Graupner MZ 24 2.4ghz 12 channel
Started by Coyote, April 27, 2014, 07:34:35 PM
This looks a really nice bit of kit. £300 though, but you pay for the name and quality.
Graupner/SJ mz-24 HoTT 2.4GHz 12 Channel transmitter is designed with Graupner/SJ's unique telemetry technology that supports Bi-directional data transmission to give user the real-time information. The use of up to 75 frequency hopping channels ensures extreme operating reliability and immunity to external interference. Through the telemetry function, you may check receiver's consumption voltage, temperature and program the telemetry data. By using optional sensor, brushless control + T ESC, or HoTT sensor module, you may check the real-time data such as RPM, voltage, current, temperature, and warning in transmitter. mz-24 has 30 model memories and it is suitable for any aircraft, Additionally, with up to 12 available channels, built-in telemetry with data logging capabilities and 3.5" large TFT LCD with specialized touch panel, mz-24 is the obvious choice for anyone who needs a high quality 12 channel radio.
Key Features:
    HoTT (HOPPING TELEMETRY TRANSMISSION) bi-directional 2.4 GHz technology
    3.5" Full color TFT Touch LCD with specialized touch panel and user friendly interface.
    Smart voice announcement system (Speaker and Earphone) for warnings and alarms at real time.
    Real-time data analysis with optional sensor (GPS, Fuel status, Temperature, Voltage, Current) and sensor board (General air module, General engine module).
    Real-time telemetry analysis for Optional Brushless Control Telemetry ESC such as RPM, consumption current, voltage, ESC temperature, Warning, etc...
    SUMO, SUMD functions ensure the convenient use of gyro and control board.
    Selectable 10ms, 20ms of the signal repetition time for the use of analogue and digital servos.
    Advanced HoTT wired/ wireless trainer system.
    Multi binding receiver system that 2 receivers can be connected in parallel to use additional servos.
    High precision quad ball bearing gimbals (total 8ea) lead the smooth and comfortable stick feeling.
    Standard micro SD Memory cards to share model setup, expand model memory,and check flight log file.
    30 model memories.
    Model copy function for model memories.
Programming Options:
    30 model memories available (Memory extension function, using SD card)
    6 Q. link function
    3 model type (Helicopter, Airplane, Glider)
Helicopter Function
    Q.link function x 6
    6 Swash plate type(1 Servo, 2 Servo 180, 3 Servo 120, 3 Servo 140, 3 Servo(Elevator), 4 Servo 90)
    Pitch Curves (7-point)
    Throttle Curves (7-point)
    Pitch. Throttle Trim function x6
    Swash Limit function
    Swash mix function
    Program mixing x 8 (Liner Program mixing x 5, Curve mixing x 3)
    Throttle mixing function(Aile>>THRO, ELEV>>THRO, RUDD>>THRO)
Airplane Function:
    Q.link function x 6
    14 wing type(Including Delta wing type)
    3 Tail type
    Wing mixing (RUDD>>AILE, AILE>>RUDD, RUDD>>ELEV)
    Throttle Curve function
    Snap roll function
    Aileron Diff function
    Flap MIX function (FLAP, AILE>>FLAP, ELEV>>FLAP, FLAP>>ELEV)
    Flap sett function
    Airbrake function
    Idle Low function
Glider Function:
    Q.link function x6
    14 wing type (Delta wing type included)
    3 tail type
    Flap sett function
    Butterfly function
Graupner/SJ HoTT Features:
    Simple, extremely fast binding
    Range test and warning function
    Low-voltage warning
    Extremely broad receiver operating voltage range from 3.6 V to 8.4 V (functional to 2.5V)
    Fast response time if 10ms is set in PERIOD since four transmitter channels are received at once
    Failsafe, free channel allocation (channel mapping); mixer functions and all servo settings can be programmed simply on transmitter LCD by using telemetry function
    Binding of any number of receivers for channel expansion (max. of 32 channels)
    SUMD, SUMO functions ensures the convenient use of the peripherals through gyro and control board
    Maximum immunity to interference through optimized frequency hopping and broad channel spread
    Intelligent data transmission with correction function
    Extremely fast rebinding, even at max. distance
    Telemetry analysis in real time
    Over 200 systems can be used simultaneously
    Future-proof through update capability via USB interface
    Graupner/SJ Firmware update through GR STUDIO PC Software
Scope of Delivery:
MZ-24 Transmitter
USB PC interface set
USB interface adapter wire
4000mAh LiPo Battery
GR-24L receiver
GR-12L receiver
Manual
USB Cable
SD Card adapter
SD Card case
Micro SD Card
Hard case
USB adapter wire
Neckstrap
Graupner MZ 24 first impressions
liambaker996
I have the mz18 and bloody love it!!
This is my Heli only tx though :-D
a pocket emptyer
and a life long addiction!
frsky taranis, Ezu
Quote from: Clunk84 on April 29, 2014, 03:05:50 PM
Looking at possibly getting one of these where did you see it for £300? Was that with the case and two receivers ?
I cant remember, all I can find is it for £360 now not £300 :(
liambaker996
I believe it's the 18 at around the 300 mark?
a pocket emptyer
frsky taranis, Ezu
