Skywalker Build Log
Started by bignose13, December 28, 2010, 10:21:32 PM
electricmick
Yea, don't worry, we all get our nuts in a twist occasionally.
After yesterday's disaster, I decided to have a go and see if I could cut the ply plate out
I put a new blade in the knife and went at the tail end
I managed to get the plate out after about ten mins, not too much damage and glad I did it
Tail is now on as it should be, woo hoo
Here you can see where I cut the rear of the fuse
Ply plate and blind nuts out
And glued back in correctly, not too bad
Tail bolted on properly
I decided the rudder hinge was pants after all so I got some cyno hinges I had spare and used them up on the rudder, worked well and might do on the elevator
I also cut out the hatch in the side of the fuse, use a new blade for this otherwise the foam will tear and look shite
Thats not looking too bad at all, looks like you got lucky :)
Built the Pan and Tilt and used tower pro metal geared servos
This thing is a work of art, you need to see it to believe the quality
of the thing
Added the motor and used a 3536 1200 kv from Giantcod
I used a 9x4.7 prop and getting 34 amps and a little under 400 watts of power at WOT, fine by me
Fuselage completed  ;D ;D
The pan and tilt does look nice, with 400 watts you`ve got plenty of power, its looking the muts nuts now mate :)
mark1975
hey simon throw your cases on board it ill be summer soon you could sit on that thing and fly abroad
https://plus.goo
Ive already got them packed mark  ;D
Anyway back to the wing
Nothing to difficult here, just dab a bit of hot glue on the servos and tape in the extension leads
I used CA and kicker to glue in the carbon rods and covers and then CA the wings together, holds nice and strong
Completed
Just need to balance and look at the rear stab, it's a little on the piss to the right, think it was something I did when I had to open the rear for the blind nuts, no biggie either trim the foam on the high edge or shim the low edge,
I did the headtracking and thats all sorted, the Blackstork works a treatand found sats before I could put the battery on the sharks and get them on my head, that thing really is good
Jasmine our Shih tzu wanted to have a ride,  :D
hopefully maiden tomorrow with vid, watch this space
Simon
mark1975
good luck simon hope it goes well..matey
https://plus.goo
Ah nice one, she is complete !!!
Stab shouldnt be too much bother to sort out, looking forward to maiden :)
maddirk
Great build, wanna !  ;D  Wondering whether you could keep the nose out of the cam picture by mounting it a bit more forward ? Assuming it does get in the picture, that is.... :+
sail away with me, honey
Quote from: maddirk on January 25, 2011, 11:14:46 AM
I use headtracking so the nose would be in the pic if I look down
If you didnt want the nose in the pic it wouldnt be a prob to move the cam forward
[size=+2]Skywalker Maiden[/size]
Naughty dog
Nice video, sky walker looks like the way to go for nice relaxed flying,
Is there anything  special about your kit, or what would you recommend to start with, as a basic get you in the air set up, and would you do anything different now you have yours flying? Apart from securing the tail with the nuts the right way round !
Cheers Naughty Dog
Quote from: Naughty dog on March 06, 2011, 09:18:19 AM
Cheers Naughty Dog
I would build the same way tbh,
The only think special about my kit is the Pan and Tilt mechanism, works very well but really expensive, but hey you pays yer money as they say
As a basic get you in the air kit, have a look on Best offer buy.com for some 2.4 tx and rx, quite cheap and then get a cheap cam from securith2000, the cam I have on the Skywalker cost something like £24, cant be bad and then your up and flying
