The new Naza / Disco build has been flying well..
but it has felt a bit 'fly it like you stole it' in manual mode,
in atti and gps it is solid.
anyway went to the big field (that was half ice) today and had a test fly in some open space.
its 4th FPV flight, i start flying it quite hard in manual mode.....
(http://s7.postimage.org/66hzwlsuv/2012_12_13_16_45_38.jpg) (http://postimage.org/image/66hzwlsuv/)
what im more bothered about is the motor wire :(
(http://s15.postimage.org/f5rb1wion/2012_12_13_16_45_58.jpg) (http://postimage.org/image/f5rb1wion/)
hope it lives to fight another day, but i can see a broken wire,
fingers crossed i can do something with it..
simon.
Oooops indeed :) It should still be fine to use the motor with just one of the wires snapped, the rest will carry the current fine
Quote from: Coyote on December 13, 2012, 06:51:33 PM
do you think it will be ok?
they are only one solid wire at the esc end?
i was thinking i would strip the silcone back,
and re-wire to that point if i could? or 'fix' it with a blob of solder?
would only 2 of the 3 windings work as it is?
i thought the copper was insulated? so it wouldnt ?
simon.
Stupid me, yeah you will have a winding down. You could try a repair on it but it may be better just replacing it
yep... :(
