What are these bits for ?? (a question about a quad frame)
Started by CurryKitten, June 07, 2013, 03:22:19 PM
I'm building a super cheap quad at the moment - the frame is called an "Alien", it looks a bit like a TBS Disco frame, except it's built out of something not quite as strong as tissue paper.
Anyhoo, I've ended up with some bits left over, which I *think* is for dampening a camera, but I'm not sure.  The front of the frame looks like this, and I've got this spare little rectangle which matches the front, and 4 of these dampener whatsits.
I thought the way they were intended to sit is like this, with the two frame bits sandwiching the dampeners and (hopefully) creating a dampened platform, like this -
If thats the case, then are they supposed to be screwed, or glued, or something else.... or have I got the wrong end of the stick entirely, and these are for something else ?
scotsoft
I think you slot the rubber dampners into the base then do the same for the top plate, no screws needed  ;)
John.
ah - well, that was another thought I had, but I wasn't sure if the slots might have been for that or for looping rubber bands around.  Let me have a go at slotting stuff in
Western
's exactly how they work, slot in. Hence the two narrow sections. Just a double grommet.
Cheers, Mark.
Staib
You can also hang that 'floating' bit underneath (for example to add a brushless gimbal) but then you'd also need legs for ground clearance... :)
Sorry - I should have updated to say it's all attached now.  It actually seems pretty good - the movement isn't too soft, but will move independantly of that frame.  It's only going to carry a little 808 for it's first try though.  If it ever stops raining, I'll find out if it does anything
marcin
If you mount keychain only I would suggest to use only 3 rubbers instead of 4...make it bit more soft ?...
Quote from: marcin on June 13, 2013, 01:22:55 PM
I'll give it some testing, my 808 seems jello free on my mini quad, but is very prone to it on anything bigger, so I may swap over to something else anyway
