My new diversity relay ground station
Started by Dizzy, May 26, 2013, 09:02:32 PM
The grey plastic box cost me £7 i there is two pairs of vrx,s inside plus my 5.8 relay vtx and diversity unit
The antenna,s come off and its just a robust box that can be carried in a rucksack with the tripod the eagle tree gs is visable the switch,s are heavy duty my larger lipo packs can be used for the power supply with a lipo checker and alarm built in and i did remember to fit a cooling fan this time, the patch and 6db omini can be replaced with a helical and skew for circular the 5.8 is feed to my goggles and my recording station which remains unchanged.
I decided any tilt needed on the patch or helical can be done with the tripod unit this just makes it simpler
I may fit an external vid socket under for a wired pair of goggles at some point
Back to penquin now to finish paint ready for testing :D
dizzy :)
Hubsanman
Cool setup dizzy, its something I can aspire to in the future.
FPV Gives You Wings
Hubsan X4  FPV
1.8M SuperCub  TO FPV!
F450  APM3.1 QUAD  FPV
F330  KK2 QUAD FPV
Quote from: Hubsanman on May 26, 2013, 09:36:17 PM
Hubsanman its taken me nearly two years to get to this stage but its been worth the trouble i started with cheap gear and built on that but really i would have been better off buying quality to start with  :D
but we all have to cut our cloth to suite our income  ;)
dizzy :)
Looks good Dizzy :) Have you use it much yet ? How do you find it ?
Quote from: Coyote on May 29, 2013, 07:18:17 AM
Coyote i have only ground tested it as yet but its there awaiting the penquin now  :) I may try the 2.4 side out on the easystar first though the goggle link is fine though no interference that i can see :)
It unpacks and so easy to set up i should have done this last year  :D
dizzy :)
