Hornet and carbon spar help please
Started by Hawkview, July 17, 2017, 10:50:28 PM
Hawkview
Hello the good folks of fpvhub
Building my little hornet follow the guidelines and I've run into a slight problem when cutting out the servo area in hitting the carbon spar which you glue in way before doing the servo area cut which is now causing the servo to not sit flush with wing is up by two to three mm up see the pictures.
Any tips or advice please
I would cut the servo hole further forward, using the newly cut out piece to fill the rear over the spar. Then the servo will sink in just fine but you may need slightly longer linkage rods but that's all.
Hawkview
