Does this look ok to you more experienced Naza flyers?
Started by Fpvmatt, May 22, 2013, 06:33:45 PM
Fpvmatt
After eons of messing about with my Y6, am pretty happy with the gains, and took her outside today for a quick hop.
This flight is in Atti, but have successfully managed to calibrate GPS, set IOC and Failsafe (Am using an FF9 with a FrSky telemetry module on 2.4ghz)
Fixed my wiring to my 12v Sony HAD 600VTL cam too)
All systems go soon with my Attitudes  ;D
Taking it to my friend's field soon for further testing and familiarity flights soon, before donning the goggles...This is really exciting and cannot wait to see how things go.
Here's the vid, low res, my daughter filmed it on her iphone 5, but for some readon the video was very compressed.
So what do you think, stable enough in atti?
Y6, Naza FC tuned, failsafe, GPS and IOC activated, yes I'm pretty pleased with this!
Thanks to some of you guys who offered advice on here, much appreciated.
Matt
Skipper Billy
Looks good to me !!!
Your look of total concentration was great!!
Google it !!
Fpvmatt
Quote from: Skipper Billy on May 22, 2013, 06:39:04 PM
Ha ha, more a look of terror, lol.
Just seemed forever to get this far, but the dream is very near to reality :-)
Matt
cortex
how you finding those keda motors matt?, much vibration from props?
Fpvmatt
The Keda's are actually pretty smooth, only issues so far is that one arrived with no prop adapter and if you bend a shaft on an adapter, you need to buy a whole new motor as spares are not available, which is mildly irritating.
As for the motors, they run well and smooth, I'm liking them so far :)
Just wish spares support was better.
Actually need to buy another now, as I found one of mine has a bit of run out on an adapter end.
cortex
Quote from: Fpvmatt on May 22, 2013, 08:07:32 PM
Try here
http://www.giantshark.co.uk/keda-kd2217-accessory-pack-p-403659.html
I got the same motors but have had problems finding the right props as all the ones I have tried vibrate like anything.
William showed me the ones you are currently using, I have ordered a couple of pairs to try out.
Can You take a picture and show me how you have got the motor set up? I'm assuming your using the 4mm threaded adaptor that comes with it?
Fpvmatt
 I can buy spares! I looked there before but must have missed them..thanks :-)
Am using gemfam 9x7 although hard to find at the moment.
A prop balanced is a must, no two ways about it. Try doing that if you haven't already. I diligently balance my props always,a bit tedious but essential.
If that isn't the problem, maybe your gains are too high? Final possibility  is that your cans are imbalanced.?
Not impossible to fix, but a bit tedious.
William has been fantastic with me, answering all my questions. Really nice guy, and of course, he recovered my IFLY from the castle. :)
Will take a pic in a while and post on here, So do you fly in Essex too?
cortex
Quote from: Fpvmatt on May 22, 2013, 10:07:23 PM
At the price of those spares you might aswell buy a new motor tbh.
I tried one of wills gemfans on mine and it worked fine without vibration. Be good if i could find somehwere that sells them in the uk. Its the crap props i have been buying my gains are fine.
fingers crossed that these ones that you recommended on ebay are good.
yeh i do fly in essex, my club is in rainham but they dont really allow fpv.  >:(
Fpvmatt
So you are Glenwin?
Here's a few photos
I did find a guy selling them on ebay, but he's zero stock now, look for a user called floatships.
They seem to be very good props to me, maybe your mounting system? My kit came with flimsy 1.5mm thick fibreglass mounts, swapped them for 2.5mm aluminium ones, much better.
Here's a few gratuitous pics,and one with a motor mount closeup:
cortex
Quote from: Fpvmatt on May 22, 2013, 10:54:53 PM
So you are Glenwin?
Here's a few photos
Im Gwilym not glenwin lol  :D :D :D :D, william has a very hard time pronouncing it, Ironically its welsh for william
very very nice setup. yeh I ordered those props from there but haven't tried them yet as they havent arrived.
Basically I swapped my stock dji motors for the keda's as they are a slightly higher kv, they mount exactly the same too. I had no problems with the previous motors or props so that rules out the mounting
these props are dodgy with 4mm shafts. terrible vibration
http://www.unmannedtechshop.co.uk/multi-rotor/propellers/10x45-propeller-set-carbon-fibre-reinforced.html] [url]http://www.unmannedtechshop.co.uk/multi-rotor/propellers/10x45-propeller-set-carbon-fibre-reinforced.html[/url]
I then tried these
http://www.buildyourowndrone.co.uk/Propeller-set-10x45-EPP-Style-p/ac-ps10x45.htm
Much better in regards to balance and vibration but too floppy, not good for heavy payloads
Now im just waiting on the ones from ebay. Do they come with 4mm inserts and are they quite rigid?
if all else fails i think i might convert back to the stock dji motors as i am confident with the dji propellors designed for them
this is my current setup but of course with the kedas now mounted
Fpvmatt
Hi Gwylim
Nice to hear from you mate  :)
I have found a supplier of 9x5 all carbon props, these look really good, cost more, but from a UK supplier
http://www.ebay.co.uk/itm/9x5-Carbon-Fibre-Propeller-Pair-CW-CCW-Graupner-Quadcopter-Multicopter-DJI-FPV-/200922692595?pt=UK_ToysGames_RadioControlled_JN&hash=item2ec7ecfbf3
Maybe worth a try?
I have one of those SMD G4 LED lights (same as yours) on my Y6 Unbelievably bright! Have you flown a full pack with it on, and if so, is there any discernible effect on your flight times?
Am looking for smaller super bright red LED's to put at the rear of my Y6 to aid orientation in LOS but not found any yet.
The Gemfam props do come with 4mm inserts, they are a tiny bit tight on the Keda shafts, but you can get them on.
The props are very rigid. Have heard stories of the larger gemfams occasionally breaking in flight with some users, but only on the larger sizes.(12" etc) These smaller ones seem to be OK.
Am looking to put all carbon props on mine when I'm happy with the setup in terms of general flying.
Your quad looks good, have seen pics of it flying before, William sent me some pics of one of your FPV meets.
Just need to find more multirotor flyers in Essex to join us!
