31AP a solid base too.
I also have made a second base for the Hornet OSD higher up, so its not wasting space, easy to access ( both hatches cut out )
(http://s16.postimage.org/d4dbuyam9/IMAG0160_1.jpg) (http://postimage.org/image/d4dbuyam9/)
I made up the camera pod, which I like, but they cocked up the laser cutting so either Skywalker or 1900 is the wrong way around when stuck together.
I added servo`s for the tail too and glued the carbon etc in place for tomorrow
(http://s7.postimage.org/vqhf7i2af/IMAG0162_1.jpg) (http://postimage.org/image/vqhf7i2af/)
Title: Re: Coyote`s Skywalker 1900
Post by: g.collins on May 08, 2012, 11:04:50 PM
looking good mate, I have don a similar thing with the base of my walker.
;) G
Post by: Coyote on May 09, 2012, 01:41:13 AM
As the night moves on.........
Next mod was the nose, it now sports a big open mouth :)More on that bit later in the thread
(http://s14.postimage.org/6hiyd96t9/IMAG0163.jpg) (http://postimage.org/image/6hiyd96t9/)
After that comes the wing, I hate the rubber band means of securing them, very old school, rubber perishes in UV etc. So I took a knife to my wings and cut them down
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0165.jpg)
I glued them together adding dowels for extra strength, then I added dowels to the wing saddle too, the new part will now be permanently glued to the saddle.
Three main reasons :
1) the motor mount is a particular weak spot, with the new piece glued to it, it will now be a whole lot stronger
2) No rubber bands to forget or fail in flight
3) Another weak spot is to the front of the saddle, now it wont be :)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0164-1.jpg)
I have not decided wether or not to use the space below the saddle, I don`t think I will be though
Post by: Coyote on May 09, 2012, 01:57:43 AM
Thanks G, this ones going to be a bit different this time, hopefully for the better :)
Post by: bignose13 on May 10, 2012, 07:14:10 AM
Like the idea of a ply base Ian, will defo be doing this on my next walker
Post by: wgt40w on May 10, 2012, 12:28:37 PM
What ply do you use - 3mm ??
Post by: Funky Diver on May 10, 2012, 12:43:24 PM
Looking good Ian, looking forward to the rest of the build!!
Quote from: Coyote on May 09, 2012, 01:41:13 AM
Now that's extreme clipped wing mod right there :D
Post by: Coyote on May 10, 2012, 01:21:34 PM
Thanks Simon, more ply in now, next update shows drastic mod :)
The ply is 3.6mm wgt40w, light enough but has a decent amount of strength too
Cheers Rich, more to come this afternoon :)
Post by: Coyote on May 10, 2012, 05:23:14 PM
Time for an update :)
I have now finished adding the ply, I mentioned on chat last night that my walker looked like a fish................. I was`nt kidding :)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0166-1.jpg)
Previous builds really annoyed me with the Go Pro always being in shot of my flight cam, I love the Go Pro footage but it was spoiling my experience having a face full of its bum in my view. So I have cut the nose off and made my own Go Pro holder. Its pretty strong, holds the Go Pro back out the way for protection, but does not show up in the recording
Next up was the Vtx to plane wires, after a few builds now, from time to time I have needed to swap wires about. With the normal setup feeding wires through the glued fuse was a nightmare, so I installed a carbon tube in so it should be a whole lot easier now
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0167.jpg)
More wood has now gone in, two brackets and three straps, the straps are for securing up to 2x 5000 mah lipos. The second lipo can be any size because it is sat on the CG. To do this meant of course I could not mount anything on the walkers base. No problem, but that can wait ;)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0168-1.jpg)
The final mod for this update, I turned to FPVUK`s own build Guru Mr SteveW :)
I liked his removable landing gear especially when hand launching can be hit and miss by yourself, so I have started the wheels build as per Steves demo :)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0169-1.jpg)
More to come
Post by: FPVSteve on May 10, 2012, 07:23:06 PM
Heh nice ... credit needs to go to ElectricMick though, I just had the idea to velcro them to my plane. Incidentally, where did you get those wheels from? I need some fatter larger ones.
Post by: wgt40w on May 10, 2012, 07:33:58 PM
Good choice of wheels here !
http://www.ebay.co.uk/sch/Aeroplanes-/19163/i.html?Type=Parts%2520%2526%2520Accessories&_nkw=wheels&_catref=1&_dmpt=UK_ToysGames_RadioControlled_JN&_sac=1&_trksid=p3286.c0.m1538 (http://www.ebay.co.uk/sch/Aeroplanes-/19163/i.html?Type=Parts%2520%2526%2520Accessories&_nkw=wheels&_catref=1&_dmpt=UK_ToysGames_RadioControlled_JN&_sac=1&_trksid=p3286.c0.m1538)
Post by: Coyote on May 10, 2012, 07:39:21 PM
Stockton Modellers Steve : http://www.stocktonmodeller.co.uk/ (http://www.stocktonmodeller.co.uk/)
Post by: FPVSteve on May 10, 2012, 08:28:56 PM
Meh, postage is same price as the wheels, lol.
Post by: Coyote on May 10, 2012, 09:13:09 PM
OK now for some toys to go in................
