Testing new fpv aircraft. ST DG1000
Started by littleimp, June 04, 2012, 11:52:30 PM
littleimp
hmm, what happened at the end? Looked like a good flight beforehand, what setup are you using? Love the picture clarity.
Have to say though, the video thumbnail didn't fill me with confidence before I watched it!!! :laugh:
Not a bad start there :) Pan and tilt work well ;)
littleimp
Seems to be some sort of bugger up in the video process in either windows movie maker or youtube. Re-done it with nero vision.
littleimp
Believe it or not the cam & mic are both from one of these.
http://www.ebay.co.uk/itm/320860095317?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1499wt_1392
Inside theirs a sony 600 superhad board cam + a self amplified mic. The cam has no settings board but the sockets their and just used probes to set the cams preferences up touching the pins.
The video system is just a cheap 5.8ghz system. I've added pics to the vid so you can see.
littleimp
Most of the flight is above the ground station though so theirs plenty of ground effect interference but overall I'm happy with the kit.
marcin
littleimp
Yes, the ones available on ebay. Bit of a change too be honest that the copy's improved on the original although it's not as expandable as only has one sensor port. The original remzibi's had overheating issues with 3s batterys as the board was designed for 5v. The copy has a separate tiny power board so this is't a problem. I've aslo added a flytron current sensor to.
