Myflydream AAT and RVOSD GPS
Started by markvanhaze, August 14, 2013, 07:33:35 PM
markvanhaze
Hi
I have 115 baud and I am using the green wire from the RVSOD GPS system to get the signal. The AAT driver is showing via yellow blinking led, that it is getting GPS data but the tracker does not track. Selftest works, and the AAT is beeping when I fly behind it, indicating the weaker signal while when im flying infront of the patch panel, the beeping stops. Yet no motion of the tracker. Any ideas? I have not used the tracker for a long time so maybe its defect now but before I throw it away I was going to ask.
markvanhaze
All works now! What I missed was to calibrate the pan servo as described in the AAT manual. ONce that was done, using 115 baud and the green cable from the RVOSD gps, the tracker works like a charm.