With the base being left available for the lipo`s I have made two brackets higher up in the fuse. This is to hold a board with my electronics on. The problem being that high is any adjustments to FY31AP would mean I have no access, this is solved by the electronic base being velcro`d to the brackets. The whole board can pull down, any adjustments made and put back into place, the velcro also helps with vibration dampening fr the FY31AP as well
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0171-2.jpg)
This is the flight side of the board, Telefly OSD yet to be added. Nice neat and unobstructed
Next on the other side is the power side :
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0172.jpg)
4S power comes in and distributed to a variable step down power supply, a 7.5 Amp Turnighy Bec and the Chainlink Rx is to the rear of them. This way power and signals, 12, 14 and 5v all kept separate from each other too
So with the board in place, here is how its looking so far ...........
Loads of space for lipo`s, FPV equipment well clear of damage, GoPro mounted with a clear view and out of view from FPV camera
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0174-2.jpg)
Post by: g.collins on May 10, 2012, 09:30:29 PM
Some nice ideas their mate, after your first flight Ian you may need to adjust the pots, can you get to them OK.
;) G
Post by: Coyote on May 10, 2012, 09:32:51 PM
Yes, the board just pulls down G
I can at any point remove all the FPV board if I want to do anything with it, then just put it back in again :)
Post by: FPVSteve on May 10, 2012, 09:36:02 PM
You've outdone yourself with this build Coyote, excellent work. Nice to see you "honing" the SkyWalker based on previous builds too - this one should be a cracker.
Post by: Pr][nCe on May 10, 2012, 10:36:54 PM
ditto, great stuff.  :P
Post by: g.collins on May 11, 2012, 11:24:54 AM
Hear you go Ian, this is the Step up/down I told you about, im sure it was PK that put me on to it the one on the left is a step down and the other is a step up and down, the bag has the details to fined out more info.
;) G
(http://i1217.photobucket.com/albums/dd397/itsalivecollins/stepupdown.jpg)
Post by: Coyote on May 11, 2012, 12:23:45 PM
That's what I have in this Walker G, its a step down only though I think
Post by: g.collins on May 11, 2012, 05:37:12 PM
yes yours is the one on the left, that is just a step down only, the one on the right is a step up and down.
;) G
http://www.dpcav.com/xcart/Adjustable-Voltage-Regulator-1-35V-SEPIC-Type.html (http://www.dpcav.com/xcart/Adjustable-Voltage-Regulator-1-35V-SEPIC-Type.html)
Post by: Coyote on May 18, 2012, 01:36:01 AM
Not a lot more done, but nearly there.
I fitted the Telefly into the top of the fuse, it shares the GPS with the FY31AP but sorry G I forgot to take a picture :(
That meant I could then seal up the fuse, I did, then covered the fuse / tail and finished the wings to give them loads more strength. I added the FPVUK.org stickers and being vain again even painted the ply bracket on the tail white, then cut another sticker so it still reads right when you look down on it :)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0181.jpg)
Sad I know :)
My 1450kv Overlander was fitted with a 9x6 prop and the Esc mounted on top because I dont have access to its normal location underneath
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0182.jpg)
Because the 1900 wings only have one spar I also glued in ply wing joiner / liners so the wings always fit straight and true
Both hatches were attached and a hole cut for my on off switch so I dont need to open it up, but its sunk in behind the hatch so cant be knocked either
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0184.jpg)
Insides looking good, the whole bottom free for lipos, everything secure above
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0185.jpg)
So far they are looking a nice pair :)
(http://i108.photobucket.com/albums/n39/cayote64/IMAG0177-1.jpg)
Still and the only thing to do is fit GWS 125 1T for camera, camera itself and tilt, sand down the edges of the ply and its ready to go :)
Post by: Dantian on July 05, 2012, 09:54:03 PM
Hi Coyote
Just nearing the end of my 1900 build and was wondering if you would be able to share your CoG point with me. I've searched around but not really found a real answer to this?
Regards
Dan
Post by: Coyote on July 06, 2012, 12:24:49 PM
Yeah sure, start with CG at 10.5cm from LE of wing for setup and trimming, then when your happy 11.5cm will improve its glide
Post by: bignose13 on July 06, 2012, 01:54:58 PM
Looking nice mate
Think I prefer it to your X8.........Have I just swore
Post by: Coyote on July 06, 2012, 09:27:21 PM
A few more bits and pieces done. I was not happy with the tail as with all Skywalkers the tail is just too weak, it was tracking and that effected the AP's effectiveness. So as my last build two carbon rods added between the end of the tail and the horizontal stab and I added a spar down the tail section. Solid as rock now :)
(http://i108.photobucket.com/albums/n39/cayote64/DSC_0014.jpg)
Next I added tilt for my head tracker. That is if I can get it to work in proximity to my Dominantors
(http://i108.photobucket.com/albums/n39/cayote64/DSC_0015.jpg)
Post by: g.collins on July 08, 2012, 05:52:45 PM
looking great Ian.
I cant what to get my walker back in the air. now flying for a couple of weeks now, whether and work, Do!
:+ G
Post by: Coyote on July 08, 2012, 06:11:46 PM
hanks Gordon, where have you been fella ?
